简单翻译 有句不会 请教
 楼主| dod6009 发表于 2009-9-22 11:24 | 显示全部楼层 |阅读模式
TI, FOR, ge, AN, os
6.  A general-purpose function generator. While sine and square waves are popular test signals, I have often found triangular waveforms to be invaluable when searching for nonlinearities. Sometimes you need two  function generators, one to sweep the operating point of the DUT, slowly, back and forth over its operating range, while you watch the response of the output to a small quick square wave-watching  for oscillation or ringing or trouble.
蓝色字体那句,第一个扫频,第二个信号发生器到底要干嘛?
还我今生 发表于 2009-9-23 13:03 | 显示全部楼层
a small quick square wave 脉冲方波的意思吧
 楼主| dod6009 发表于 2009-9-23 18:55 | 显示全部楼层
2# 还我今生 那整句是什么意思??请教
luckymoon 发表于 2009-9-23 19:14 | 显示全部楼层
看输出反映是否对脉冲方波有什么作用或效果
