美国UE压力控制器
 楼主| smilewuqing 发表于 2009-11-11 10:51 | 显示全部楼层 |阅读模式
H100系列(通用型压力、真空、温度开关):H100-483 H100-484 H100-485 H100-486 H100-488 H100-489 H100-490 H100-491 H100-492 H100-493 H100-494 H100-520 H100-521 H100-522 H100-523 H100-524 H100-525 H100-530 H100-531 H100-532 H100-533 H100-534 H100-535 H100-560 H100-561 H100-562 H100-563 H100-564 H100-565 H100-566 H100-567 H100-610 H100-612 H100-616 H100-680 H100-701 H100-702 H100-703 H100-704 H100-705 H100-706;
H100K系列:H100K-540 H100K-541 H100K-542 H100K-543 H100K-544 H100K-545 H100K-546 H100K-547 H100K-548;
J120系列(危险区域安装的压力开关、真空开关、差压开关和温度开关):J120-126 J120-134 J120-137 J120-144 J120-152 J120-156 J120-164 J120-171 J120-172 J120-173 J120-174 J120-183 J120-190 J120-193 J120-356 J120-450 J120-483 J120-484 J120-488 J120-520;
J402K系列:J402K-147 J402K-157 J402K-455 J402K-456 J402K-457 J402K-559 J402K-S147B J402K-S157B J402K-540 J402K-541 J402K-542 J402K-543 J402K-544 J402K-545 J402K-546;
J400K系列(通用型多点输出压力、真空、温度开关):J400K-147 J400K-157 J400K-455 J400K-456 J400K-457 J400K-559 J400K-S147B J400K-S157B;
J120K系列:J120K-36 J120K-37 J120K-38 J120K-39 J120K-147 J120K-157 J120K-367 J120K-455 J120K-456 J120K-457 J120K-540 J120K-541 J120K-542 J120K-543 J120K-544 J120K-545 J120K-546 J120K-547 J120K-548 J120K-559 J120K-S147B J120K-S157B;
H100系列:H100-171 H100-172 H100-173 H100-174 H100-183 H100-184 H100-185 H100-186 H100-188 H100-189 H100-190 H100-191 H100-192 H100-193 H100-194 H100-218 H100-270 H100-274 H100-358 H100-361 H100-376;
J403系列压力开关:J403-S134B J403-S137B J403-S144B J403-S146B J403-S156B J403-S164B  J403-126  J403-134  J403-137  J403-144  J403-146  J403-156 J403-164  J403-270 J403-274  J403-358  J403-361  J403-376 J403-442  J403-443  J403-448  J403-450 J403-451 J403-452  J403-453  J403-454  J403-550 J403-551  J403-552  J403-553 J403-554 J403-555 J403-570  J403-571  J403-572  J403-610  J403-612  J403-614  J403-S126B H403-126 H403-134 H403-144 H403-146 H403-156 H403-164 H403-358 H403-361 H403-376 H403-S126B H403-S134B H403-S144B H403-S146B H403-S156B H403-S164B;
H402K系列压力开关:H402K-455 H402K-456 H402K-457 H402K-559
U系列压力开关:U-10D-10  U-12SHSN2C  U-12SHSN3A  U-12SHSN3D  U-24-013
U-24-014  U-24-014-M262  U-2S260L4-316  U-3611SB1  U-B402-120  U-H100-171
U-H100-172  U-H100-173  U-H100-174  U-H100-184  U-H100-185  U-H100-188
U-H100-189  U-H100-190  U-H100-191  U-H100-192  U-H100-193  U-H100-194
U-H100-194-M449  U-H100-218  U-H100-358  U-H100-491  U-H100-520  U-H100-522
U-H100-524  U-H100-533  U-H100-534  U-H100-567  U-H100-612  U-H100-612-0500
U-H100-616  U-H100-701  U-H100-702  U-H100-703  U-H100-704  U-H100-705
U-H100-705-M540  U-H100-706  U-H100K-540  U-H100K-544  U-H121K-S147B-M210
U-H122-361  U-H122-612  U-H122-S126B  U-H122-S146B  U-H122-S156B  U-H177-188
U-E122-2BSB-W050  U-J120-126  U-J120-134  U-J120-144  U-J120-171  U-J120-173
U-J120-189  U-J120-190  U-J120-190-0140  U-J120-190-1190  U-J120-191  U-J21K-254
U-J120-192  U-J120-193  U-J120-194  U-J129K-36  U-J120K-S147B  U-J120-560
U-J120K-457-M277   U-J120K-541-0140  U-J40-222  U-J400K-157  U-J400K-455  U-J400K-456
U-J402K-455  U-J400-156  U-J400-164  U-J402-126  U-J402-164  U-J402-454  U-J402-455
U-J402-612  U-J400-S156B  U-J402-S156B  U-J6-230  U-J6-136
福州亿兴合电器有限公司
    陈金皇
电话:0591-83778301
传真:0591-83781315
网 址:http://www.iacauto.com
wubingyan 发表于 2010-5-19 16:33 | 显示全部楼层
有压力传感器吗?
