- // this method makes a HTTP connection to the server:
- void sendData(int device_id,int sensor_id,int thisData) {
- // if there's a successful connection:
- if (wifi.ipConfig(TCP,server, 80)) {
- DebugSerial.println("connecting...");
- // send the HTTP PUT request:
- String cmd;
- cmd = "POST /v1.0/device/";
- cmd += String(device_id);
- cmd += "/sensor/";
- cmd += String(sensor_id);
- cmd += "/datapoints";
- cmd += " HTTP/1.1\r\n";
- cmd += "Host: api.yeelink.net\r\n";
- cmd += "Accept: *";
- cmd += "/";
- cmd += "*\r\n";
- cmd += "U-ApiKey: ";
- cmd += APIKEY;
- cmd += "\r\n";
- cmd += "Content-Length: ";
- int thisLength = 10 + getLength(thisData);
- cmd += String(thisLength);
- cmd += "\r\n";
- cmd += "Content-Type: application/x-www-form-urlencoded\r\n";
- cmd += "Connection: close\r\n";
- cmd += "\r\n";
- cmd += "{"value":";
- cmd += String(thisData);
- cmd += "}\r\n";
- DebugSerial.println(cmd);
- wifi.Send(cmd);
- // note the time that the connection was made:
- lastConnectionTime = millis();
- else {
- // if you couldn't make a connection:
- DebugSerial.println("connection failed");
- DebugSerial.println("disconnecting.");
- wifi.closeMux();
- int getLength(int someValue) {
- // there's at least one byte:
- int digits = 1;
- // continually divide the value by ten,
- // adding one to the digit count for each
- // time you divide, until you're at 0:
- int dividend = someValue /10;
- while (dividend > 0) {
- dividend = dividend /10;
- digits++;
- // return the number of digits:
- return digits;
- int dht11_read(int pin)
- // BUFFER TO RECEIVE
- int bits[5];
- int cnt = 7;
- int idx = 0;
- // EMPTY BUFFER
- for (int i=0; i< 5; i++)
- {bits= 0;}
- // REQUEST SAMPLE
- pinMode(pin, OUTPUT);
- digitalWrite(pin, LOW);
- delay(18);
- digitalWrite(pin, HIGH);
- delayMicroseconds(40);
- pinMode(pin, INPUT);
- // ACKNOWLEDGE or TIMEOUT
- unsigned int loopCnt = 10000;
- while(digitalRead(pin) == LOW)
- if (loopCnt-- == 0) return -2;
- loopCnt = 10000;
- while(digitalRead(pin) == HIGH)
- // READ OUTPUT - 40 BITS => 5 BYTES or TIMEOUT
- for (int i=0; i<40; i++)
- loopCnt = 10000;
- unsigned long t = micros();
- loopCnt = 10000;
- if ((micros() - t) > 40) bits[idx] |= (1 << cnt);
- if (cnt == 0) // next byte?
- cnt = 7; // restart at MSB
- idx++; // next byte!
- else cnt--;
- // WRITE TO RIGHT VARS
- // as bits[1] and bits[3] are allways zero they are omitted in formulas.
- humidity = bits[0];
- temperature = bits[2];
- int sum = bits[0] + bits[2];
- if (bits[4] != sum) return -1;
- return 0;
