- * @file main.c
- * @version V1.00
- * $Revision: 9 $
- * $Date: 15/10/06 11:24a $
- * @brief This is a starter kit sample enables all peripherals on learning
- * board. Peripherals enabled are UART, SPI, I2C, Timer, ADC, and PWM
- * @note
- * Copyright (C) 2013 Nuvoton Technology Corp. All rights reserved.
- #include <stdio.h>
- #include "Mini51Series.h"
- #include "lcd_driver.h"
- #include "eeprom_24lc64.h"
- void Delay(int32_t ms)
- int32_t i;
- for(i=0; i<ms; i++)
- CLK_SysTickDelay(1000);
- void EINT0_IRQHandler(void)
- P3->ISRC = 1 << 2;
- /* Toggle PWM3 enable/disable */
- PWM->POE |= PWM_POE_PWM3_Msk;
- printf("EINT0 Interrupt!\n");
- void TMR0_IRQHandler(void)
- /* Clear Interrupt */
- TIMER0->TISR = 1;
- void ADC_Init(void)
- /*reset ADC */
- SYS->IPRSTC2 |= SYS_IPRSTC2_ADC_RST_Msk;
- SYS->IPRSTC2 &= (~SYS_IPRSTC2_ADC_RST_Msk);
- /* ADC clock source */
- CLK->CLKSEL1 &= (~CLK_CLKSEL1_ADC_S_Msk);
- CLK->CLKSEL1 |= CLK_CLKSEL1_ADC_S_XTAL;
- /* Set ADC divisor */
- CLK->CLKDIV &= (~CLK_CLKDIV_ADC_N_Msk);
- CLK->CLKDIV |= CLK_CLKDIV_ADC(3);
- /* ADC engine clock enable */
- CLK->APBCLK |= CLK_APBCLK_ADC_EN_Msk;
- /* ADC enable */
- ADC_POWER_ON(ADC);
- void PWM_Init(void)
- CLK->APBCLK |= (CLK_APBCLK_PWM01_EN_Msk | CLK_APBCLK_PWM23_EN_Msk | CLK_APBCLK_PWM45_EN_Msk) ;
- SYS->IPRSTC2 |= SYS_IPRSTC2_PWM_RST_Msk;
- SYS->IPRSTC2 &= (~SYS_IPRSTC2_PWM_RST_Msk);
- /* PWM Timer0: Clk = HCLK / 120 / 16, Freq = clk / 6250, duty cycle = 3125/6250 % */
- /* PWM Timer1: Clk = HCLK / 120 / 16, Freq = clk / 3125, duty cycle = 1563/3125 % */
- /* PWM Timer2: Clk = HCLK / 60 / 16, Freq = clk / 3125, duty cycle = 1563/3125 % */
- /* PWM Timer3: Clk = HCLK / 60 / 1, Freq = clk / 50, duty cycle = 25/50 % */
- /* PWM0 = 12000000 / 120 / 16 / 6250 = 1Hz */
- /* PWM1 = 12000000 / 120 / 16 / 3125 = 2Hz */
- /* PWM2 = 12000000 / 60 / 16 / 3125 = 4Hz */
- /* PWM3 = 12000000 / 60 / 1 / 50 = 4000Hz */
- PWM_ConfigOutputChannel(PWM,0,1,50);
- PWM_ConfigOutputChannel(PWM,1,1,50);
- PWM_ConfigOutputChannel(PWM,2,1,50);
- PWM_ConfigOutputChannel(PWM,3,1,50);
- PWM_EnableOutput(PWM,0xF);
- PWM_Start(PWM,0xF);
- SYS->P2_MFP &= ~(SYS_MFP_P22_Msk | SYS_MFP_P23_Msk | SYS_MFP_P24_Msk | SYS_MFP_P25_Msk);
- SYS->P2_MFP |= (SYS_MFP_P22_PWM0| SYS_MFP_P23_PWM1| SYS_MFP_P24_PWM2| SYS_MFP_P25_PWM3) ;
- void TMR0_Init(void)
- TIMER_EnableInt(TIMER0);
- TIMER_SET_PRESCALE_VALUE(TIMER0,11); // 12MHz / (11+1) / 100000 = 10Hz
- TIMER_Start(TIMER0);
- TIMER_SET_CMP_VALUE(TIMER0,100000);
- NVIC_EnableIRQ(TMR0_IRQn);
- void EINT0_Init(void)
- /* Debounce function control */
- GPIO->DBNCECON = GPIO_DBNCECON_ICLK_ON | GPIO_DBNCECON_DBCLKSRC_HCLK | GPIO_DBNCECON_DBCLKSEL_32768;
- GPIO_ENABLE_DEBOUNCE(P3,1<<2);
- /* Configure external interrupt */
- GPIO_EnableInt(P3, 2, GPIO_INT_FALLING);
- NVIC_EnableIRQ(EINT0_IRQn);
- void I2C_Init(void)
- /* Enable I2C */
- CLK->APBCLK |= CLK_APBCLK_I2C_EN_Msk ;
- SYS->IPRSTC2 |= SYS_IPRSTC2_I2C_RST_Msk;
- SYS->IPRSTC2 &= (~SYS_IPRSTC2_I2C_RST_Msk);
- I2C->I2CON = I2C_I2CON_ENSI_Msk ;
- void SYS_Init(void)
- /* Init System Clock */
- /* Unlock protected registers */
- SYS_UnlockReg();
- /* Set P5.0 and P5.1 -> XTAL */
- SYS->P5_MFP &= ~(SYS_MFP_P50_Msk | SYS_MFP_P51_Msk);
- SYS->P5_MFP |= (SYS_MFP_P50_XTAL1 | SYS_MFP_P51_XTAL2);
- /* Enable external 12MHz XTAL, internal 22.1184MHz */
- CLK->PWRCON = (CLK->PWRCON & ~CLK_PWRCON_XTLCLK_EN_Msk) | CLK_PWRCON_XTL12M;
- CLK_SysTickDelay(12000);
- /* Waiting for clock ready */
- CLK_WaitClockReady(CLK_CLKSTATUS_XTL_STB_Msk);
- /* Switch HCLK clock source to XTL, STCLK to XTL */
- CLK->CLKSEL0 = (CLK->CLKSEL0 & ~CLK_CLKSEL0_HCLK_S_Msk) | CLK_CLKSEL0_HCLK_S_XTAL;
- /* Enable IP clock */
- CLK->APBCLK = CLK_APBCLK_UART_EN_Msk;
- /* IP clock source */
- CLK->CLKSEL1 = ( CLK->CLKSEL1 & (~CLK_CLKSEL1_UART_S_Msk) ) | CLK_CLKSEL1_UART_S_XTAL;
- /* Update System Core Clock */
- /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
- SystemCoreClockUpdate();
- /* Init I/O Multi-function */
- /* Set P0 multi-function pins for UART RXD and TXD */
- SYS->P0_MFP &= ~(SYS_MFP_P00_Msk | SYS_MFP_P01_Msk);
- SYS->P0_MFP |= (SYS_MFP_P00_TXD | SYS_MFP_P01_RXD);
- /* Set P3.4 and P3.5 for I2C SDA and SCL */
- SYS->P3_MFP = SYS_MFP_P34_SDA | SYS_MFP_P35_SCL;
- /* Lock protected registers */
- SYS_LockReg();
- void UART_Init(void)
- /* Init UART */
- UART_Open(UART, 115200);
- /* MAIN function */
- int main(void)
- uint32_t u32Counter = 0, u32AdcData = 0, u32I2cData;
- char AdcValue[15] = "ADC Value:";
- char strClearAdcValue[15] = "ADC Value: ";
- /* Init System, IP clock and multi-function I/O */
- SYS_Init();
- /* Init UART for printf */
- UART_Init();
- /* Init Other peripherals */
- LCD_Init();
- /* Initialize I2C */
- I2C_Init();
- EEPROM_Init();
- TMR0_Init();
- /* Initialize ADC */
- ADC_Init();
- /* Initialize PWM */
- PWM_Init();
- StartKit is used to demo Nu-LB_004 learning board. This sample will test EEPROM, SPI Flash read/write by
- I2C, SPI. And test LED by GPIO and PWM. Test KEY by EINT0. Use ADC to convert the voltage of
- variable resistor by AD0. Generate 4kHz key sound by buzzer with PWM. LCD display is enabled to show working
- message. CPU will be idle by __WFI() when a loop has been done. Timer events (every 100ms) or key events are
- used to wakeup CPU to execute next loop.
- LCD_EnableBackLight();
- LCD_ClearScreen();
- printf("CPU [url=home.php?mod=space&uid=72445]@[/url] %dHz\n", SystemCoreClock);
- // SPI test
- LCD_Print(0, "Welcome! Nuvoton");
- LCD_Print(1, "This is LB test ");
- /*Initialize external interrupt*/
- EINT0_Init();
- while (1) {
- if(u32Counter > 8) {
- /* Disable Buzzer */
- PWM->POE &= ~PWM_POE_PWM3_Msk;
- printf("\nTest time: %d\n", u32Counter++);
- /* LED test */
- P2->DOUT=u32Counter;
- /* ADC test */
- ADC->ADSR = ( ADC->ADSR & (~ADC_ADSR_CHANNEL_Msk) ) | ADC_ADSR_ADF_Msk;
- ADC->ADCR |= ADC_ADCR_ADST_Msk;
- while(!(ADC->ADSR & ADC_ADSR_ADF_Msk));
- u32AdcData = ADC->ADDR & 0xFFFUL;
- printf("ADC value: %d\n", u32AdcData);
- sprintf((char *)AdcValue + 10, "%d", u32AdcData);
- LCD_Print(3, strClearAdcValue);
- LCD_Print(3, AdcValue);
- /* Single end, single mode, start convert */
- ADC->ADCR = ADC_ADCR_ADEN_Msk | ADC_ADCR_ADST_Msk;
- /*I2C test*/
- u32AdcData = (u32Counter + u32AdcData) & 0xff;
- EEPROM_Write(u32Counter,u32AdcData);
- u32I2cData = EEPROM_Read(u32Counter);
- if (u32I2cData != u32AdcData) {
- LCD_Print(2, "I2C fail ");
- while (1);
- printf("I2C address:0x%x, Data:0x%x\n", u32Counter, u32I2cData);
