mbed串口上手也很方便哈。只要包括mbed.h函数即可,一些初始化在mbed.h中已经定义好了。
以下是mbed.h:
- /* mbed Microcontroller Library
- * Copyright (c) 2006-2013 ARM Limited
- * Licensed under the Apache License, Version 2.0 (the "License");
- * you may not use this file except in compliance with the License.
- * You may obtain a copy of the License at
- * http://www.apache.org/licenses/LICENSE-2.0
- * Unless required by applicable law or agreed to in writing, software
- * distributed under the License is distributed on an "AS IS" BASIS,
- * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
- * See the License for the specific language governing permissions and
- * limitations under the License.
- #ifndef MBED_H
- #define MBED_H
- #define MBED_LIBRARY_VERSION 113
- #include "platform.h"
- // Useful C libraries
- #include <math.h>
- #include <time.h>
- // mbed Debug libraries
- #include "mbed_error.h"
- #include "mbed_interface.h"
- // mbed Peripheral components
- #include "DigitalIn.h"
- #include "DigitalOut.h"
- #include "DigitalInOut.h"
- #include "BusIn.h"
- #include "BusOut.h"
- #include "BusInOut.h"
- #include "PortIn.h"
- #include "PortInOut.h"
- #include "PortOut.h"
- #include "AnalogIn.h"
- #include "Ana**ut.h"
- #include "PwmOut.h"
- #include "Serial.h"
- #include "SPI.h"
- #include "SPISlave.h"
- #include "I2C.h"
- #include "I2CSlave.h"
- #include "Ethernet.h"
- #include "CAN.h"
- #include "RawSerial.h"
- // mbed Internal components
- #include "Timer.h"
- #include "Ticker.h"
- #include "Timeout.h"
- #include "LowPowerTimeout.h"
- #include "LowPowerTicker.h"
- #include "LowPowerTimer.h"
- #include "LocalFileSystem.h"
- #include "InterruptIn.h"
- #include "wait_api.h"
- #include "sleep_api.h"
- #include "rtc_time.h"
- using namespace mbed;
- using namespace std;
- #endif
可见只要你把API打对了,就可以工作了
而Serial.h中又把接收继承父类。
- #ifndef MBED_SERIAL_H
- #define MBED_SERIAL_H
- #if DEVICE_SERIAL
- #include "Stream.h"
- #include "SerialBase.h"
- #include "serial_api.h"
- namespace mbed {
- /** A serial port (UART) for communication with other serial devices
- * Can be used for Full Duplex communication, or Simplex by specifying
- * one pin as NC (Not Connected)
- * Example:
- * @code
- * // Print "Hello World" to the PC
- * #include "mbed.h"
- * Serial pc(USBTX, USBRX);
- * int main() {
- * pc.printf("Hello World\n");
- * @endcode
- class Serial : public SerialBase, public Stream {
- public:
- #if DEVICE_SERIAL_ASYNCH
- using SerialBase::read;
- using SerialBase::write;
- #endif
- /** Create a Serial port, connected to the specified transmit and receive pins
- * @param tx Transmit pin
- * @param rx Receive pin
- * @note
- * Either tx or rx may be specified as NC if unused
- Serial(PinName tx, PinName rx, const char *name=NULL);
- protected:
- virtual int _getc();
- virtual int _putc(int c);
- } // namespace mbed
- #endif
- #endif
而实际操作只要掌握基本函数即可:
类名 | | | | Serial(PinName tx, PinName rx, const char *name=NULL); | | | | void format(int bits=8, Parity parity=SerialBase::None, int stop_bits=1); | 设置Uart传输的格式,包括一个字长的位数、奇偶检验的方法、停止位的位数,默认为一个字长为8位,无奇偶检验,1位停止位 | | | | | void attach(void (*fptr)(void), IrqType type=RxIrq); | | void set_flow_control(Flow type, PinName flow1=NC, PinName flow2=NC); | 设置Uart的流控方法,其目标是提高数据发送的可靠性,流控方法有无流控,RTS流控,CTS流控,RTSCTS流控,后面两个常数为流控的管脚设置 | | | | | int printf(const char* format, ...) | 格式化Uart的输出,参数等同标准C的printf | int scanf(const char* format, ...); | |
以下是我的程序:
- #include "mbed.h"
- Serial pc(USBTX, USBRX);
- int main() {
- while(1)
- pc.printf("Hello World\n");
- wait(0.2);
以下是编译通过的截图:
以下是输出结果。总体感觉mbed上手极速地快。
