[LabVIEW资料] 哪位有Vision的安装包
 楼主| 18662000038 发表于 2016-9-10 20:06 | 显示全部楼层 |阅读模式
哪位有能配套13版Lab的Vision?最好是中文的,有兼容的也可以
hbzjt2011 发表于 2016-9-12 11:36 | 显示全部楼层
Vision Development Module 2013 SP1 - Windows 8 32-bit/8 64-bit/7 64-bit/7 32-bit/Vista 64-bit/Vista 32-bit/XP 32-bit/Server 2008 R2 64-bit/Server 2008 64-bit/Server 2003 R2 32-bit下载器下载:
http://ftp.ni.com/support/softlib/vision/Vision%20Development%20Module/2013SP1/VDM2013SP1_downloader.exe&
直接下载:
http://ftp.ni.com/support/softlib/vision/Vision%20Development%20Module/2013SP1/VDM2013SP1.exe
Download Language: English
Product Line: Vision Software
Version: 2013 SP1
Release date: 02-14-2014
Software type: Addons
Operating system: Windows 8 32-bit; Windows 8 64-bit; Windows 7 64-bit; Windows 7 32-bit; Windows Vista 64-bit; Windows Vista 32-bit; Windows XP 32-bit; Windows Server 2008 R2 64-bit; Windows Server 2008 64-bit; Windows Server 2003 R2 32-bit
描述:
Installing this program may remove previous versions of the NI Vision Development Module that are currently instalLED.
The NI Vision Development Module 2013 SP1 supports LabVIEW 2010, 2011, 2012, and 2013; Visual Studio 2005 and 2008; and LabWindows/CVI 8.1 or later. The installer specifically allows side-by-side installations of NI Vision for each of the supported versions of LabVIEW, enabling you to use the NI Vision Development Module with multiple versions of LabVIEW. National Instruments recommends that you install LabVIEW, LabVIEW Real-Time, or any other supported development environment, before installing the NI Vision Development Module
Note: The NI Vision Development Module overwrites existing NI Vision examples and NI Vision VIs. Move modified examples or VIs that you want to save to another directory before installing the NI Vision Development Module.
功能:
Support for LabVIEW 2013 SP1 (32- and 64-bit)
New IMAQ ImageToEDVR VI, which exposes an image as an external data value reference. This allows you to manipulate image pixels using an In Place Element structure in LabVIEW and avoid making unnecessary copies of image data.
Increased JPEG performance when streaming images from remote targets to the host machine.
Improvements to calibration
 楼主| 18662000038 发表于 2016-9-12 16:00 | 显示全部楼层
Vision Development Module 2013 SP1 - Windows 8 32-bit/8 64-bit/7 64-bit/7 32-bit/Vista 64-bit/Vista  ...
多谢!
