我只会简单的例化,比如说顶层和底层的引脚都一样的那种
下面的图我就不会了
我自己的例化程序,编译不成功,希望大家可以帮忙下
- library ieee;
- use ieee.std_logic_1164.all;
- use ieee.std_logic_unsigned.all;
- entity clock is
- port(
- clk,reset :in std_logic;
- time_out :out std_logic
- end entity;
- architecture rtl of clock is
- component time_ms is
- port(
- clk ,reset :in std_logic;
- ms_out :out std_logic
- end component;
- component time_sec is
- port(
- ms_in :in std_logic;
- sec_out :out std_logic
- end component;
- component time_min is
- port(
- sec_in :in std_logic;
- min_out :out std_logic
- end component;
- component time_hour is
- port(
- min_in :in std_logic;
- hour_out :out std_logic
- end component;
- begin
- u1:time_ms port map(clk=>clk,reset=>reset);
- u2:time_sec port map(clk=>clk,reset=>reset,ms_in=>ms_out);
- u3:time_min port map(clk=>clk,reset=>reset,sec_in=>sec_out);
- u4:time_hour port map(clk=>clk,reset=>reset,hour_in=>min_hour,hour_out=>time_out);
- end architecture;
