psoc deisgned 5.1错误
 楼主| pangb 发表于 2011-2-28 20:18 | 显示全部楼层 |阅读模式
creating project.mk -- no changes
CAUTION there are no library files
CAUTION boot.asm is older than boot.tpl or is missing
CAUTION you may need to generate source in PSoC Designer
./boot.asm
!E ./boot.asm(0): cannot open './boot.asm' for input
C:\PROGRA~1\Cypress\PSOCDE~1\5.1\Common\CY3E64~1\tools\make: *** [obj/boot.o] Error 1
asdfg - 2 error(s) 0 warning(s)还有好多Starting MAKE...
zyf部长 发表于 2011-2-28 20:21 | 显示全部楼层
源程序呢
zwll 发表于 2011-2-28 20:41 | 显示全部楼层
没有定义LED吧
 楼主| pangb 发表于 2011-2-28 23:08 | 显示全部楼层
呵,还真是,多谢
