- * [url=home.php?mod=space&uid=288409]@file[/url] main.c
- * [url=home.php?mod=space&uid=895143]@version[/url] V3.00
- * $Revision: 6 $
- * $Date: 15/09/02 10:04a $
- * @brief
- * Monitor the conversion result of channel 2 by the digital compare function.
- * @note
- * Copyright (C) 2013~2015 Nuvoton Technology Corp. All rights reserved.
- #include "stdio.h"
- #include "M451Series.h"
- #define PLLCTL_SETTING CLK_PLLCTL_72MHz_HXT
- #define PLL_CLOCK 72000000
- /* Define global variables and constants */
- volatile uint32_t g_u32AdcCmp0IntFlag;
- volatile uint32_t g_u32AdcCmp1IntFlag;
- /* Define functions prototype */
- int32_t main(void);
- void EADC_FunctionTest(void);
- void SYS_Init(void)
- /* Init System Clock */
- /* Enable HIRC clock (Internal RC 22.1184MHz) */
- CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
- /* Wait for HIRC clock ready */
- CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
- /* Select HCLK clock source as HIRC and and HCLK source divider as 1 */
- CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
- /* Set PLL to Power-down mode and PLLSTB bit in CLK_STATUS register will be cleared by hardware.*/
- CLK_DisablePLL();
- /* Enable HXT clock (external XTAL 12MHz) */
- CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
- /* Wait for HXT clock ready */
- CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
- /* Set core clock as PLL_CLOCK from PLL */
- CLK_SetCoreClock(PLL_CLOCK);
- /* Enable UART module clock */
- CLK_EnableModuleClock(UART0_MODULE);
- /* Select UART module clock source as HXT and UART module clock divider as 1 */
- CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UARTSEL_HXT, CLK_CLKDIV0_UART(1));
- /* Enable EADC module clock */
- CLK_EnableModuleClock(EADC_MODULE);
- /* EADC clock source is 72MHz, set divider to 8, ADC clock is 72/8 MHz */
- CLK_SetModuleClock(EADC_MODULE, 0, CLK_CLKDIV0_EADC(8));
- /* Init I/O Multi-function */
- /* Set PD multi-function pins for UART0 RXD and TXD */
- SYS->GPD_MFPL &= ~(SYS_GPD_MFPL_PD0MFP_Msk | SYS_GPD_MFPL_PD1MFP_Msk);
- SYS->GPD_MFPL |= (SYS_GPD_MFPL_PD0MFP_UART0_RXD | SYS_GPD_MFPL_PD1MFP_UART0_TXD);
- /* Configure the GPB0 - GPB3 ADC analog input pins. */
- SYS->GPB_MFPL &= ~(SYS_GPB_MFPL_PB0MFP_Msk | SYS_GPB_MFPL_PB1MFP_Msk |
- SYS_GPB_MFPL_PB2MFP_Msk | SYS_GPB_MFPL_PB3MFP_Msk);
- SYS->GPB_MFPL |= (SYS_GPB_MFPL_PB0MFP_EADC_CH0 | SYS_GPB_MFPL_PB1MFP_EADC_CH1 |
- SYS_GPB_MFPL_PB2MFP_EADC_CH2 | SYS_GPB_MFPL_PB3MFP_EADC_CH3);
- /* Disable the GPB0 - GPB3 digital input path to avoid the leakage current. */
- GPIO_DISABLE_DIGITAL_PATH(PB, 0xF);
- void UART0_Init()
- /* Init UART */
- /* Reset UART IP */
- SYS->IPRST1 |= SYS_IPRST1_UART0RST_Msk;
- SYS->IPRST1 &= ~SYS_IPRST1_UART0RST_Msk;
- /* Configure UART0 and set UART0 baud rate */
- UART0->BAUD = UART_BAUD_MODE2 | UART_BAUD_MODE2_DIVIDER(__HXT, 115200);
- UART0->LINE = UART_WORD_LEN_8 | UART_PARITY_NONE | UART_STOP_BIT_1;
- /* EADC function test */
- void EADC_FunctionTest()
- printf("\n");
- printf("+----------------------------------------------------------------------+\n");
- printf("| EADC compare function (result monitor) sample code |\n");
- printf("\nIn this test, software will compare the conversion result of channel 2.\n");
- /* Set the ADC internal sampling time, input mode as single-end and enable the A/D converter */
- EADC_Open(EADC, EADC_CTL_DIFFEN_SINGLE_END);
- EADC_SetInternalSampleTime(EADC, 6);
- /* Configure the sample module 0 for analog input channel 2 and ADINT0 trigger source */
- EADC_ConfigSampleModule(EADC, 0, EADC_ADINT0_TRIGGER, 2);
- /* Enable EADC comparator 0. Compare condition: conversion result < 0x800; match Count=5 */
- printf(" Set the compare condition of comparator 0: channel 2 is less than 0x800; match count is 5.\n");
- EADC_ENABLE_CMP0(EADC, 0, EADC_CMP_CMPCOND_LESS_THAN, 0x800, 0x5);
- /* Enable EADC comparator 1. Compare condition: conversion result >= 0x800; match Count=5 */
- printf(" Set the compare condition of comparator 1 : channel 2 is greater than or equal to 0x800; match count is 5.\n");
- EADC_ENABLE_CMP1(EADC, 0, EADC_CMP_CMPCOND_GREATER_OR_EQUAL, 0x800, 0x5);
- /* Enable sample module 0 interrupt */
- EADC_ENABLE_SAMPLE_MODULE_INT(EADC, 0, 0x1);
- /* Clear the A/D ADINT3 interrupt flag for safe */
- EADC_CLR_INT_FLAG(EADC, (0x1 << 3));
- /* Enable ADINT3 interrupt */
- EADC_ENABLE_INT(EADC, (0x1 << 3));
- NVIC_EnableIRQ(ADC03_IRQn);
- /* Clear the EADC comparator 0 interrupt flag for safe */
- EADC_CLR_INT_FLAG(EADC, (0x1 << 4));
- /* Enable ADC comparator 0 interrupt */
- EADC_ENABLE_CMP_INT(EADC, 0);
- /* Clear the EADC comparator 1 interrupt flag for safe */
- EADC_CLR_INT_FLAG(EADC, (0x1 << 5));
- /* Enable ADC comparator 1 interrupt */
- EADC_ENABLE_CMP_INT(EADC, 1);
- /* Reset the EADC interrupt indicator and trigger sample module 0 to start A/D conversion */
- g_u32AdcCmp0IntFlag = 0;
- g_u32AdcCmp1IntFlag = 0;
- EADC_START_CONV(EADC, 0x1);
- /* Wait EADC compare interrupt */
- while((g_u32AdcCmp0IntFlag == 0) && (g_u32AdcCmp1IntFlag == 0));
- /* Disable the sample module 0 interrupt */
- EADC_DISABLE_SAMPLE_MODULE_INT(EADC, 0, 0x1);
- /* Disable ADC comparator interrupt */
- EADC_DISABLE_CMP_INT(EADC, 0);
- EADC_DISABLE_CMP_INT(EADC, 1);
- /* Disable compare function */
- EADC_DISABLE_CMP0(EADC);
- EADC_DISABLE_CMP1(EADC);
- if(g_u32AdcCmp0IntFlag == 1)
- printf("Comparator 0 interrupt occurs.\nThe conversion result of channel 2 is less than 0x800\n");
- else
- printf("Comparator 1 interrupt occurs.\nThe conversion result of channel 2 is greater than or equal to 0x800\n");
- /* EADC interrupt handler */
- void ADC03_IRQHandler(void)
- if(EADC_GET_INT_FLAG(EADC, (0x1 << 4)))
- g_u32AdcCmp0IntFlag = 1;
- EADC_CLR_INT_FLAG(EADC, (0x1 << 4));/* Clear the A/D compare flag 0 */
- if(EADC_GET_INT_FLAG(EADC, (0x1 << 5)))
- g_u32AdcCmp1IntFlag = 1;
- EADC_CLR_INT_FLAG(EADC, (0x1 << 5));/* Clear the A/D compare flag 1 */
- /* Main Function */
- /* Unlock protected registers */
- SYS_UnlockReg();
- /* Init System, IP clock and multi-function I/O */
- SYS_Init();
- /* Lock protected registers */
- SYS_LockReg();
- /* Init UART0 for printf */
- UART0_Init();
- /* SAMPLE CODE */
- printf("\nSystem clock rate: %d Hz", SystemCoreClock);
- EADC_FunctionTest();
- /* Reset EADC module */
- SYS_ResetModule(EADC_RST);
- /* Disable EADC IP clock */
- CLK_DisableModuleClock(EADC_MODULE);
- /* Disable External Interrupt */
- NVIC_DisableIRQ(ADC00_IRQn);
- printf("Exit EADC sample code\n");
- while(1);
