芯唐能否提供如下函数的源代码?
 楼主| 无冕之王 发表于 2010-7-3 09:09 | 显示全部楼层 |阅读模式
我现在用了W90P710,代理商提供了一些设计文档,但都是用ADS设计的。现在我要使用keil来移植芯唐许多已经设计好了的源文件,但现在遇到了困难,就是如下的一些函数,我没有它的源代码,移植没法进行。
    我觉得这些函数的源文件应该不属于十分机密的内容,所以请哪位能否慷慨大方的给小弟一份资料,不胜感激!
/* Define system library Timer functions */
UINT32 sysGetTicks (INT32 nTimeNo);
INT32 sysResetTicks (INT32 nTimeNo);
INT32 sysUpdateTickCount(INT32 nTimeNo, UINT32 uCount);
INT32 sysSetTimerReferenceClock (UINT32 nTimeNo, UINT32 uClockRate);
INT32 sysStartTimer (INT32 nTimeNo, UINT32 uTicksPerSecond, INT32 nOpMode);
INT32 sysStopTimer (INT32 nTimeNo);
VOID sysClearWatchDogTimerCount (VOID);
VOID sysClearWatchDogTimerInterruptStatus(VOID);
VOID sysDisableWatchDogTimer (VOID);
VOID sysDisableWatchDogTimerReset(VOID);
VOID sysEnableWatchDogTimer (VOID);
VOID sysEnableWatchDogTimerReset(VOID);
PVOID sysInstallWatchDogTimerISR (INT32 nIntTypeLevel, PVOID pvNewISR);
INT32 sysSetWatchDogTimerInterval (INT32 nWdtInterval);
INT32 sysSetTimerEvent(UINT32 nTimeNo, UINT32 nTimeTick, PVOID pvFun);
VOID sysClearTimerEvent(UINT32 nTimeNo, UINT32 nTimeEventNo);
VOID sysSetLocalTime(DateTime_T ltime);
VOID sysGetCurrentTime(DateTime_T *curTime);
VOID sysDelay(UINT32 uTicks);
/* Define system library UART functions */
INT8 sysGetChar(VOID);
INT32 sysInitializeUART(WB_UART_T *uart);
VOID sysPrintf(PINT8 pcStr,...);
VOID sysprintf(PINT8 pcStr,...);
VOID sysPutChar(UINT8 ch);
/* Define system library AIC functions */
INT32 sysDisableInterrupt (UINT32 intNo);
INT32 sysEnableInterrupt (UINT32 intNo);
PVOID sysInstallExceptionHandler (INT32 exceptType, PVOID pNewHandler);
PVOID sysInstallFiqHandler (PVOID pNewISR);
PVOID sysInstallIrqHandler (PVOID pNewISR);
PVOID sysInstallISR (INT32 intTypeLevel, INT32 intNo, PVOID pNewISR, PVOID pParam);
INT32 sysSetGlobalInterrupt (INT32 intState);
INT32 sysSetInterruptPriorityLevel (UINT32 intNo, UINT32 intLevel);
INT32 sysSetInterruptType (UINT32 intNo, UINT32 intSourceType);
INT32 sysSetLocalInterrupt (INT32 intState);
INT32 sysSetAIC2SWMode(VOID);
UINT32 sysGetInterruptEnableStatus(VOID);
/* Define system library Cache functions */
VOID sysEnableCache(VOID);
VOID sysDisableCache(VOID);
VOID sysFlushCache(INT32 cacheType);
/* Define system library External IO functions */
VOID sysSetExternalIO(INT extNo, UINT32 extBaseAddr, UINT32 extSize, INT extBusWidth);
VOID sysSetExternalIOTiming1(INT extNo, INT tACC, INT tACS);
VOID sysSetExternalIOTiming2(INT extNo, INT tCOH, INT tCOS);
/* Define system library power management functions */
INT  sysEnablePM_IRQ(INT irq_no);
VOID    sysDisableAllPM_IRQ(VOID);
INT     sysPMStart(INT pd_type);
txcy 发表于 2010-7-4 08:36 | 显示全部楼层
这应该算不是什么机密,都是开源的,不然谁用它的
 楼主| 无冕之王 发表于 2010-7-4 09:58 | 显示全部楼层
我也不知道为啥找不到源代码??
楼上的给想想办法
hsbjb 发表于 2010-7-7 15:47 | 显示全部楼层
帮楼主顶一下,有源代码的贡献一份
火箭球迷 发表于 2010-7-8 08:29 | 显示全部楼层
这个似乎要向代理商要
火箭球迷 发表于 2010-7-8 08:30 | 显示全部楼层
估计涉及到商业机密吧
sinadz 发表于 2010-7-10 21:01 | 显示全部楼层
这个应该不回涉及什么机密吧
xsgy123 发表于 2010-7-12 16:59 | 显示全部楼层
有些源代码是不公开的
pkat 发表于 2010-7-13 15:33 | 显示全部楼层
楼主可以找相应的代理商咨询下就知道了
David_ming 发表于 2010-7-18 14:47 | 显示全部楼层
整理一份传与大家。哎,这版块给分怎么都这么少呢.............:(
hsbjb 发表于 2010-7-18 21:33 | 显示全部楼层
看了下,还比较有参考价值
LPC300 发表于 2010-7-20 23:45 | 显示全部楼层
上官网上搜搜吧!晚安啦!
年轻不在 发表于 2010-7-24 23:01 | 显示全部楼层
跟代理商要
yybj 发表于 2010-7-25 22:15 | 显示全部楼层
这个好像有点涉及到商业机密
不过楼上的给的资料的确很有帮助
pkat 发表于 2010-7-27 16:20 | 显示全部楼层
这个似乎不涉及到商业机密
应该是可以公开的
火箭球迷 发表于 2010-7-27 16:42 | 显示全部楼层
不知道楼主得到自己想要的源代码没有
dfsa 发表于 2010-7-27 16:52 | 显示全部楼层
11楼的资料很有参考价值,楼主可以参考一下
个人签名:喜欢远行
160
