[i.MX] IMX6Q挂载nfs文件系统
 楼主| jully_bj 发表于 2016-3-11 15:13 | 显示全部楼层 |阅读模式
PC端已经打开,但是开发板IP:192.168.1.70在启动时显示的如下 :怎么来配置gw,bootserver呢?
PHY: 1:00 - Link is Up - 100/Full
IP-Config: Guessing netmask 255.255.255.0
IP-Config: Complete:
     device=eth0, addr=192.168.1.70, mask=255.255.255.0, gw=255.255.255.255,
     host=192.168.1.70, domain=, nis-domain=(none),
     bootserver=255.255.255.255, rootserver=192.168.1.101, rootpath=
VFS: Mounted root (nfs filesystem) on device 0:12.
Freeing init memory: 212K
Failed to execute /init.  Attempting defaults...
nfs: server 192.168.1.101 not responding, still trying
^Cnfs: server 192.168.1.101 OK
mini1986 发表于 2016-3-15 09:53 | 显示全部楼层
他们技术支持好像写了一个nfs的文档,就在论坛里,你可以找找看......
