编译时总是出现如下错误
762|8
 楼主| pangb 发表于 2018-3-19 16:09 | 显示全部楼层 |阅读模式
ADD: sdb.M0059: error: Error in component: cy_boot. The cy_boot_v1_10 component (cy_boot) is an Obsolete component. It is no longer recommended for use and should be replaced with a production version of the component (or an alternative implementation).
 楼主| pangb 发表于 2018-3-19 16:12 | 显示全部楼层
Error: cdf.M0005: CyDsFit aborted due to errors, please address all errors and rerun CyDsFit. (App=cydsfit)
chenjunt 发表于 2018-3-19 16:16 | 显示全部楼层
芯片选择对了么
ousj 发表于 2018-3-19 16:19 | 显示全部楼层
程序升级是否完整,我有过升级一半我嫌慢就取消掉了,后来就再也不能用只能重新装一遍的情况了
morrisk 发表于 2018-3-19 16:21 | 显示全部楼层
Currently, PSoC Creator does not support building a project from a network share drive. Typically, “My Documents” or equivalent folder is seen as a shared network folder by Windows running on Parallels Desktop. Please save the project in a local folder (say C:\Documents and Settings\User\...) and rebuild the example project.
zyf部长 发表于 2018-3-19 16:26 | 显示全部楼层
我在编译结束之后出现了这样的错误:
CyDsFit aborted due to errors,please address all errors and rerun CyDsFit
请问 这样我应该怎么解决?
zyf部长 发表于 2018-3-19 16:29 | 显示全部楼层
首先我的存储目录不存在中文 而且我放在本地文件(C:\Documents and Settings\User\)里面依然出现同样的错误提示。
xxmmi 发表于 2018-3-19 16:32 | 显示全部楼层
上面一个错误是由于使用了现在不支持的组件。
 楼主| pangb 发表于 2018-3-19 16:47 | 显示全部楼层
其实还是不大明白,我再琢磨琢磨吧,多谢了哈,结贴了先
