[STM32F0] 多路AD DMA模式,输出问题,在线求救?
 楼主| chinamaken 发表于 2016-9-9 16:33 | 显示全部楼层 |阅读模式
DMA, AD, dc, ADC, AN
ADC初始化
void MX_ADC_Init(void)
    ADC_ChannelConfTypeDef sConfig;
    GPIO_InitTypeDef GPIO_InitStruct;
    /* Peripheral clock enable */
    __HAL_RCC_GPIOA_CLK_ENABLE();
    __HAL_RCC_ADC1_CLK_ENABLE();
    GPIO_InitStruct.Pin = GPIO_PIN_6|GPIO_PIN_7;
    GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
    GPIO_InitStruct.Pull = GPIO_NOPULL;
    HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
    hadc.Instance = ADC1;
    if (HAL_ADC_DeInit(&hadc) != HAL_OK)
        Error_Handler();
    hadc.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV4;
    hadc.Init.Resolution = ADC_RESOLUTION_12B;
    hadc.Init.DataAlign = ADC_DATAALIGN_RIGHT;
    hadc.Init.ScanConvMode = ADC_SCAN_ENABLE;
    hadc.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
    hadc.Init.LowPowerAutoWait = DISABLE;
    hadc.Init.LowPowerAutoPowerOff = DISABLE;
    hadc.Init.ContinuousConvMode = ENABLE;
    hadc.Init.DiscontinuousConvMode = DISABLE;
    hadc.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
    hadc.Init.DMAContinuousRequests = ENABLE;
    hadc.Init.Overrun = ADC_OVR_DATA_PRESERVED;
    if (HAL_ADC_Init(&hadc) != HAL_OK)
        Error_Handler();
    /* ### - 2 - Start calibration ############################################ */
    if (HAL_ADCEx_Calibration_Start(&hadc) != HAL_OK)
        Error_Handler();
    /**Configure for the selected ADC regular channel to be converted.
    sConfig.Channel = ADC_CHANNEL_6;
    sConfig.Rank = ADC_RANK_CHANNEL_NUMBER;
    sConfig.SamplingTime = ADC_SAMPLETIME_239CYCLES_5;
    if (HAL_ADC_ConfigChannel(&hadc, &sConfig) != HAL_OK)
        Error_Handler();
    sConfig.Channel = ADC_CHANNEL_7;
        Error_Handler();
    /* ### - 4 - Start conversion in DMA mode ################################# */
    if (HAL_ADC_Start(&hadc) != HAL_OK)
        Error_Handler();
DMA初始化
static void MX_DMA_Init(void)
    /* DMA controller clock enable */
    __HAL_RCC_DMA1_CLK_ENABLE();
    /* DMA interrupt init */
    /* DMA1_Channel1_IRQn interrupt configuration */
    HAL_NVIC_SetPriority(DMA1_Channel1_IRQn, 0, 0);
    HAL_NVIC_EnableIRQ(DMA1_Channel1_IRQn);
__IO uint32_t ADC_Value[2];
uint32_t ad0,ad1;
int main(void)
    .....//此处省略一些
    MX_ADC6_Init();
    HAL_ADC_Start_DMA(&hadc, (uint32_t*)&ADC_Value, 2);
    while(1)
        HAL_Delay(500);
        ad0 = ADC_Value[0];
        ad1 = ADC_Value[1];
         printf("\r\n******** ADC DMA Example ********\r\n\r\n");
        printf(" AD0 value = %1.3fV \r\n", ad0*3.3f/4096);
        printf(" AD1 value = %1.3fV \r\n", ad1*3.3f/4096);
输出结果:
AD0 value = 0.000V
AD1 value = 0.000V
然而这两个引脚是都有电压的。求救呀?
 楼主| chinamaken 发表于 2016-9-9 16:57 | 显示全部楼层
有人在吗??
 楼主| chinamaken 发表于 2016-9-12 10:06 | 显示全部楼层
电子技术论坛算是没人了
maiweiqi 发表于 2016-9-12 11:15 | 显示全部楼层
代码太长没看,输出值为零,的话,看看转换速度是不是太快了。
xmshao 发表于 2016-9-12 14:42 | 显示全部楼层
你DMA配置了吗?
