[51单片机] 程序运行不顺自己想不通来问问大家!!!
 楼主| a1995 发表于 2017-12-24 16:48 | 显示全部楼层 |阅读模式
这个程序是我按照自己的理解只是把程序的函数名改了一下可是不知道为什么下到单片机中运行就不能像例程中一样显示日期和时间,拜托各位前辈指点一下。还有它下面提示:CALLER2: ?C_C51STARTUP
                          CALLER1: ?PR?TIMER0?1602汉譥加时糭显示
                          SEGMENT: ?PR?_WRITE_TIME?1602汉譥加时糭显示
#include<reg52.h>
#define uchar unsigned char
#define uint unsigned int
sbit RS = P3^4;        //LCD命令或数据选择端
sbit RW = P3^5;        //LCD读写选择端
sbit EN = P3^6;        //LCD使能端
sbit we = P2^6;         //数码管位选
sbit du = P2^7;         //数码管段选
sbit key2 = P3^0;  //S2独立键盘
sbit key3 = P3^1; //S3独立键盘
sbit key4 = P3^2;//S4独立键盘
sbit key5 = P3^3;  //S5独立键盘
uchar num,key2num,count,hour,min,sec; //定义字符数量、键盘初始化、计数器、时、分、秒
uchar code display[]={                                                 //年月日
        0x08,0x0f,0x10,0x0e,0x0c,0xff,0x04,0x00,
        0x0f,0x09,0x0f,0x09,0x0f,0x09,0x11,0x00,
        0x0f,0x09,0x09,0x0f,0x09,0x09,0x0f,0x00
void delay(uint xms)  //延时函数 单位ms
        uint i,j;
        for(i=xms;i>0;i--)
                for(j=112;j>0;j--);
void write_com(uchar com) //LCD总线写命令
        RS = 0;
        EN = 0;
        P0 = com;
        delay(5);
        EN = 1;
        delay(5);
        EN = 0;
void write_data(uchar date)         //LCD总线读命令
        RS = 1;
        EN = 0;
        P0 = date;
        delay(5);
        EN = 1;
        delay(5);
        EN = 0;
void write_coordinate_xy(uchar x,y)        //LCD显示位置定义
        uchar address;        //y为0的时候在第一行,为1时在第二行
        if(y==0)
        address=0x80+x;
        else
        address=0xc0+x;
        write_com(address);
void write_string(uchar x,y,uchar *s)//LCD显示字符串
        write_coordinate_xy(x,y); //设置显示位置
        while(*s);
                P0=*s;
                write_data(*s);
                s++;
void write_time(uchar add,date)//LCD时间显示10位和个位,写时、分、秒、函数
        uchar hour ,ge;
        hour = date/10;
        ge = date%10;
        write_com(0x80+0x40+add);
        write_data(0x30+hour);
        write_data(0x30+ge);
void write_character() //写入固定的汉字和符号
        write_com(0x40);//设定CGRAM的地址
        for(num=0;num<24;num--)           //将自定义字形码写入
                write_data(display[num]);
        write_com(0x84);//年
                write_data(0);
        write_com(0x87);//月
                write_data(1);
        write_com(0x8a);//日
                write_data(2);
        write_string(2,1,":");
        write_string(5,1,":");
        write_string(9,1,"QX-MCU");
void init()          //定时器和LCD初始化
        du=0;we=0;RW=0;
        hour=0;min=0;sec=0;key2num=0;count=0;
        TMOD=0x01;
        TH0=(65536-45872)/256;
        TL0=(65536-45872)%256;
        EA=1;
        ET0=1;
        TR0=1;
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
        write_string(0,0,"2017");
        write_string(5,0,"12");
        write_string(8,0,"21");
        write_time(0,hour);
        write_time(3,min);
        write_time(6,sec);
        write_character();
        TMOD=0x01;//设置定时器0工作模式1
        TH0=(65536-50000)/256;//定时器装初值
        TL0=(65536-50000)%256;
        EA=1; //开总中断
        ET0=1; //开定时器0中断
        TR0=1; //启动定时器0
void keyscan() //按键检测
        key5=0;
        if(key2==0)
                delay(5);
                if(key2==0)
                        key2num++;
                        while(!key2);
                        if(key2num==1)
                                TR0=0;
                                write_com(0x80+0x40+7);
                                write_com(0x0f);
                        if(key2num==2)
                                write_com(0x80+0x40+4);
                        if(key2num==3)
                                write_com(0x80+0x40+1);
                        if(key2num==4)
                                key2num=0;
                                write_com(0xc0);
                                TR0=1;
        if(key2num!=0)
                if(key3==0)
                        delay(5);
                        if(key3==0)
                                while(!key3);
                                if(key2num==1)
                                        sec++;
                                        if(sec==60)
                                        sec=0;
                                        write_time(6,sec);
                                if(key2num==2)
                                        min++;
                                        if(min==60)
                                        min=0;
                                        write_time(3,min);
                                if(key2num==3)
                                        hour++;
                                        if(hour==24)
                                        hour=0;
                                        write_time(0,hour);
                if(key4==0)
                        delay(5);
                        if(key3==0)
                                while(!key3);
                                if(key2num==1)
                                        sec--;
                                        if(sec==-1)
                                                sec=59;
                                        write_time(6,sec);
                                if(key2num==2)
                                        min--;
                                        if(min==-1)
                                                min=59;
                                        write_time(3,min);
                                if(key2num==3)
                                        hour--;
                                        if(hour==-1)
                                                hour=23;
                                        write_time(0,hour);
void main()          //主程序
        du=0;we=0;RS=0;
        init();
        while(1)
                keyscan();
void timer0() interrupt 1//中断服务程序
        count++;
        if(count==20)
                count=0;
                sec++;
                if(sec==60)
                        sec=0;
                        min++;
                        if(min==60)
                                min=0;
                                hour++;
                                if(hour==24)
                                        hour=0;
                                write_time(0,hour);
                        write_time(3,min);
                write_time(6,sec);
ningling_21 发表于 2017-12-24 17:09 | 显示全部楼层
不改函数名是正常的吗
例程是正常的,我改之后就不正常了  发表于 2017-12-25 08:39
linqing171 发表于 2017-12-24 21:01 | 显示全部楼层
定时器和主循环都要写LCD,厉害。
但是你有没有想一下同时写的话时序会被打断?
建议在timer0中断里面不要写lcd,只加个TimeChangedFlag。在主循环中写LCD。
ningling_21 发表于 2017-12-25 10:46 | 显示全部楼层
不要在中断中操作LCD
zhangxiyi5277 发表于 2017-12-28 22:14 | 显示全部楼层
一言不合就贴代码,,,
zqx1000 发表于 2018-4-10 22:25 | 显示全部楼层
caijie001 发表于 2018-4-10 23:22 | 显示全部楼层
...........................看得我头大
sum123456 发表于 2018-4-11 07:11 | 显示全部楼层
IIC通讯有主机和从机。主机发送模式下协议是:起始位 从机地址 应答位 数据位 应答位 数据位 应答位 ...... 停止位
