[ZLG-ARM] LPCXpresso已经更新到V3.4了,需要的可以到官方网下载!
 楼主| bit6019 发表于 2010-7-19 21:11 | 显示全部楼层 |阅读模式
LPCXpresso V3.4,需要的可以到官方网下载:http://lpcxpresso.code-red-tech.com/LPCXpresso/Downloads
2010-7-1 09:01
更新如下:
Download LPCXpresso installer
  • LPCXpresso v3.4.0 [Current stable release]
    • Added support for LPC2929 and LPC3250
    • Added new 'reset after programming' option to Flash dialog
    • Fix to Managed linker script for data section
    • Various fixes/improvements to peripheral descriptions
    • Debugger fixes for problems related to stepping and viewing variables
    • Fixed problem with setjmp in C library
    • Fixed a rare activation issue. Note: Customers who experienced this problem with previous releases may need acquire a new serial number and activation key.
    • Note: If you are upgrading from a previous installation, we recommend that you install into a new directory. You will be able to use any existing workspaces, and your existing activation code will be used.
yulri 发表于 2010-10-28 11:55 | 显示全部楼层
如何注册呢??
FVJFIFE 发表于 2010-10-28 20:13 | 显示全部楼层
还是英文的?点CREAT ACCOUNT注册
