RX8 串行接收器接收不到数据?
 楼主| zj.ok 发表于 2017-4-13 11:11 | 显示全部楼层 |阅读模式
#include <m8c.h>        // part specific constants and macros
#include "PSoCAPI.h"    // PSoC API definitions for all User Modules
#include "RX8.h"
BOOL fWaitToReceiveByte(void)
    BYTE bRxStatus;
    /* Wait to receive full byte*/
    while ( !( bRxStatus=RX8_bReadRxStatus() & RX8_RX_COMPLETE ) )
        /* might want to sleep or keep track of time */
    /* data received, now check for errors */
    if (( bRxStatus & RX8_RX_NO_ERROR ) == 0 )
        /* no error detected */
        bRxData = RX8_bReadRxData();
        return( TRUE );
    else
        /* error detected */
        bRxData = bRxStatus;
        return( FALSE );
void main(void)
 楼主| zj.ok 发表于 2017-4-13 17:44 | 显示全部楼层
补充一下,数据可以接受到,但是数据不对,是波特率问题吗?
