[STM32L0] STM32 L0 的EEPROM 的读写函数
 楼主| GuDuDeRener 发表于 2018-1-30 12:36 | 显示全部楼层 |阅读模式
#define EEPROM_BASE_ADDR        0x08000000
#define EEPROM_BYTE_SIZE        0x0800  //¶¨ÒåEEPROMµÄÆðʼλÖúʹóС
#define PEKEY1        0x89ABCDEF                //FLASH_PEKEYR
#define PEKEY2        0x02030405                //FLASH_PEKEYR ½âËøÃüÁî
#define EN_INT              __enable_irq();         //ϵͳ¿ª¾ÖÖжÏ
#define DIS_INT             __disable_irq();        //ϵͳ¹Ø±ÕÈ«¾Ö
void EEPROM_ReadBytes(unsigned int Addr,char *Buffer, short Length)//°´ÕÕ×Ö½Ú¶Á³öEEPROMµÄÊý¾Ý
        char *wAddr;
        wAddr=(char *)(EEPROM_BASE_ADDR+Addr);
        while(Length--)
                 *Buffer++=*wAddr++;
void EEPROM_WriteBytes(unsigned int Addr,char *Buffer,short Length)//°´ÕÕ×Ö½ÚÊý¾Ýдµ½EEPROM
        char *wAddr;
        DIS_INT
        FLASH->PEKEYR=PEKEY1;                    //unlock
        FLASH->PEKEYR=PEKEY2;
        while(Length--)
                *wAddr++=*Buffer++;
                while(FLASH->SR&FLASH_SR_BSY);
        FLASH->PECR|=FLASH_PECR_PELOCK;
        EN_INT
为什么写不进去啊?
fengfeng的恒 发表于 2018-1-31 09:14 | 显示全部楼层
EEPROM的基地址好像不对,你查下datasheet看看吧
jwzzx 发表于 2018-4-23 15:10 | 显示全部楼层
Func: EEPROM  Read
Note:
void EEPROM_Read(uint16_t Addr,uint8_t *Buffer,uint16_t Length)
    uint8_t *wAddr;
                HAL_FLASHEx_DATAEEPROM_Unlock();
    wAddr=(uint8_t *)(DATA_EEPROM_BASE+Addr);
    while(Length--){
        *Buffer++=*wAddr++;
                HAL_FLASHEx_DATAEEPROM_Lock();
Func: EEPROM Write
Note:
void EEPROM_Write(uint16_t WriteAddr,uint8_t *pBuffer,uint16_t NumToWrite)
    uint16_t t;
    for(t = 0;t < NumToWrite;t++)
        HAL_FLASHEx_DATAEEPROM_Program(FLASH_TYPEPROGRAMDATA_BYTE,DATA_EEPROM_BASE + WriteAddr + t,*(pBuffer + t));
gubaoyl 发表于 2019-1-1 20:46 | 显示全部楼层
Func: EEPROM  Read
Note:
有用,谢谢
