[conipaddr.c] "D:\ti1\c6000\cgtools\bin\cl6x" -g -q -o2 -fr"D:/ti1/ti/ndk/example/network/client/evmdm642/debug" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/inc" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/lib" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/example/tools" -i"D:/ti1/boards/evmdm642/include" -d"CHIP_DM642" -d"_INCLUDE_NIMU_CODE" -d"_INCLUDE_IPv6_CODE" -d"_NDK_EXTERN_CONFIG" -mv6400 -@"../../../network/client/evmdm642/Custom.lkf" "conipaddr.c"
"conipaddr.c", line 20: fatal error: could not open source file "netmain.h"
1 fatal error detected in the compilation of "conipaddr.c".
Compilation terminated.
[conipv6.c] "D:\ti1\c6000\cgtools\bin\cl6x" -g -q -o2 -fr"D:/ti1/ti/ndk/example/network/client/evmdm642/debug" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/inc" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/lib" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/example/tools" -i"D:/ti1/boards/evmdm642/include" -d"CHIP_DM642" -d"_INCLUDE_NIMU_CODE" -d"_INCLUDE_IPv6_CODE" -d"_NDK_EXTERN_CONFIG" -mv6400 -@"../../../network/client/evmdm642/Custom.lkf" "conipv6.c"
"conipv6.c", line 15: fatal error: could not open source file "netmain.h"
1 fatal error detected in the compilation of "conipv6.c".
[conlli.c] "D:\ti1\c6000\cgtools\bin\cl6x" -g -q -o2 -fr"D:/ti1/ti/ndk/example/network/client/evmdm642/debug" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/inc" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/lib" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/example/tools" -i"D:/ti1/boards/evmdm642/include" -d"CHIP_DM642" -d"_INCLUDE_NIMU_CODE" -d"_INCLUDE_IPv6_CODE" -d"_NDK_EXTERN_CONFIG" -mv6400 -@"../../../network/client/evmdm642/Custom.lkf" "conlli.c"
"conlli.c", line 19: fatal error: could not open source file "netmain.h"
1 fatal error detected in the compilation of "conlli.c".
[conping.c] "D:\ti1\c6000\cgtools\bin\cl6x" -g -q -o2 -fr"D:/ti1/ti/ndk/example/network/client/evmdm642/debug" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/inc" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/lib" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/example/tools" -i"D:/ti1/boards/evmdm642/include" -d"CHIP_DM642" -d"_INCLUDE_NIMU_CODE" -d"_INCLUDE_IPv6_CODE" -d"_NDK_EXTERN_CONFIG" -mv6400 -@"../../../network/client/evmdm642/Custom.lkf" "conping.c"
"conping.c", line 19: fatal error: could not open source file "netmain.h"
1 fatal error detected in the compilation of "conping.c".
[conroute.c] "D:\ti1\c6000\cgtools\bin\cl6x" -g -q -o2 -fr"D:/ti1/ti/ndk/example/network/client/evmdm642/debug" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/inc" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/lib" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/example/tools" -i"D:/ti1/boards/evmdm642/include" -d"CHIP_DM642" -d"_INCLUDE_NIMU_CODE" -d"_INCLUDE_IPv6_CODE" -d"_NDK_EXTERN_CONFIG" -mv6400 -@"../../../network/client/evmdm642/Custom.lkf" "conroute.c"
"conroute.c", line 20: fatal error: could not open source file "netmain.h"
1 fatal error detected in the compilation of "conroute.c".
[consock.c] "D:\ti1\c6000\cgtools\bin\cl6x" -g -q -o2 -fr"D:/ti1/ti/ndk/example/network/client/evmdm642/debug" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/inc" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/lib" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/example/tools" -i"D:/ti1/boards/evmdm642/include" -d"CHIP_DM642" -d"_INCLUDE_NIMU_CODE" -d"_INCLUDE_IPv6_CODE" -d"_NDK_EXTERN_CONFIG" -mv6400 -@"../../../network/client/evmdm642/Custom.lkf" "consock.c"
"consock.c", line 20: fatal error: could not open source file "netmain.h"
1 fatal error detected in the compilation of "consock.c".
[console.c] "D:\ti1\c6000\cgtools\bin\cl6x" -g -q -o2 -fr"D:/ti1/ti/ndk/example/network/client/evmdm642/debug" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/inc" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/lib" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/example/tools" -i"D:/ti1/boards/evmdm642/include" -d"CHIP_DM642" -d"_INCLUDE_NIMU_CODE" -d"_INCLUDE_IPv6_CODE" -d"_NDK_EXTERN_CONFIG" -mv6400 -@"../../../network/client/evmdm642/Custom.lkf" "console.c"
"console.c", line 19: fatal error: could not open source file "netmain.h"
1 fatal error detected in the compilation of "console.c".
[constat.c] "D:\ti1\c6000\cgtools\bin\cl6x" -g -q -o2 -fr"D:/ti1/ti/ndk/example/network/client/evmdm642/debug" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/inc" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/lib" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/example/tools" -i"D:/ti1/boards/evmdm642/include" -d"CHIP_DM642" -d"_INCLUDE_NIMU_CODE" -d"_INCLUDE_IPv6_CODE" -d"_NDK_EXTERN_CONFIG" -mv6400 -@"../../../network/client/evmdm642/Custom.lkf" "constat.c"
"constat.c", line 20: fatal error: could not open source file "netmain.h"
1 fatal error detected in the compilation of "constat.c".
[contest.c] "D:\ti1\c6000\cgtools\bin\cl6x" -g -q -o2 -fr"D:/ti1/ti/ndk/example/network/client/evmdm642/debug" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/inc" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/lib" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/example/tools" -i"D:/ti1/boards/evmdm642/include" -d"CHIP_DM642" -d"_INCLUDE_NIMU_CODE" -d"_INCLUDE_IPv6_CODE" -d"_NDK_EXTERN_CONFIG" -mv6400 -@"../../../network/client/evmdm642/Custom.lkf" "contest.c"
"contest.c", line 19: fatal error: could not open source file "netmain.h"
1 fatal error detected in the compilation of "contest.c".
[contftp.c] "D:\ti1\c6000\cgtools\bin\cl6x" -g -q -o2 -fr"D:/ti1/ti/ndk/example/network/client/evmdm642/debug" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/inc" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/lib" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/example/tools" -i"D:/ti1/boards/evmdm642/include" -d"CHIP_DM642" -d"_INCLUDE_NIMU_CODE" -d"_INCLUDE_IPv6_CODE" -d"_NDK_EXTERN_CONFIG" -mv6400 -@"../../../network/client/evmdm642/Custom.lkf" "contftp.c"
"contftp.c", line 20: fatal error: could not open source file "netmain.h"
1 fatal error detected in the compilation of "contftp.c".
[convlan.c] "D:\ti1\c6000\cgtools\bin\cl6x" -g -q -o2 -fr"D:/ti1/ti/ndk/example/network/client/evmdm642/debug" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/inc" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/lib" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/example/tools" -i"D:/ti1/boards/evmdm642/include" -d"CHIP_DM642" -d"_INCLUDE_NIMU_CODE" -d"_INCLUDE_IPv6_CODE" -d"_NDK_EXTERN_CONFIG" -mv6400 -@"../../../network/client/evmdm642/Custom.lkf" "convlan.c"
"convlan.c", line 19: fatal error: could not open source file "netmain.h"
1 fatal error detected in the compilation of "convlan.c".
[datasrv.c] "D:\ti1\c6000\cgtools\bin\cl6x" -g -q -o2 -fr"D:/ti1/ti/ndk/example/network/client/evmdm642/debug" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/inc" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/lib" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/example/tools" -i"D:/ti1/boards/evmdm642/include" -d"CHIP_DM642" -d"_INCLUDE_NIMU_CODE" -d"_INCLUDE_IPv6_CODE" -d"_NDK_EXTERN_CONFIG" -mv6400 -@"../../../network/client/evmdm642/Custom.lkf" "datasrv.c"
"datasrv.c", line 17: fatal error: could not open source file "netmain.h"
1 fatal error detected in the compilation of "datasrv.c".
[echosrv.c] "D:\ti1\c6000\cgtools\bin\cl6x" -g -q -o2 -fr"D:/ti1/ti/ndk/example/network/client/evmdm642/debug" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/inc" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/lib" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/example/tools" -i"D:/ti1/boards/evmdm642/include" -d"CHIP_DM642" -d"_INCLUDE_NIMU_CODE" -d"_INCLUDE_IPv6_CODE" -d"_NDK_EXTERN_CONFIG" -mv6400 -@"../../../network/client/evmdm642/Custom.lkf" "echosrv.c"
"echosrv.c", line 14: fatal error: could not open source file "netmain.h"
1 fatal error detected in the compilation of "echosrv.c".
[newservers.c] "D:\ti1\c6000\cgtools\bin\cl6x" -g -q -o2 -fr"D:/ti1/ti/ndk/example/network/client/evmdm642/debug" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/inc" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/lib" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/example/tools" -i"D:/ti1/boards/evmdm642/include" -d"CHIP_DM642" -d"_INCLUDE_NIMU_CODE" -d"_INCLUDE_IPv6_CODE" -d"_NDK_EXTERN_CONFIG" -mv6400 -@"../../../network/client/evmdm642/Custom.lkf" "newservers.c"
"newservers.c", line 29: fatal error: could not open source file "netmain.h"
1 fatal error detected in the compilation of "newservers.c".
[nullsrv.c] "D:\ti1\c6000\cgtools\bin\cl6x" -g -q -o2 -fr"D:/ti1/ti/ndk/example/network/client/evmdm642/debug" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/inc" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/lib" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/example/tools" -i"D:/ti1/boards/evmdm642/include" -d"CHIP_DM642" -d"_INCLUDE_NIMU_CODE" -d"_INCLUDE_IPv6_CODE" -d"_NDK_EXTERN_CONFIG" -mv6400 -@"../../../network/client/evmdm642/Custom.lkf" "nullsrv.c"
"nullsrv.c", line 17: fatal error: could not open source file "netmain.h"
1 fatal error detected in the compilation of "nullsrv.c".
[oobsrv.c] "D:\ti1\c6000\cgtools\bin\cl6x" -g -q -o2 -fr"D:/ti1/ti/ndk/example/network/client/evmdm642/debug" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/inc" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/lib" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/example/tools" -i"D:/ti1/boards/evmdm642/include" -d"CHIP_DM642" -d"_INCLUDE_NIMU_CODE" -d"_INCLUDE_IPv6_CODE" -d"_NDK_EXTERN_CONFIG" -mv6400 -@"../../../network/client/evmdm642/Custom.lkf" "oobsrv.c"
"oobsrv.c", line 20: fatal error: could not open source file "netmain.h"
1 fatal error detected in the compilation of "oobsrv.c".
[client.c] "D:\ti1\c6000\cgtools\bin\cl6x" -g -q -o2 -fr"D:/ti1/ti/ndk/example/network/client/evmdm642/debug" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/inc" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/lib" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/example/tools" -i"D:/ti1/boards/evmdm642/include" -d"CHIP_DM642" -d"_INCLUDE_NIMU_CODE" -d"_INCLUDE_IPv6_CODE" -d"_NDK_EXTERN_CONFIG" -mv6400 -@"../evmdm642/Custom.lkf" "client.c"
"client.c", line 26: fatal error: could not open source file "netmain.h"
1 fatal error detected in the compilation of "client.c".
[webpage.c] "D:\ti1\c6000\cgtools\bin\cl6x" -g -q -o2 -fr"D:/ti1/ti/ndk/example/network/client/evmdm642/debug" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/inc" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/lib" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/example/tools" -i"D:/ti1/boards/evmdm642/include" -d"CHIP_DM642" -d"_INCLUDE_NIMU_CODE" -d"_INCLUDE_IPv6_CODE" -d"_NDK_EXTERN_CONFIG" -mv6400 -@"../evmdm642/Custom.lkf" "webpage.c"
"webpage.c", line 23: fatal error: could not open source file "netmain.h"
1 fatal error detected in the compilation of "webpage.c".
[dm642init.c] "D:\ti1\c6000\cgtools\bin\cl6x" -g -q -o2 -fr"D:/ti1/ti/ndk/example/network/client/evmdm642/debug" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/inc" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/lib" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/example/tools" -i"D:/ti1/boards/evmdm642/include" -d"CHIP_DM642" -d"_INCLUDE_NIMU_CODE" -d"_INCLUDE_IPv6_CODE" -d"_NDK_EXTERN_CONFIG" -mv6400 -@"Custom.lkf" "dm642init.c"
"dm642init.c", line 26: fatal error: could not open source file "netmain.h"
1 fatal error detected in the compilation of "dm642init.c".
[evmdm642cfg.s62] "D:\ti1\c6000\cgtools\bin\cl6x" -g -q -o2 -fr"D:/ti1/ti/ndk/example/network/client/evmdm642/debug" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/inc" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/lib" -i"%NDK_INSTALL_DIR%/packages/ti/ndk/example/tools" -i"D:/ti1/boards/evmdm642/include" -d"CHIP_DM642" -d"_INCLUDE_NIMU_CODE" -d"_INCLUDE_IPv6_CODE" -d"_NDK_EXTERN_CONFIG" -mv6400 -@"Custom.lkf" "evmdm642cfg.s62"
"evmdm642cfg.s62", ERROR! at line 19: [E1000] Include/Copy file not found or
opened
.include client_evmDM642_x64cfg.h62
"evmdm642cfg.s62", ERROR! at line 27: [E1000] Include/Copy file not found or
opened
.include pool.h62
00H,00H,02H,%g inst,%g inst,%.2f inst,_filtmaxmult,_filtsummult,_unittype
"evmdm642cfg.s62", ERROR! at line 1000: [E0003] Invalid constant specification
.word 00H,00H,02H,%g inst,%g inst,%.2f inst,_filtmaxmult,_filtsummult,_unittype
"evmdm642cfg.s62", ERROR! at line 1039: [ ***** USER ERROR ***** - ]
LOG_Obj: argument 'circular,_iType,_iFormat' is not a member of
{circular,fixed}
.emsg "LOG_Obj: argument 'circular,_iType,_iFormat' is not a member of {circular,fixed}"
LOG_Obj mode error.
.emsg "LOG_Obj mode error."
"evmdm642cfg.s62", ERROR! at line 1057: [ ***** USER ERROR ***** - ]
STS_Obj was passed too many parameters.
.emsg "STS_Obj was passed too many parameters."
.if (DEV$NUMDEVICES > 0) ; expand only if devices are configured.
"evmdm642cfg.s62", ERROR! at line 1200: [E0002] Illegal mnemonic specified
MSGQ_end
"evmdm642cfg.s62", ERROR! at line 1201: [E0200] Operation cannot be performed
on given operands
.if (HOOK$ == 1)
