EEPROM的程序
 楼主| chenho 发表于 2010-12-25 18:37 | 显示全部楼层 |阅读模式
有谁会88F4051读写EEPROM的程序。
gongche 发表于 2010-12-25 18:41 | 显示全部楼层
没用过,帮顶
huwr 发表于 2010-12-25 19:16 | 显示全部楼层
可以到代码区找找
huanghuac 发表于 2010-12-25 19:26 | 显示全部楼层
uint16 ReadEEPData(uint8 *ptr)
uint8 i,j;
uint16 addr;
uint8 curBlock[EEP_SAVE_BYTE];
uint8 *bkDP;
bit bkEA = EA;
bit bWrited;
    EA = 0;
    FLASHCON = 1;
    bkDP = ptr;
    for(i=0; i<EEP_SAVE_BYTE; i++)
        *ptr =0;
        ptr++;
    addr =EEP_SECTOR_USE;
    j = 0;
    for(i=0; i<EEP_SAVE_TIMES; i++)
        bWrited = 0;
        ptr = bkDP;
        for(j=0; j<EEP_SAVE_BYTE; j++)
            curBlock[j] = CBYTE[addr];
            addr++;
            if(curBlock[j]) bWrited = 1;
        if(bWrited)
                *ptr = curBlock[j];
                ptr++;
        else
            break;
    if(i == EEP_SAVE_TIMES)
        EraseEEPSector(EEP_SECTOR_USE);
        i = 0;
        addr = EEP_SECTOR_USE;
    else
        addr -= EEP_SAVE_BYTE;
    FLASHCON = 0;
    EA = bkEA;
    return(addr);
 楼主| chenho 发表于 2010-12-25 19:50 | 显示全部楼层
多谢楼上,我要的就是这个
 楼主| chenho 发表于 2010-12-25 19:51 | 显示全部楼层
结贴了
