- * [url=home.php?mod=space&uid=288409]@file[/url] main.c
- * [url=home.php?mod=space&uid=895143]@version[/url] V2.00
- * $Revision: 6 $
- * $Date: 15/05/22 2:52p $
- * @brief Change system clock to different PLL frequency and output system clock from CLKO pin.
- * @note
- * Copyright (C) 2011 Nuvoton Technology Corp. All rights reserved.
- #include <stdio.h>
- #include "M051Series.h"
- #define PLL_CLOCK 50000000
- #define SIGNATURE 0x125ab234
- #define FLAG_ADDR 0x20000FFC
- /* Brown Out Detector IRQ Handler */
- void BOD_IRQHandler(void)
- /* Clear BOD Interrupt Flag */
- SYS_CLEAR_BOD_INT_FLAG();
- printf("Brown Out is Detected\n");
- /* Simple calculation test function */
- #define PI_NUM 256
- int32_t f[PI_NUM + 1];
- uint32_t piTbl[19] =
- 3141,
- 5926,
- 5358,
- 9793,
- 2384,
- 6264,
- 3383,
- 2795,
- 288,
- 4197,
- 1693,
- 9937,
- 5105,
- 8209,
- 7494,
- 4592,
- 3078,
- 1640,
- 6284
- int32_t piResult[19];
- int32_t pi(void)
- int32_t i, i32Err;
- int32_t a = 10000, b = 0, c = PI_NUM, d = 0, e = 0, g = 0;
- for(; b - c;)
- f[b++] = a / 5;
- i = 0;
- for(; d = 0, g = c * 2; c -= 14,/*printf("%.4d\n",e+d/a),*/ piResult[i++] = e + d / a, e = d % a)
- if(i == 19)
- break;
- for(b = c; d += f[b] * a, f[b] = d % --g, d /= g--, --b; d *= b);
- i32Err = 0;
- for(i = 0; i < 19; i++)
- if(piTbl[i] != piResult[i])
- i32Err = -1;
- return i32Err;
- void Delay(uint32_t x)
- int32_t i;
- for(i = 0; i < x; i++)
- __NOP();
- __NOP();
- uint32_t g_au32PllSetting[] =
- CLK_PLLCON_PLL_SRC_HXT | CLK_PLLCON_NR(3) | CLK_PLLCON_NF(25) | CLK_PLLCON_NO_4, /* PLL = 25MHz */
- CLK_PLLCON_PLL_SRC_HXT | CLK_PLLCON_NR(3) | CLK_PLLCON_NF(29) | CLK_PLLCON_NO_4, /* PLL = 29MHz */
- CLK_PLLCON_PLL_SRC_HXT | CLK_PLLCON_NR(3) | CLK_PLLCON_NF(33) | CLK_PLLCON_NO_4, /* PLL = 33MHz */
- CLK_PLLCON_PLL_SRC_HXT | CLK_PLLCON_NR(3) | CLK_PLLCON_NF(37) | CLK_PLLCON_NO_4, /* PLL = 37MHz */
- CLK_PLLCON_PLL_SRC_HXT | CLK_PLLCON_NR(3) | CLK_PLLCON_NF(41) | CLK_PLLCON_NO_4, /* PLL = 41MHz */
- CLK_PLLCON_PLL_SRC_HXT | CLK_PLLCON_NR(3) | CLK_PLLCON_NF(45) | CLK_PLLCON_NO_4, /* PLL = 45MHz */
- CLK_PLLCON_PLL_SRC_HXT | CLK_PLLCON_NR(3) | CLK_PLLCON_NF(49) | CLK_PLLCON_NO_4 /* PLL = 49MHz */
- void SYS_PLL_Test(void)
- int32_t i;
- /* PLL clock configuration test */
- printf("\n-------------------------[ Test PLL ]-----------------------------\n");
- for(i = 0; i < sizeof(g_au32PllSetting) / sizeof(g_au32PllSetting[0]) ; i++)
- /* Switch HCLK clock source to HXT and HCLK source divide 1 */
- CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HXT, CLK_CLKDIV_HCLK(1));
- /* Set PLL to power down mode and PLL_STB bit in CLKSTATUS register will be cleared by hardware. */
- CLK_DisablePLL();
- /* Set PLL frequency */
- CLK->PLLCON = g_au32PllSetting[i];
- /* Waiting for PLL clock ready */
- CLK_WaitClockReady(CLK_CLKSTATUS_PLL_STB_Msk);
- /* Switch HCLK clock source to PLL */
- CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_PLL, CLK_CLKDIV_HCLK(1));
- printf(" Change system clock to %d Hz ...................... ", SystemCoreClock);
- /* Output selected clock to CKO, CKO Clock = HCLK / 2^(1 + 1) */
- CLK_EnableCKO(CLK_CLKSEL2_FRQDIV_S_HCLK, 1, 0);
- /* The delay loop is used to check if the CPU speed is increasing */
- Delay(0x400000);
- if(pi())
- printf("[FAIL]\n");
- else
- printf("[OK]\n");
- /* Disable CKO clock */
- CLK_DisableCKO();
- void SYS_Init(void)
- /* Init System Clock */
- /* Enable Internal RC 22.1184MHz clock */
- CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
- /* Waiting for Internal RC clock ready */
- CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
- /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
- CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
- /* Enable external XTAL 12MHz clock */
- CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
- /* Waiting for external XTAL clock ready */
- CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
- /* Set core clock as PLL_CLOCK from PLL */
- CLK_SetCoreClock(PLL_CLOCK);
- /* Enable UART module clock */
- CLK_EnableModuleClock(UART0_MODULE);
- /* Select UART module clock source */
- CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
- /* Init I/O Multi-function */
- /* Set P3 multi-function pins for UART0 RXD , TXD and CKO */
- SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk | SYS_MFP_P36_Msk);
- SYS->P3_MFP |= (SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0 | SYS_MFP_P36_CKO);
- void UART0_Init(void)
- /* Init UART */
- /* Reset UART0 */
- SYS_ResetModule(UART0_RST);
- /* Configure UART0 and set UART0 Baudrate */
- UART_Open(UART0, 115200);
- /* Main Function */
- int32_t main(void)
- uint32_t u32data;
- /* If define INIT_SYSCLK_AT_BOOTING in system_M051Series.h, HCLK will be set to 50MHz in SystemInit(void). */
- /* In end of main function, program issued CPU reset and write-protection will be disabled. */
- if(SYS_IsRegLocked() == 0)
- SYS_LockReg();
- /* Unlock protected registers */
- SYS_UnlockReg();
- /* Init System, peripheral clock and multi-function I/O */
- SYS_Init();
- /* Lock protected registers */
- SYS_LockReg();
- /* Init UART0 for printf */
- UART0_Init();
- printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %dHz\n", SystemCoreClock);
- This sample code will show some function about system manager controller and clock controller:
- 1. Read PDID
- 2. Get and clear reset source
- 3. Setting about BOD
- 4. Change system clock depended on different PLL settings
- 5. Output system clock from CKO pin, and the output frequency = system clock / 4
- printf("+---------------------------------------+\n");
- printf("| M05xx System Driver Sample Code |\n");
- if(M32(FLAG_ADDR) == SIGNATURE)
- printf(" CPU Reset success!\n");
- M32(FLAG_ADDR) = 0;
- printf(" Press any key to continue ...\n");
- getchar();
- /* Misc system function test */
- /* Read Part Device ID */
- printf("Product ID 0x%x\n", SYS_ReadPDID());
- /* Get reset source from last operation */
- u32data = SYS_GetResetSrc();
- printf("Reset Source 0x%x\n", u32data);
- /* Clear reset source */
- SYS_ClearResetSrc(u32data);
- /* Unlock protected registers for Brown-Out Detector settings */
- SYS_UnlockReg();
- /* Check if the write-protected registers are unlocked before BOD setting and CPU Reset */
- printf("Protected Address is Unlocked\n");
- /* Enable Brown-Out Detector, and set Brown-Out Detector voltage 2.7V */
- SYS_EnableBOD(SYS_BODCR_BOD_INTERRUPT_EN, SYS_BODCR_BOD_VL_2_7V);
- /* Enable BOD IRQ */
- NVIC_EnableIRQ(BOD_IRQn);
- /* Enable Low Voltage Reset function */
- SYS_ENABLE_LVR();
- /* Run PLL Test */
- SYS_PLL_Test();
- /* Write a signature work to SRAM to check if it is reset by software */
- M32(FLAG_ADDR) = SIGNATURE;
- printf("\n\n >>> Reset CPU <<<\n");
- /* Waiting for message send out */
- UART_WAIT_TX_EMPTY(UART0);
- /* Switch HCLK clock source to Internal RC 22.1184MHz clock and HCLK source divide 1 */
- /* Set PLL to Power down mode and HW will also clear PLL_STB bit in CLKSTATUS register */
- CLK_DisablePLL();
- /* Reset CPU */
- SYS_ResetCPU();
