System Generator Clock Enable Logic Optimization
 楼主| AutoESL 发表于 2011-4-22 15:41 | 显示全部楼层 |阅读模式
§Multi-rate design in System Generator
§Clock enable hardware
§Phase of clock enables in relation to the original Simulinksimulation
§Optimizing Clock Enable fanout
§Resetting the auto-generated clock enable logic
奔腾2.0 发表于 2011-4-22 22:47 | 显示全部楼层
:dizzy:
 楼主| AutoESL 发表于 2011-4-23 11:50 | 显示全部楼层
hjjnet 发表于 2011-4-23 13:21 | 显示全部楼层
瞄一下
个人签名:天使宝贝 博客IT人生 From C/C++/SystemC to Xilinx FPGA
