[DCDC] 内置MOS同步开关型充电管理IC ZCC1307-4.2V/8.4V/12.6V
 楼主| mbgcn 发表于 2018-9-17 09:36 | 显示全部楼层 |阅读模式
Features
u Input voltage range 4V~18V
u Dynamic input current allocation for maximum charging rate
u 2.0A Maximum Charge Current
u No External MOSFETs and Blocking Diode Required
u Efficiency up to 90%
u Constant-Current/Constant-Voltage Operation with Thermal Regulation to Maximize Charge Rate Without Risk of Overheating
u Optional Battery Temperature Monitoring Before and During Charge Automatic Sleep Mode for Low-Power
u Over Current Protection
u Consumption Available in ESOP8
RoHS Compliant and 100% Lead (Pb)-Free
 楼主| mbgcn 发表于 2018-9-17 09:54 | 显示全部楼层
高效率,高精度,大电流
戈卫东 发表于 2018-9-17 10:23 | 显示全部楼层
再集成电池保护吧。。。。
戈卫东 发表于 2018-9-17 10:24 | 显示全部楼层
ESOP8有10个脚?
@justin 发表于 2018-9-17 17:17 | 显示全部楼层
4.4V的电池可以用么?
jjjyufan 发表于 2018-9-17 17:24 | 显示全部楼层
规格书放上来看看
