- /* Copyright(c) 2016 Nuvoton Technology Corp. All rights reserved. */
- // Nuvoton Technoledge Corp.
- // Website: http://www.nuvoton.com
- // E-Mail : MicroC-8bit@nuvoton.com
- // Date : Apr/21/2016
- // File Function: N76E003 Watch Dog as pure timer with interrupt demo code
- #include "N76E003.h"
- #include "Common.h"
- #include "Delay.h"
- #include "SFR_Macro.h"
- #include "Function_define.h"
- * WDT interrupt sub-routine
- void WDT_ISR (void) interrupt 10
- //---------toggle GPIO1---------
- clr_GPIO1;
- Timer0_Delay1ms(50);
- set_GPIO1;
- clr_GPIO1;
- set_GPIO1;
- //---------end toggle GPIO2--------
- clr_WDTF;
- set_WDCLR;
- * Main function
- void main (void)
- /* Note
- WDT timer base is LIRC 10Khz
- Set_All_GPIO_Quasi_Mode;
- clr_GPIO1;
- Timer0_Delay1ms(500);
- set_GPIO1;
- clr_GPIO1;
- set_GPIO1;
- //WDT init
- //Warning:
- //Pleaes always check CONFIG WDT disable first
- //only when WDT reset disable, WDT use as pure timer
- TA=0xAA;TA=0x55;WDCON=0x07; //Setting WDT prescale
- set_WDTR; //WDT run
- set_WDCLR; //Clear WDT timer
- set_EWDT;
- EA =1;
- #if 0
- while(1);
- #else
- set_WIDPD; //WDT run in POWER DOWM mode setting if needed
- while (1)
- set_PD;
- clr_P04;
- Timer1_Delay10ms(5);
- set_P04;
- clr_P04;
- set_P04;
- //---------end toggle GPIO1---------
- #endif
