[开发工具] MPLAB IDE x编译出问题
 楼主| lixianlong 发表于 2018-6-12 15:35 | 显示全部楼层 |阅读模式
MPLAB IDE x编译工程老出现下面的错误提示,但该工程在 MPLAB IDE v8.70是编译通过的。很是晕呢,到现在还不知道是什么问题,求大神们帮忙解决下,先谢了
make[2]: Leaving directory 'E:/Panther1_SRC_120312/Graphics/Egle/Egle.X'
nbproject/Makefile-default.mk:78: recipe for target '.build-conf' failed
make[1]: Leaving directory 'E:/Panther1_SRC_120312/Graphics/Egle/Egle.X'
nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed
ld/default/production/_ext/1431224913/Test_Released.o build/default/production/_ext/1431224913/TestGif.o build/default/production/_ext/1431224913/Tool_Pressed.o build/default/production/_ext/1431224913/Tool_Released.o -Wl,--defsym=__MPLAB_BUILD=1,--defsym=_min_heap_size=9216,-L..,-L.,-Map=dist/default/production/Egle.X.production.map, ...) failed.
make (e=87):
make[2]: *** [dist/default/production/Egle.X.production.hex] Error 87
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
