[i.MX] vold mountservice 报错
 楼主| Danlet007 发表于 2016-6-15 10:39 | 显示全部楼层 |阅读模式
imx6dq, 外置SD卡系统设置那边看不到信息,看了下日志好像是/storage/extsd挂载失败。求助如何解决! 日志如下:
--------- beginning of /dev/log/main
--------- beginning of /dev/log/system
I/Vold    (  157): Vold 2.1 (the revenge) firing up
D/Vold    (  157): Volume extsd state changing -1 (Initializing) -> 0 (No-Media)
D/Vold    (  157): Volume udisk state changing -1 (Initializing) -> 0 (No-Media)
D/Vold    (  157): Volume extsd state changing 0 (No-Media) -> 2 (Pending)
D/MountService(  468): got storage path: null description: 内存设备 primary: true removable: false emulated: true mtpReserve: 100 allowMassStorage: false maxFileSize: 0
D/MountService(  468): addVolumeLocked() StorageVolume:
D/MountService(  468):     mStorageId=65537 mPath=/storage/emulated/0 mDescriptionId=17040663
D/MountService(  468):     mPrimary=true mRemovable=false mEmulated=true mMtpReserveSpace=100
D/MountService(  468):     mAllowMassStorage=false mMaxFileSize=0 mOwner=UserHandle{0} mUuid=null
D/MountService(  468):     mUserLabel=null mState=null
D/MountService(  468): got storage path: /storage/extsd description: SD 卡 primary: false removable: true emulated: false mtpReserve: 0 allowMassStorage: false maxFileSize: 0
D/MountService(  468):     mStorageId=0 mPath=/storage/extsd mDescriptionId=17040664 mPrimary=false
D/MountService(  468):     mRemovable=true mEmulated=false mMtpReserveSpace=0 mAllowMassStorage=false
D/MountService(  468):     mMaxFileSize=0 mOwner=null mUuid=null mUserLabel=null mState=null
D/MountService(  468): got storage path: /storage/udisk description: USB 存储器 primary: false removable: true emulated: false mtpReserve: 0 allowMassStorage: false maxFileSize: 0
D/MountService(  468):     mStorageId=0 mPath=/storage/udisk mDescriptionId=17040665 mPrimary=false
E/MountService(  468): Error processing initial volume state
E/MountService(  468): java.lang.Exception: Unexpected state 2
E/MountService(  468):         at com.android.server.MountService$4.run(MountService.java:754)
E/MountService(  468): Boot-time mount failed (-1)
E/MountService(  468): Boot-time mount failed (-2)
W/MountService(  468): Duplicate state transition (mounted -> mounted) for /storage/emulated/0
 楼主| Danlet007 发表于 2016-6-15 11:14 | 显示全部楼层
01-01 08:00:04.940 D/MagDaemon(  169): init_sensors
01-01 08:00:05.010 I/OrionSvc(  170): Set command is setprop athr.gps.conf /system/etc/gps/Orion.ini
01-01 08:00:05.030 I/installd(  164): installd firing up
01-01 08:00:05.040 I/OrionSvc(  170): using prop value
01-01 08:00:05.050 I/OrionSvc(  170): Get key ANDROID_SOCKET_athrshmsocket on 11
01-01 08:00:05.050 I/OrionSvc(  170): Enter control_ipc thread
01-01 08:00:05.070 I/DEBUG   (  159): debuggerd: Apr 26 2016 14:28:17
01-01 08:00:05.100 I/Netd    (  158): Netd 1.0 starting
01-01 08:00:05.100 W/InterfaceController(  158): Warning (dlopen failed: library "/system/lib/libnetcmdiface.so" not found) while opening the net interface command library
01-01 08:00:05.220 E/DirectVolume(  157): Vold managed volumes must have auto mount point; ignoring /mnt/media_rw/extsd
01-01 08:00:05.220 E/DirectVolume(  157): Vold managed volumes must have auto mount point; ignoring /mnt/media_rw/udisk
01-01 08:00:05.220 I/Vold    (  157): Vold 2.1 (the revenge) firing up
01-01 08:00:05.220 D/Vold    (  157): Volume extsd state changing -1 (Initializing) -> 0 (No-Media)
01-01 08:00:05.220 D/Vold    (  157): Volume udisk state changing -1 (Initializing) -> 0 (No-Media)
01-01 08:00:05.250 D/Vold    (  157): Volume extsd state changing 0 (No-Media) -> 2 (Pending)
01-01 08:00:05.260 E/DirectVolume(  157): Partition '/devices/soc0/soc.1/2100000.aips-bus/2198000.usdhc/mmc_host/mmc2/mmc2:aaaa/block/mmcblk2/mmcblk2p8' has a different major than its disk!
