这个函数的最后一行代码
void CLK_SetHCLK(uint32_t u32ClkSrc, uint32_t u32ClkDiv)
uint32_t u32HIRCSTB;
/* Read HIRC clock source stable flag */
u32HIRCSTB = CLK->CLKSTATUS & CLK_CLKSTATUS_OSC22M_STB_Msk;
/* Switch to HIRC for Safe. Avoid HCLK too high when applying new divider. */
CLK->PWRCON |= CLK_PWRCON_OSC22M_EN_Msk;
while((CLK->CLKSTATUS & CLK_CLKSTATUS_OSC22M_STB_Msk) == 0);
CLK->CLKSEL0 = (CLK->CLKSEL0 & (~CLK_CLKSEL0_HCLK_S_Msk)) | CLK_CLKSEL0_HCLK_S_HIRC;
/* Apply new Divider */
CLK->CLKDIV = (CLK->CLKDIV & (~CLK_CLKDIV_HCLK_N_Msk)) | u32ClkDiv;
/* Switch to new HCLK source */
CLK->CLKSEL0 = (CLK->CLKSEL0 & (~CLK_CLKSEL0_HCLK_S_Msk)) | u32ClkSrc;
/* Update System Core Clock */
SystemCoreClockUpdate();
/* Disable HIRC if HIRC is disabled before switching HCLK source */
if(u32HIRCSTB == 0)
CLK->PWRCON &= ~CLK_CLKSTATUS_OSC22M_STB_Msk;
PWRCON 寄存器里面没有CLK_CLKSTATUS_OSC22M_STB_Msk定义,对应的位是PD_WU_DLY,是"使能唤醒延时计数器"功能.这样写有什么用意?
BSP当中有PD_WU_DLY位的定义,如下:
#define CLK_PWRCON_PD_WU_DLY_Pos 4 /*!< CLK_T::PWRCON: PD_WU_DLY Position */
#define CLK_PWRCON_PD_WU_DLY_Msk (1ul << CLK_PWRCON_PD_WU_DLY_Pos) /*!< CLK_T::PWRCON: PD_WU_DLY Mask */
我查了nano130的BSP,这个函数的最后一行代码也是这样写的,都是使用别的寄存器位的定义. |
