[家电应用] 基于51单片机,1602的简易时钟设计
 楼主| hfdy01 发表于 2016-4-9 17:03 | 显示全部楼层 |阅读模式
#include<reg52.h>
#define uchar unsigned char
#define uint unsigned int
sbit rs=P3^7;
sbit lcden=P3^6;
sbit s1=P3^0;
sbit s2=P3^1;
sbit s3=P3^2;
uchar count,s1num;
char miao,fen,shi,ri=1,yue=1,nian=15;
uchar code table2[]="(^-^)Made by Ke ";
uchar code table[]=" Welcome to use ";
uchar code table0[]="  2015-01-01  KE";
uchar code table1[]="    00:00:00";
void delay(uint xms)
        uint i,j;
        for(i=xms;i>0;i--)
                for(j=110;j>0;j--);
void write_com(uchar com)
        rs=0;
        lcden=0;
        P0=com;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void write_date(uchar date)
        rs=1;
        lcden=0;
        P0=date;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void init()
        uchar num;
        lcden=0;
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
        write_com(0x80+0x10);
        for(num=0;num<16;num++)
                        write_date(table[num]);
                        delay(5);
                        write_com(0x18);
                        delay(200);
        write_com(0x01);
        write_com(0x80+0x40+0x10);
                        write_date(table2[num]);
                        delay(5);
                        write_com(0x18);
                        delay(200);
        write_com(0x01);
        write_com(0x80);
                        write_date(table0[num]);
                        delay(5);
        write_com(0x80+0x40);
        for(num=0;num<12;num++)
                        write_date(table1[num]);
                        delay(5);
        TMOD=0x01;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        EA=1;
        ET0=1;
        TR0=1;
void write_sfm(uchar add,uchar date)
        uchar shi,ge;
        shi=date/10;
        ge=date%10;
        write_com(0x80+0x40+add);
        write_date(0x30+shi);
        write_date(0x30+ge);
void write_sfm0(uchar add,uchar date)
        uchar shi,ge;
        shi=date/10;
        ge=date%10;
        write_com(0x80+add);
void keyscan()
        if(s1==0)
                delay(5);
                if(s1==0)
                        T0=0;
                        s1num++;
                        while(!s1);
                        if(s1num==1)
                                write_com(0x80+0x40+10);
                                write_com(0x0f);
                        if(s1num==2)
                                write_com(0x80+0x40+7);
                        if(s1num==3)
                                write_com(0x80+0x40+4);
                        if(s1num==4)
                                write_com(0x80+10);
                        if(s1num==5)
                                write_com(0x80+7);
                        if(s1num==6)
                                write_com(0x80+4);
                        if(s1num==7)
                                s1num=0;
                                T0=1;
                                write_com(0x0c);
        if(s1num!=0)
                if(s2==0)
                        delay(5);
                        if(s2==0)
                                while(!s2);
                                if(s1num==1)
                                        miao++;
                                        if(miao>=60)
                                                miao=0;
                                        write_sfm(10,miao);
                                if(s1num==2)
                                        fen++;
                                        if(fen>=60)
                                                fen=0;
                                        write_sfm(7,fen);
                                if(s1num==3)
                                        shi++;
                                        if(shi==24)
                                                shi=0;
                                        write_sfm(4,shi);
                                if(s1num==4)
                                        ri++;
                                        if(yue==2&&ri==29)
                                                ri=1;
                                        if((yue==4||yue==6||yue==9||yue==11)&&ri==31)
                                                ri=1;
                                        if(ri==32)
                                                ri=1;
                                        write_sfm0(10,ri);
                                        write_com(0x80+10);
                                if(s1num==5)
                                        yue++;
                                        if(yue==13)
                                                yue=1;
                                        write_sfm0(7,yue);
                                        write_com(0x80+7);
                                if(s1num==6)
                                        nian++;
                                        if(nian==99)
                                                nian=15;
                                        write_sfm0(4,nian);
                                        write_com(0x80+4);
                if(s3==0)
                        delay(5);
                        if(s3==0)
                                while(!s3);
                                if(s1num==1)
                                        miao--;
                                        if(miao==-1)
                                                miao=59;
                                        write_sfm(10,miao);
                                if(s1num==2)
                                        fen--;
                                        if(fen==-1)
                                                fen=59;
                                        write_sfm(7,fen);
                                if(s1num==3)
                                        shi--;
                                        if(shi==-1)
                                                shi=23;
                                        write_sfm(4,shi);
                                if(s1num==4)
                                        ri--;
                                        if(yue==2&&ri==0)
                                                ri=28;
                                        if((yue==4||yue==6||yue==9||yue==11)&&ri==0)
                                                ri=30;
                                        if(ri==0)
                                                ri=31;
                                        write_sfm0(10,ri);
                                        write_com(0x80+10);
                                if(s1num==5)
                                        yue--;
                                        if(yue==0)
                                                yue=12;
                                        write_sfm0(7,yue);
                                        write_com(0x80+7);
                                if(s1num==6)
                                        nian--;
                                        if(nian==14)
                                                nian=99;
                                        write_sfm0(4,nian);
                                        write_com(0x80+4);
void main()
        init();
        while(1)
                keyscan();
void timer0() interrupt 1
        count++;
        if(count==18)
                count=0;
                miao++;
                if(miao==60)
                        miao=0;
                        fen++;
                        if(fen==60)
                                fen=0;
                                shi++;
                                if(shi==24)
                                        shi=0;
                                        ri++;
                                        if(yue==2&&ri==29)
                                                ri=1;
                                                yue++;
                                                if(yue==13)
                                                        yue=1;
                                                        nian++;
                                                        if(nian==100)
        nian=15;
                                                        write_sfm0(4,nian);
                                                write_sfm0(7,yue);
                                                ri=1;
                                                yue++;
                                                if(yue==13)
                                                        yue=1;
                                                        nian++;
                                                        if(nian==100)
        nian=15;
                                                        write_sfm0(4,nian);
                                                write_sfm0(7,yue);
                                        if(ri==32)
                                                ri=1;
                                                yue++;
                                                if(yue==13)
                                                        yue=1;
                                                        nian++;
                                                        if(nian==100)
        nian=15;
                                                        write_sfm0(4,nian);
                                                write_sfm0(7,yue);
                                        write_sfm0(10,ri);
                                write_sfm(4,shi);
                        write_sfm(7,fen);
                write_sfm(10,miao);
feiqi1 发表于 2016-4-9 17:25 | 显示全部楼层
哇 这么多的代码啊,看的迷迷糊糊的呢
androidbus 发表于 2016-4-9 17:32 | 显示全部楼层
可惜只是有代码, 不知道楼主想要分享什么有用的信息
 楼主| hfdy01 发表于 2016-4-9 18:13 | 显示全部楼层
哇 这么多的代码啊,看的迷迷糊糊的呢
这个代码量也不算很大吧。
 楼主| hfdy01 发表于 2016-4-9 18:14 | 显示全部楼层
这是一段基于51单片机,1602的简易时钟设计的程序代码、
洛理小子 发表于 2016-4-9 18:29 | 显示全部楼层
楼主想要表达什么呢??
mylinss 发表于 2016-4-9 23:06 | 显示全部楼层
同楼上没明白楼主意图:
robter 发表于 2016-4-10 13:10 | 显示全部楼层
很好很好,感谢感谢
feiqi1 发表于 2016-5-16 10:31 | 显示全部楼层
这个代码量也不算很大吧。
只能说我是新手,还得像楼主这样的大神学习啊
androidbus 发表于 2016-5-16 10:58 | 显示全部楼层
哦哦 好的,不知道楼主问题现在解决没有呢??
 楼主| hfdy01 发表于 2016-5-22 21:34 | 显示全部楼层
现在问题解决了,多谢多谢了啊
androidbus 发表于 2016-5-24 21:45 | 显示全部楼层
现在问题解决了,多谢多谢了啊
怎么解决的呀,解决就好
 楼主| hfdy01 发表于 2016-5-24 22:01 | 显示全部楼层
怎么解决的呀,解决就好
