DWORD CTCPCustom_CE::SocketThreadFunc(PVOID lparam)
CTCPCustom_CE *pSocket;
//得到CTCPCustom类实例指针
pSocket = (CTCPCustom_CE*)lparam;
//定义读事件集合
fd_set fdRead;
int ret;
TIMEVAL aTime;
aTime.tv_sec = 1;
aTime.tv_usec = 0;
while (TRUE)
//收到退出事件,结束线程
if (WaitForSingleObject(pSocket->m_exitThreadEvent,0) == WAIT_OBJECT_0)
break;
//置空读事件集合
FD_ZERO(&fdRead);
//给pSocket设置读事件
FD_SET(pSocket->m_socket,&fdRead);
//调用select函数,判断是否有读事件发生
ret = select(0,&fdRead,NULL,NULL,&aTime);
if (ret == SOCKET_ERROR)
//触发错误事件
pSocket->m_pTCPServer_CE->OnClientError(pSocket->m_pTCPServer_CE->m_pOwnerWnd,pSocket,1);
//关闭socket
closesocket(pSocket->m_socket);
break;
if (ret > 0)
//判断是否读事件
if (FD_ISSET(pSocket->m_socket,&fdRead))
//char recvBuf[1024];
char *recvBuf=new char[1024];
int recvLen;
ZeroMemory(recvBuf,1024);
recvLen = recv(pSocket->m_socket,recvBuf, 1024,0);
if (recvLen == SOCKET_ERROR)
int nErrorCode = WSAGetLastError();
//触发与客户端端连接的Socket错误
pSocket->m_pTCPServer_CE->OnClientError(pSocket->m_pTCPServer_CE->m_pOwnerWnd,pSocket,nErrorCode);
//触发与客户端端连接的Socket关闭事件
pSocket->m_pTCPServer_CE->OnClientClose(pSocket->m_pTCPServer_CE->m_pOwnerWnd,pSocket);
//关闭socket
break;
//表示连接已经从容关闭
else if (recvLen == 0)
//关闭socket
break;
else
//触发与客户端端连接的Socket读事件
pSocket->m_pTCPServer_CE->OnClientRead(pSocket->m_pTCPServer_CE->m_pOwnerWnd,pSocket,recvBuf,recvLen);
delete[] recvBuf;
return 0;
