有关DSP2407 FLASH烧写不进去问题
 楼主| shangken 发表于 2010-6-24 17:12 | 显示全部楼层 |阅读模式
前面提到锁芯片的事情,我已经解决了,现在又出现的一个问题是FLASH写不进去,就最前的清零也不行,下面是提示错误:
OK: FLASH Algorithm loaded into DSP MEMORY
OK: Write sector VALUE 0x0001 to symbol PRG_options
OK: Set Breakpoint at PRG_stop
OK: Running FLASH algorithm
OK: DSP Halted
OK: Read status VALUE 0x0000 from symbol PRG_status
OK: PC set to PRG_erase
OK: DSP Halted
Error: Read status VALUE 0x0001 from symbol PRG_status
FLASH algorithm failed during clear operation
大家帮忙看一下,这到底是什么问题,谢谢!!!!
