仿真器连接不上怎么办?
 楼主| redgalaxy 发表于 2010-3-3 10:34 | 显示全部楼层 |阅读模式
安装CCS3.1后用的是仿真器连接不上出现SEED510,芯片2812
Error connecting to the target:
Error 0x80000240/-2092
Fatal Error during: Initialization, OCS,
Device driver: Emulation Connection Loss Detected on Target CPU.
It is recommended to RESET EMULATOR.  This will disconnect each
target from the emulator.  The targets should then be power cycled
or hard reset followed by an emureset and reconnect to each target.
Sequence ID: 0
Error Code: -2092
Error Class: 0x80000240
I/O Port = 240
 楼主| redgalaxy 发表于 2010-3-3 11:36 | 显示全部楼层
原来是接口焊接错了
mmg2013 发表于 2013-1-26 14:12 | 显示全部楼层
噢,我还以为是驱动程序没装好呢,我之前就是这样,然后我也没设置好
