- #include "dma.h"
- #include "adc.h"
- DMA_HandleTypeDef ADC1_ch5_DMA_Handler; //DMA句柄
- //初始化DMA2
- //这里的传输形式是固定的,这点要根据不同的情况来修改
- //DMA_Streamx:DMA数据流,DMA1_Stream0~7/DMA2_Stream0~7
- //chx:DMA通道选择,[url=home.php?mod=space&uid=144993]@ref[/url] DMA_channel DMA_CHANNEL_0~DMA_CHANNEL_7
- void DMA2_ADC1_Ch0_Stream0_Init(void)
- __HAL_RCC_DMA2_CLK_ENABLE();//DMA2时钟使能
- //DMA配置
- ADC1_ch5_DMA_Handler.Instance=DMA2_Stream0; //数据流0
- ADC1_ch5_DMA_Handler.Init.Channel=DMA_CHANNEL_0; //通道0
- ADC1_ch5_DMA_Handler.Init.Direction=DMA_PERIPH_TO_MEMORY ; //外设到存储器
- ADC1_ch5_DMA_Handler.Init.PeriphInc=DMA_PINC_DISABLE; //外设非增量模式
- ADC1_ch5_DMA_Handler.Init.MemInc=DMA_MINC_DISABLE; //存储器非增量模式
- ADC1_ch5_DMA_Handler.Init.PeriphDataAlignment=DMA_PDATAALIGN_HALFWORD ; //外设数据长度:32位
- ADC1_ch5_DMA_Handler.Init.MemDataAlignment=DMA_MDATAALIGN_HALFWORD ; //存储器数据长度:32位
- ADC1_ch5_DMA_Handler.Init.Mode=DMA_CIRCULAR; //循环模式
- ADC1_ch5_DMA_Handler.Init.Priority=DMA_PRIORITY_MEDIUM; //中等优先级
- ADC1_ch5_DMA_Handler.Init.FIFOMode=DMA_FIFOMODE_DISABLE;
- ADC1_ch5_DMA_Handler.Init.FIFOThreshold=DMA_FIFO_THRESHOLD_FULL;
- ADC1_ch5_DMA_Handler.Init.MemBurst=DMA_MBURST_SINGLE; //存储器突发单次传输
- ADC1_ch5_DMA_Handler.Init.PeriphBurst=DMA_PBURST_SINGLE; //外设突发单次传输
- HAL_DMA_Init(&ADC1_ch5_DMA_Handler);
- __HAL_LINKDMA(&ADC1_Handler,DMA_Handle,ADC1_ch5_DMA_Handler); //将DMA与ADC1联系起来(发送DMA)
- /*##-4- Configure the NVIC for DMA #########################################*/
- /* NVIC configuration for DMA transfer complete interrupt */
- HAL_NVIC_SetPriority(DMA2_Stream0_IRQn, 0, 0);
- HAL_NVIC_EnableIRQ(DMA2_Stream0_IRQn);
- #include "adc.h"
- #include "dma.h"
- ADC_HandleTypeDef ADC1_Handler; //ADC1 句柄
- uint32_t ADC1_data; //缓冲
- //adc 底层配置 时钟 IO
- void HAL_ADC_MspInit (ADC_HandleTypeDef * hadc){
- GPIO_InitTypeDef GPIO_Initure;
- __HAL_RCC_ADC1_CLK_ENABLE(); //开启ADC1时钟
- __HAL_RCC_GPIOA_CLK_ENABLE(); //开启GPIOA时钟
- GPIO_Initure.Pin = GPIO_PIN_5; //PA5
- GPIO_Initure.Mode = GPIO_MODE_ANALOG; //模拟输入
- GPIO_Initure.Pull = GPIO_NOPULL; //无上下拉
- HAL_GPIO_Init(GPIOA,&GPIO_Initure); //初始化GPIO
- //adc1 初始化
- void adc1_init(void){
- ADC_ChannelConfTypeDef ADC1_Channel; //ADC1通道配置
- ADC1_Handler.Instance = ADC1; //ADC1
- ADC1_Handler.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV4; //4分频
- ADC1_Handler.Init.Resolution = ADC_RESOLUTION_12B; //12位模式
- ADC1_Handler.Init.ScanConvMode = DISABLE; //单通道模式
- ADC1_Handler.Init.EOCSelection = DISABLE; //关闭EOC中断
- ADC1_Handler.Init.ContinuousConvMode = ENABLE; //开启连续转换
- ADC1_Handler.Init.DMAContinuousRequests = ENABLE; //开启DMA
- ADC1_Handler.Init.NbrOfConversion = 1; //规则通道数
- ADC1_Handler.Init.DiscontinuousConvMode = DISABLE; //间断模式
- ADC1_Handler.Init.NbrOfDiscConversion = 0; //注入通道数
- ADC1_Handler.Init.ExternalTrigConv = ADC_SOFTWARE_START; //软件触发
- ADC1_Handler.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE; //软件触发
- HAL_ADC_Init (&ADC1_Handler); //ADC1初始化
- //ADC通道配置
- ADC1_Channel.Channel = ADC_CHANNEL_5; //通道5
- ADC1_Channel.Rank = 1; //规则通道数
- ADC1_Channel.SamplingTime = ADC_SAMPLETIME_3CYCLES; //转换时间
- ADC1_Channel.Offset = 0; //保留
- HAL_ADC_ConfigChannel(&ADC1_Handler,&ADC1_Channel); //通道配置
- // HAL_ADC_Start(&ADC1_Handler);//开启ADC
- HAL_ADC_Start_DMA(&ADC1_Handler,&ADC1_data,1); //开启DMA传输
- #include "main.h"
- #include "sys.h"
- #include "delay.h"
- #include "usart.h"
- #include "led.h"
- #include "adc.h"
- #include "dma.h"
- #include <string.h>
- //初始化
- static void init(void){
- Cache_Enable(); //使能CPU的L1-Cache
- HAL_Init(); //初始化HAL库
- Stm32_Clock_Init(432,25,2,9); //设置时钟,216Mhz
- delay_init(216); //延时初始化
- uart_init(115200); //串口初始化
- led_init(); //初始化led
- DMA2_ADC1_Ch0_Stream0_Init(); //初始化dma2
- adc1_init(); //初始化adc1
- int main(void)
- init(); //初始化
- while (1)
- delay_ms(1000);
- printf("adc1 ch5:%d\r\n",ADC1_data);
- // ADC1_data = 0;
- * [url=home.php?mod=space&uid=288409]@file[/url] Templates/Src/stm32f7xx.c
- * [url=home.php?mod=space&uid=187600]@author[/url] MCD Application Team
- * [url=home.php?mod=space&uid=895143]@version[/url] V1.0.0
- * [url=home.php?mod=space&uid=212281]@date[/url] 22-April-2016
- * @brief Main Interrupt Service Routines.
- * This file provides template for all exceptions handler and
- * peripherals interrupt service routine.
- * @attention
- * <h2><center>© COPYRIGHT(c) 2016 STMicroelectronics</center></h2>
- * Redistribution and use in source and binary forms, with or without modification,
- * are permitted provided that the following conditions are met:
- * 1. Redistributions of source code must retain the above copyright notice,
- * this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright notice,
- * this list of conditions and the following disclaimer in the documentation
- * and/or other materials provided with the distribution.
- * 3. Neither the name of STMicroelectronics nor the names of its contributors
- * may be used to endorse or promote products derived from this software
- * without specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
- * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
- * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
- * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
- * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
- * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
- * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
- * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
- * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
- /* Includes ------------------------------------------------------------------*/
- #include "main.h"
- #include "stm32f7xx_it.h"
- #include "adc.h"
- /** @addtogroup STM32F7xx_HAL_Examples
- /** @addtogroup Templates
- /* Private typedef -----------------------------------------------------------*/
- /* Private define ------------------------------------------------------------*/
- /* Private macro -------------------------------------------------------------*/
- /* Private variables ---------------------------------------------------------*/
- /* Private function prototypes -----------------------------------------------*/
- /* Private functions ---------------------------------------------------------*/
- /* Cortex-M7 Processor Exceptions Handlers */
- * @brief This function handles NMI exception.
- * @param None
- * @retval None
- void NMI_Handler(void)
- * @brief This function handles Hard Fault exception.
- * @param None
- * @retval None
- void HardFault_Handler(void)
- /* Go to infinite loop when Hard Fault exception occurs */
- while (1)
- * @brief This function handles Memory Manage exception.
- * @param None
- * @retval None
- void MemManage_Handler(void)
- /* Go to infinite loop when Memory Manage exception occurs */
- while (1)
- * @brief This function handles Bus Fault exception.
- * @param None
- * @retval None
- void BusFault_Handler(void)
- /* Go to infinite loop when Bus Fault exception occurs */
- while (1)
- * @brief This function handles Usage Fault exception.
- * @param None
- * @retval None
- void UsageFault_Handler(void)
- /* Go to infinite loop when Usage Fault exception occurs */
- while (1)
- * @brief This function handles SVCall exception.
- * @param None
- * @retval None
- void SVC_Handler(void)
- * @brief This function handles Debug Monitor exception.
- * @param None
- * @retval None
- void DebugMon_Handler(void)
- * @brief This function handles PendSVC exception.
- * @param None
- * @retval None
- void PendSV_Handler(void)
- * @brief This function handles SysTick Handler.
- * @param None
- * @retval None
- void SysTick_Handler(void)
- HAL_IncTick();
- /* STM32F7xx Peripherals Interrupt Handlers */
- /* Add here the Interrupt Handler for the used peripheral(s) (PPP), for the */
- /* available peripheral interrupt handler's name please refer to the startup */
- /* file (startup_stm32f7xx.s). */
- void DMA2_Stream0_IRQHandler(void)
- HAL_DMA_IRQHandler(ADC1_Handler.DMA_Handle);
- * @brief This function handles PPP interrupt request.
- * @param None
- * @retval None
- /*void PPP_IRQHandler(void)
- /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
我的ADC1 是连续转换通道5 debug的时候adc模块在转换数据也在变化 dma2的中断也触发了,但数据一直都是0
