【招聘!!】Staff Mixed Signal Verification Engineer (#13165)
 楼主| 21ic小管家 发表于 2018-8-17 15:19 | 显示全部楼层 |阅读模式
JobTitle:Staff Mixed Signal Verification Engineer (#13165)
Numberof position: 1
Working experience: 5+ years withMaster's Degree or 7+ years with Bachelor Degree
Hiring Manager: SFX@cypress.com
CV Receiver: xin.yang@cypress.com
JobDescription:
1.    Work on mixed-signal/Finesimsimulation/verification of Programmable SoC project
2.    Create the Mixed-signal/Finesim verificationplan and test bench according to the Spec
3.    Verify/debug analog/digital design and fixthe issue with the original designer together
4.    Develop analog/digital toolkit (behavioralmodel, .lib view, LEF view etc) of mixed/analog blocks
5.    Work on Full chip analog DFT design and testcase development, analysis and simulation
6.    Other responsibilities include supportingother groups in the test, qualification and release to production
7.    Document the verification plan, coverage,implementation, and method.
Job Requirements:
1.    Very good English skills
2.    Takes initiative and sets high goals
3.    Smart and confident
4.    Self starter & ability to work in a teamenvironment as an individual contributor
5.    Track record of planning and delivering ownwork completely and on time
Education & WorkExperience:
1.    5+ years with Master's Degree or 7+ yearswith Bachelor Degree in EE/CE
2.    Experience on custom IC design skills
3.    Experience on Mixed-signal/Finesim SoCproduct with MCU and the peripheral IPs
4.    Knowledge with a wide range of analog IP suchas Band-Gap, OPAMP, Switch Cap, OSC, ADC, and so on.
5.    Understand digital verilog design and analogmodels.
6.    Experience on Memory design is plus
7.    LATCHUP and ESD knowledge is plus
8.    Experience in analog and digital simulationtools, ELDO, NANOSIM, and MODELSIM tools experience is plus.
9.    Proficiency in Perl, Tcl, Shell, assembly andC languages
2895
