求帮帮忙,刚用GD类的MCU
 楼主| 小曹111 发表于 2016-4-19 17:54 | 显示全部楼层 |阅读模式
MCU, pi, IO, GPIO, gp
/* Includes ------------------------------------------------------------------*/
#include "gd32f1x0.h"
#include <stdio.h>
#include "systick.h"
/* Private functions ---------------------------------------------------------*/
  * @brief  Configure the GPIO ports.
  * @param  None
  * @retval None
void delay(int x)
  int i,j;
   for(i=x;i>0;i--)
     for(j=110;j>0;j--);
void LED_config(void)
    GPIO_InitPara GPIO_InitStructure;
        RCC_APB2PeriphClock_Enable(RCC_APB2Periph_GPIOC,ENABLE);
    //RCC_AHBPeriphClock_Enable(RCC_AHBPERIPH_GPIOB,ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_PIN_6;
    GPIO_InitStructure.GPIO_Mode = GPIO_MODE_OUT;
    GPIO_InitStructure.GPIO_Speed = GPIO_SPEED_2MHZ;
    GPIO_InitStructure.GPIO_OType = GPIO_OTYPE_PP;
    GPIO_InitStructure.GPIO_PuPd = GPIO_PUPD_NOPULL;
    GPIO_Init(GPIOC,&GPIO_InitStructure);
  * @brief  Toggle the LED every 500ms.
  * @param  None
  * @retval None
void LED_Spark(void)
   /* static __IO uint32_t TimingDelayLocal = 0;
    if (TimingDelayLocal != 0x00)
        if(TimingDelayLocal < 500)
            GPIO_ResetBits(GPIOB, GPIO_PIN_9);
        else
            GPIO_SetBits(GPIOB,GPIO_PIN_9);
        TimingDelayLocal--;
    else
        TimingDelayLocal = 1000;
            //GPIO_SetBits(GPIOB,GPIO_PIN_15);*/
  * @brief  Main program.
  * @param  None
  * @retval None
int main(void)
    LED_config();
        GPIO_SetBits(GPIOC,GPIO_PIN_6);
        delay(500);
        GPIO_ResetBits(GPIOC,GPIO_PIN_6);
        //LED_Spark();
    SysTick_Configuration();
    while (1)
由于文件太大,沾不上来,我就把主函数拿出来,各位大神帮我看看为什么驱动不了LED,用的是GD32F103RCT6芯片,程序编译时没有问题,程序是以前用ST时的程序改的,在ST板子上能正常运行,谢谢各位大神,求指教
zhangmangui 发表于 2016-4-19 22:18 | 显示全部楼层
你好   GD你应该发到GD32 MCU版块去
都被注册了啊啊 发表于 2016-4-20 14:26 | 显示全部楼层
是的呀
vivilzb1985 发表于 2016-4-20 20:43 | 显示全部楼层
这个是用GD的f1X系列的单片机的?还是?
 楼主| 小曹111 发表于 2016-4-21 11:21 | 显示全部楼层
GD32F103
