- #include <stdio.h>
- #include <stdlib.h>
- #include <strings.h>
- #include <string.h>
- #include <unistd.h>
- #include <sys/types.h>
- #include <sys/socket.h>
- #include <netinet/in.h>
- #include <arpa/inet.h>
- #include <netdb.h>
- #include <sys/stat.h>
- #include <fcntl.h>
- #include <netinet/tcp.h>
- #include <net/if.h>
- #include <sys/ioctl.h>
- unsigned long int get_host_ip ()
- int tempSock = socket(PF_INET, SOCK_DGRAM, 0);
- struct ifreq ifr;
- strcpy(ifr.ifr_name, "eth0");
- if (ioctl(tempSock, SIOCGIFADDR, &ifr) < 0) { printf("error: ioctl\n"); exit (0); }
- close (tempSock);
- unsigned long int host_ip = (((struct sockaddr_in *)&(ifr.ifr_addr))->sin_addr).s_addr;
- return host_ip;
- long int get_random (void)
- int fd = 0;
- if ((fd = open ("/dev/urandom", O_RDONLY | O_NONBLOCK)) == -1) { printf ("error: open /dev/urandom. exit\n"); exit (0); }
- long int buf;
- if (read (fd, (char *)&buf, 4) != 4) { printf ("error: read /dev/urandom. exit\n"); exit (0); }
- if (close (fd) != 0) { printf ("error: close() fd. exit\n"); exit (0); }
- return buf;
- unsigned short csum (unsigned short *buf, int nwords) /* generates header checksums */
- unsigned long sum;
- for (sum = 0; nwords > 0; nwords--)
- sum += *buf++;
- sum = (sum >> 16) + (sum & 0xffff);
- sum += (sum >> 16);
- return ~sum;
- struct pseudohdr {
- u_int32_t saddr; /* source IP address */
- u_int32_t daddr; /* destination IP address */
- u_int8_t res; /* contains binary zeroes.(0) */
- u_int8_t ptcl; /* protocol. can be tcp (6), udp(17), icmp(1) */
- u_int16_t len; /* TCP/UDP packet length. (unit:byte) */
- int main (int argc, char *argv[])
- if (argc != 5) { printf ("usage: %s fromip toip fromport toport\n", argv[0]); exit (0); }
- unsigned long fromip, toip;
- fromip = ntohl(inet_addr(argv[1])); toip = ntohl(inet_addr(argv[2])); /* inet_aton() returns non-zero if the address is valid, zero if not. */
- if ((fromip == 0) || (toip == 0) || ((toip-fromip) < 0)) { printf ("error: fromip or toip\n"); exit (0); }
- unsigned short fromport, toport;
- fromport = atoi (argv[3]); toport = atoi (argv[4]);
- if ((fromport == 0) || (toport == 0) || ((toport-fromport) < 0)) { printf ("error: fromport or toport\n"); exit (0); }
- int raw_sock_tcp;
- if ((raw_sock_tcp = socket(PF_INET, SOCK_RAW, IPPROTO_TCP)) == -1) { printf("socket() failed!\nMust be root to make raw socket.\n"); exit(0); }
- unsigned char packet[80]; bzero (packet, 80);
- struct tcphdr *tcph = (struct tcphdr *)packet;
- /* fill in the tcp header values */
- // tcph->source = htons (1234);
- tcph->source = htons (get_random());
- tcph->dest = htons (1);
- tcph->seq = get_random (); /* in a SYN packet, the sequence is a random */
- tcph->ack_seq = 0; /* number, and the ack sequence is 0 in the 1st packet */
- tcph->doff = 5;
- tcph->syn = 1; /* initial connection request */
- tcph->window = htonl (65535); /* maximum allowed window size */
- tcph->check = 0;
- tcph->urg_ptr = 0;
- struct sockaddr_in dest; bzero (&dest, sizeof (dest));
- dest.sin_family = PF_INET; dest.sin_addr.s_addr = inet_addr ("1.2.3.4"); dest.sin_port = htons (1);
- unsigned long int host_ip = get_host_ip ();
- int ip_i,port_i;
- for(ip_i = 0; ip_i <= (toip-fromip); ip_i++) {
- for(port_i = 0; port_i <= (toport-fromport); port_i++) {
- dest.sin_addr.s_addr = htonl (fromip + ip_i); dest.sin_port = htons (fromport + port_i);
- tcph->dest = htons (fromport + port_i);
- unsigned char buf[512]; bzero (buf, 512);
- struct pseudohdr *pseudohdr;
- pseudohdr = (struct pseudohdr *)buf;
- /* full pseudohdr */
- pseudohdr->daddr = dest.sin_addr.s_addr;
- pseudohdr->saddr = host_ip;
- pseudohdr->res = 0; pseudohdr->ptcl = 0x06;
- pseudohdr->len = htons((tcph->doff)<<2);
- tcph->check = 0;
- memcpy((unsigned char *)pseudohdr+sizeof(struct pseudohdr), (unsigned char *)tcph, (tcph->doff)<<2);
- tcph->check = csum((unsigned short *)pseudohdr, (((tcph->doff)<<2) + sizeof(struct pseudohdr))>>1);
- if (sendto (raw_sock_tcp, packet, /* the buffer containing headers and data */
- ((tcph->doff)<<2), /* total length of our packet */
- 0, (struct sockaddr *) &dest, sizeof (struct sockaddr)) < 0)
- printf ("error: sendto()\n");
- fd_set readfs; /* file descriptor set */
- FD_ZERO (&readfs); FD_SET (raw_sock_tcp, &readfs);
- struct timeval timeout = {0, 0}; /* 0s */
- while (select (raw_sock_tcp+1, &readfs, NULL, NULL, &timeout)) {
- bzero (buf, 512);
- int n_recv;
- n_recv = recvfrom(raw_sock_tcp, buf, 512, 0, NULL, NULL);
- if(n_recv < 40) { continue; } /* 20byte ip header + 20byte tcp header */
- if(buf [33] == 0x12) {
- printf ("%d.%d.%d.%d %d\n", buf[12], buf[13], buf[14], buf[15],
- ((buf[20]<<8)&0XFF00 | buf[21]&0XFF));
- return 0;
