/****************************************************************************** * [url=home.php?mod=space&uid=288409]@file[/url] main.c * [url=home.php?mod=space&uid=895143]@version[/url] V1.00 * $Revision: 3 $ * $Date: 13/10/07 3:54p $ * [url=home.php?mod=space&uid=247401]@brief[/url] PWM sample for Mini51 series MCU * * @note * Copyright (C) 2013 Nuvoton Technology Corp. All rights reserved. *****************************************************************************/ #include <stdio.h> #include "Mini51Series.h" void SYS_Init(void) { /*---------------------------------------------------------------------------------------------------------*/ /* Init System Clock */ /*---------------------------------------------------------------------------------------------------------*/ /* Unlock protected registers */ while(SYS->RegLockAddr != 1) { SYS->RegLockAddr = 0x59; SYS->RegLockAddr = 0x16; SYS->RegLockAddr = 0x88; } /* Enable external 12MHz XTAL, internal 22.1184MHz */ CLK->PWRCON = CLK_PWRCON_IRC22M_EN_Msk; /* Waiting for clock ready */ while(!(CLK->CLKSTATUS & CLK_CLKSTATUS_IRC22M_STB_Msk)); /* Enable IP clock */ CLK->APBCLK = CLK_APBCLK_UART_EN_Msk | CLK_APBCLK_PWM23_EN_Msk; /* Update System Core Clock */ /* User can use SystemCoreClockUpdate() to calculate SystemCoreClock and CycylesPerUs automatically. */ SystemCoreClockUpdate(); /*---------------------------------------------------------------------------------------------------------*/ /* Init I/O Multi-function */ /*---------------------------------------------------------------------------------------------------------*/ /* Set P1 multi-function pins for UART RXD, TXD */ SYS->P0_MFP = SYS_MFP_P00_TXD | SYS_MFP_P01_RXD; /* Set P2 multi-function pins for PWM Channel */ SYS->P2_MFP = SYS_MFP_P24_PWM2; /* Lock protected registers */ SYS->RegLockAddr = 0; } void UART_Init(void) { // Set UART to 8 bit character length, 1 stop bit, and no parity UART->LCR = UART_LCR_WLS_Msk; // 22.1184 MHz reference clock input, for 115200 bps // 22118400 / 115200 = 192. Using mode 2 to calculate baudrate, 192 - 2 = 190 = 0xBE UART->BAUD = UART_BAUD_DIV_X_EN_Msk | UART_BAUD_DIV_X_ONE_Msk | (0xBE); } int32_t main (void) { /* Init System, IP clock and multi-function I/O In the end of SYS_Init() will issue SYS_LockReg() to lock protected register. If user want to write protected register, please issue SYS_UnlockReg() to unlock protected register if necessary */ SYS_Init(); /* Init UART to 115200-8n1 for print message */ UART_Init(); printf("\nThis sample code will output PWM channel 0 to output waveform\n"); printf("using double buffer feature.\n"); /* PWM channel 0 wave form of this sample showns below: |<- CNR + 1 clk ->| CNR + 1 = 199 + 1 CLKs |<-CMR+1 clk ->| CMR + 1 = 99 + 1 CLKs |<- CNR + 1 ->| CNR + 1 = 99 + 1 CLKs |<CMR+1>| CMR + 1 = 39 + 1 CLKs ______________ ________ _____ __| 100 |_____100______| 60 |__40___| PWM waveform */ // Set channel 0 perscaler to 2. Actual value fill into register needs to minus 1. PWM->PPR = 0x0100; // Set channel 0 clock divider to 1 PWM->CSR = PWM_CLK_DIV_1 << PWM_CSR_CSR2_Pos; // Enable PWM channel 0 auto-reload mode PWM->PCR = PWM_PCR_CH2MOD_Msk; /* Configure PWM channel 1 init period and duty. Period is HCLK / (perscaler * clock divider * (CNR + 1)) Duty ratio = (CMR + 1) / (CNR + 1) Period = 22.1184 MHz / (1 * 1 * (1B9 + 1)) = 25000 Hz Duty ratio = (99 + 1) / (199 + 1) = 50% */ PWM->CMR[2] = 0xB9; PWM->CNR[2] = 0x1B9; // Enable PWM channel 2 output PWM->POE = PWM_POE_PWM2_Msk; // Start PWM->PCR |= PWM_PCR_CH2EN_Msk; while(1); } /*** (C) COPYRIGHT 2013 Nuvoton Technology Corp. ***/
举报
本版积分规则 发表回复 回帖并转播 回帖后跳转到最后一页
222
3931
扫码关注 21ic 官方微信
扫码关注嵌入式微处理器
扫码关注电源系统设计
扫码关注21ic项目外包
扫码浏览21ic手机版
本站介绍 | 申请友情链接 | 欢迎投稿 | 隐私声明 | 广告业务 | 网站地图 | 联系我们 | 诚聘英才
京公网安备 11010802024343号
