[STM32F7] STM32F746需要Keil MDK 5.? 哪个版本?
 楼主| walnutcy 发表于 2016-7-22 16:24 | 显示全部楼层 |阅读模式
如题, 在5.14里没有STM32F7这个系列? 谢谢。
mmuuss586 发表于 2016-7-22 16:38 | 显示全部楼层
不知道用哪个版本;
可以到KEIL公司网站下一个安装包,再在KEIL MDK中导入安装
 楼主| walnutcy 发表于 2016-7-22 16:51 | 显示全部楼层
不知道用哪个版本;
可以到KEIL公司网站下一个安装包,再在KEIL MDK中导入安装 ...
找到源头了, 是从5.12开始支持的, 额用的5.14应该可以干活。
In order to get the best performance out the Cortex-M7 processor, a number of C compilers and their runtime libraries have been optimized and updated.
In addition, a number of changes in the debug system for the Cortex-M7 processor compared to Cortex-M4 means that software developers must update their tool chain to a newer version in order to debug applications on Cortex-M7 based microcontroller products. In a few cases, the firmware on the debug adaptor might also need an update.
As a result, an update to latest development tool chain is strongly recommended.
Keil MDK officially supports the Cortex-M7 starting with version 5.12
