STM32 串口收发数据
 楼主| 树下好乘凉 发表于 2011-3-22 12:00 | 显示全部楼层 |阅读模式
我尝试用下面的代码发数据,但是一直得到的是00 00。。。。。望好心人指教!!
int main(void)
int i, RX_status = 0;
SystemInit();
GPIO_Configuration();
USART1_Config();
   while (1)
  RX_status = USART_GetFlagStatus(USART1, USART_FLAG_RXNE);
  if(RX_status == SET)
     USART_SendData(USART1 , USART_ReceiveData(USART1));
     while(USART_GetFlagStatus(USART1, USART_FLAG_TC)==RESET);
void USART1_Config(void)
USART_InitTypeDef USART_InitStructure;
    USART_InitStructure.USART_BaudRate = 115200;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
USART_Init(USART1, &USART_InitStructure);
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
USART_ITConfig(USART1, USART_IT_TXE, ENABLE);
USART_Cmd(USART1, ENABLE);
void GPIO_Configuration(void)
RCC_APB2PeriphClockCmd( RCC_APB2Periph_USART1 |RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB |
                         RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD |
                         RCC_APB2Periph_GPIOE, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;    //LED4
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOE, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOA, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
ST_ARM 发表于 2011-3-22 23:38 | 显示全部楼层
你先看看你收到的数据是否正确.
 楼主| 树下好乘凉 发表于 2011-3-23 09:28 | 显示全部楼层
不正确,如果以16进制接收,显示的全是00 00 00
ST_ARM 发表于 2011-3-23 09:41 | 显示全部楼层
用示波器查看一下RX引脚上的数据(包括PC端的TX),看看信号是否正确。
zztishan 发表于 2012-2-13 16:17 | 显示全部楼层
接受的数据不能直接在函数里发送,应该要通过变量保存转换,而且, while (USART_GetFlagStatus(USART1,USART_FLAG_TXE) == RESET);
xlhtracy 发表于 2012-2-13 16:40 | 显示全部楼层
这是个啥
