- # -- coding: utf-8 --
- # http://blog.csdn.net/luhanglei
- import picamera
- import time
- import traceback
- import ctypes
- from librtmp import *
- global meta_packet
- global start_time
- class Writer(): # camera可以通过一个类文件的对象来输出,实现write方法即可
- conn = None # rtmp连接
- sps = None # 记录sps帧,发过以后就不需要再发了(抓包看到ffmpeg是这样的)
- pps = None # 同上
- sps_len = 0 # 同上
- pps_len = 0 # 同上
- time_stamp = 0
- def __init__(self, conn):
- self.conn = conn
- def write(self, data):
- try:
- # 寻找h264帧间隔符
- indexs = []
- index = 0
- data_len = len(data)
- while index < data_len - 3:
- if ord(data[index]) == 0x00 and ord(data[index + 1]) == 0x00 and ord(
- data[index + 2]) == 0x00 and ord(data[index + 3]) == 0x01:
- indexs.append(index)
- index = index + 3
- index = index + 1
- # 寻找h264帧间隔符 完成
- # 通过间隔符个数确定类型,树莓派摄像头的第一帧是sps+pps同时发的
- if len(indexs) == 1: # 非sps pps帧
- buf = data[4: len(data)] # 裁掉原来的头(00 00 00 01),把帧内容拿出来
- buf_len = len(buf)
- type = ord(buf[0]) & 0x1f
- if type == 0x05: # 关键帧,根据wire shark抓包结果,需要拼装sps pps 帧内容 三部分,长度都用4个字节表示
- body0 = 0x17
- data_body_array = [bytes(bytearray(
- [body0, 0x01, 0x00, 0x00, 0x00, (self.sps_len >> 24) & 0xff, (self.sps_len >> 16) & 0xff,
- (self.sps_len >> 8) & 0xff,
- self.sps_len & 0xff])), self.sps,
- bytes(bytearray(
- [(self.pps_len >> 24) & 0xff, (self.pps_len >> 16) & 0xff, (self.pps_len >> 8) & 0xff,
- self.pps_len & 0xff])),
- self.pps,
- bytes(bytearray(
- [(buf_len >> 24) & 0xff, (buf_len >> 16) & 0xff, (buf_len >> 8) & 0xff, (buf_len) & 0xff])),
- buf
- mbody = ''.join(data_body_array)
- time_stamp = 0 # 第一次发出的时候,发时间戳0,此后发真时间戳
- if self.time_stamp != 0:
- time_stamp = int((time.time() - start_time) * 1000)
- packet_body = RTMPPacket(type=PACKET_TYPE_VIDEO, format=PACKET_SIZE_LARGE, channel=0x06,
- timestamp=time_stamp, body=mbody)
- packet_body.packet.m_nInfoField2 = 1
- else: # 非关键帧
- body0 = 0x27
- [body0, 0x01, 0x00, 0x00, 0x00, (buf_len >> 24) & 0xff, (buf_len >> 16) & 0xff,
- (buf_len >> 8) & 0xff,
- (buf_len) & 0xff])), buf]
- # if (self.time_stamp == 0):
- self.time_stamp = int((time.time() - start_time) * 1000)
- packet_body = RTMPPacket(type=PACKET_TYPE_VIDEO, format=PACKET_SIZE_MEDIUM, channel=0x06,
- timestamp=self.time_stamp, body=mbody)
- self.conn.send_packet(packet_body)
- elif len(indexs) == 2: # sps pps帧
- if self.sps is not None:
- return
- data_body_array = [bytes(bytearray([0x17, 0x00, 0x00, 0x00, 0x00, 0x01]))]
- sps = data[indexs[0] + 4: indexs[1]]
- sps_len = len(sps)
- pps = data[indexs[1] + 4: len(data)]
- pps_len = len(pps)
- self.sps = sps
- self.sps_len = sps_len
- self.pps = pps
- self.pps_len = pps_len
- data_body_array.append(sps[1:4])
- data_body_array.append(bytes(bytearray([0xff, 0xe1, (sps_len >> 8) & 0xff, sps_len & 0xff])))
- data_body_array.append(sps)
- data_body_array.append(bytes(bytearray([0x01, (pps_len >> 8) & 0xff, pps_len & 0xff])))
- data_body_array.append(pps)
- data_body = ''.join(data_body_array)
- body_packet = RTMPPacket(type=PACKET_TYPE_VIDEO, format=PACKET_SIZE_LARGE, channel=0x06,
- timestamp=0, body=data_body)
- body_packet.packet.m_nInfoField2 = 1
- self.conn.send_packet(meta_packet, queue=True)
- self.conn.send_packet(body_packet, queue=True)
- except Exception, e:
- traceback.print_exc()
- def flush(self):
- pass
- def get_property_string(string): # 返回两字节string长度及string
- length = len(string)
- return ''.join([chr((length >> 8) & 0xff), chr(length & 0xff), string])
- def get_meta_string(string): # 按照meta packet要求格式返回bytes,带02前缀
- return ''.join([chr(0x02), get_property_string(string)])
- def get_meta_double(db):
- nums = [0x00]
- fp = ctypes.pointer(ctypes.c_double(db))
- cp = ctypes.cast(fp, ctypes.POINTER(ctypes.c_longlong))
- for i in range(7, -1, -1):
- nums.append((cp.contents.value >> (i * 8)) & 0xff)
- return ''.join(bytes(bytearray(nums)))
- def get_meta_boolean(isTrue):
- nums = [0x01]
- if (isTrue):
- nums.append(0x01)
- else:
- nums.append(0x00)
- conn = RTMP(
- 'rtmp://192.168.199.154/oflaDemo/test', # 推流地址
- live=True)
- librtmp.RTMP_EnableWrite(conn.rtmp)
- conn.connect()
- start_time = time.time()
- # 拼装视频格式的数据包
- meta_body_array = [get_meta_string('@setDataFrame'), get_meta_string('onMetaData'),
- bytes(bytearray([0x08, 0x00, 0x00, 0x00, 0x06])), # 两个字符串和ECMA array头,共计6个元素,注释掉了音频相关数据
- get_property_string('width'), get_meta_double(640.0),
- get_property_string('height'), get_meta_double(480.0),
- get_property_string('videodatarate'), get_meta_double(0.0),
- get_property_string('framerate'), get_meta_double(25.0),
- get_property_string('videocodecid'), get_meta_double(7.0),
- # get_property_string('audiodatarate'), get_meta_double(125.0),
- # get_property_string('audiosamplerate'), get_meta_double(44100.0),
- # get_property_string('audiosamplesize'), get_meta_double(16.0),
- # get_property_string('stereo'), get_meta_boolean(True),
- # get_property_string('audiocodecid'), get_meta_double(10.0),
- get_property_string('encoder'), get_meta_string('Lavf57.56.101'),
- bytes(bytearray([0x00, 0x00, 0x09]))
- meta_body = ''.join(meta_body_array)
- print meta_body.encode('hex')
- meta_packet = RTMPPacket(type=PACKET_TYPE_INFO, format=PACKET_SIZE_LARGE, channel=0x04,
- timestamp=0, body=meta_body)
- meta_packet.packet.m_nInfoField2 = 1 # 修改stream id
- stream = conn.create_stream(writeable=True)
- with picamera.PiCamera() as camera:
- camera.start_preview()
- time.sleep(2)
- camera.start_recording(Writer(conn), format='h264', resize=(640, 480), intra_period=25,
- quality=25) # 开始录制,数据输出到Writer的对象里
- while True:#永远不停止
- time.sleep(60)
- camera.stop_recording()
- camera.stop_preview()
