[应用相关] STM32控制语音识别SYN6288+合成模块程序YS-LDV7语音识别
 楼主| Diyer2015 发表于 2018-9-25 12:21 | 显示全部楼层 |阅读模式
#include "stm32f10x.h"
#include <stdio.h>
#include <string.h>
#include  "SYN6288.h"
#define RxBufferSize 10
void RCC_Configuration(void);
void GPIO_Configuration(void);
void NVIC_Configuration(void);
void USART_Configuration(void);
int fputc(int ch, FILE *f);
void delay_nms(u16 time);//延时子程序
extern void SYN_FrameInfo(uint8_t Music,uint8_t *HZdata);
unsigned char RxBuffer[RxBufferSize];
unsigned char CmdBuffer[RxBufferSize];
extern unsigned char Rx_Flag=0;
unsigned char RxCounter=0;
u16 i;
int main(void)
//USART_ITConfig(USART1, USART_IT_TXE, ENABLE); // 开启发送
RCC_Configuration();
NVIC_Configuration();
GPIO_Configuration();
USART_Configuration();
USART_ClearFlag(USART2,USART_FLAG_TC);//清发送结束位
  serial3_init();
while(USART_GetFlagStatus(USART2, USART_FLAG_TC)==RESET);
//  printf("打开LED灯,请输入LEDON!\n");
//  printf("关闭LED灯,请输入LEDOFF!\n");
//  printf("输入错误的话,LED灯闪烁3次!\n");
GPIO_SetBits(GPIOA,GPIO_Pin_8);//PA8置位,LED1灯灭
memset(CmdBuffer,10,0);
while(1)
if (Rx_Flag==1)
USART_ITConfig(USART2, USART_IT_RXNE, DISABLE); //关闭接收中断
Rx_Flag=0;
RxCounter=0;
if (strstr(CmdBuffer,"LEDOFF\r\n"))
delay_nms(1000);
SYN_FrameInfo(0,"灯已经关闭了");
else if(strstr(CmdBuffer,"LEDON\r\n"))
GPIO_ResetBits(GPIOA,GPIO_Pin_8);//PA8清零,LED1灯亮
delay_nms(1000);
SYN_FrameInfo(0,"灯已经打开了");
else
for (i=0;i<3;i++)
delay_nms(1000); GPIO_SetBits(GPIOA,GPIO_Pin_8);//PA8置位,LED1灯灭
delay_nms(200);
USART_ITConfig(USART2, USART_IT_RXNE, ENABLE); //开启接收中断,接收寄存器不空(RXNE=1)时产生中断
SystemInit();
//RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);//使能AFIO的时钟,串口属于复用功能
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);//使能GPIOA的时钟
RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2,ENABLE);//使能USART1的时钟, USART1挂接到APB2上。其他USART2-5挂接到APB1上
//RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1,ENABLE);
 楼主| Diyer2015 发表于 2018-9-25 12:22 | 显示全部楼层
GPIO_InitTypeDef GPIO_InitStructure;//声明GPIO初始化结构变量。
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3; //配置管脚PA10/USART1_RX
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮置输入
GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化PA10
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_2; //配置管脚PA9/USART1_TX
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP; //IO口配置为复用输出口
GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
GPIO_Init(GPIOA,&GPIO_InitStructure); //初始化PA9
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_8; //配置管脚8
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP; //IO口配置为推挽输出口
GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz; //工作频率50MHz
GPIO_Init(GPIOA,&GPIO_InitStructure); //初始化PA8口
void NVIC_Configuration(void) //NVIC配置
{ //配置NVIC相应的优先级位
NVIC_InitTypeDef NVIC_InitStructure;
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1); //优先级分组1(0:4,0位抢占优先级、4位子优先级)
NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn; //设置串口1中断
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; //抢占优先级 0
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
USART_InitTypeDef USART_InitStructure;
//子优先级为0
//串口中断使能
USART_InitStructure.USART_BaudRate = 9600;
USART_InitStructure.USART_WordLength = USART_WordLength_8b; //USART_WordLength_8b; //8 位数据
//USART_WordLength_9b; //9 位数据
USART_InitStructure.USART_StopBits = USART_StopBits_1;
//USART_StopBits_1 ;//在帧结尾传输 1 个停止位
//USART_StopBits_0.5;//在帧结尾传输 0.5 个停止位
//USART_StopBits_2 ;//在帧结尾传输 2 个停止位
//USART_StopBits_1.5;//在帧结尾传输 1.5 个停止位
USART_InitStructure.USART_Parity = USART_Parity_No;
//USART_Parity_No ;//奇偶失能
//USART_Parity_Even;//偶模式
//USART_Parity_Odd ;//奇模式
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
//USART_HardwareFlowControl_None; //硬件流控制失能
//USART_HardwareFlowControl_RTS; //发送请求 RTS使能
//USART_HardwareFlowControl_CTS; //清除发送 CTS使能
//USART_HardwareFlowControl_RTS_CTS;//RTS和 CTS使能
USART_InitStructure.USART_Mode = USART_Mode_Tx|USART_Mode_Rx;
//USART_Mode_Tx;//发送使能
//USART_Mode_Rx;//接收使能
USART_Init(USART2, &USART_InitStructure);//初始化串口
//USART_ITConfig(USART1, USART_IT_TXE, ENABLE); // 开启发送中断,发送寄存器空(TXE=1)时能产生中断
//串口的发送中断有两个,分别是:
// l发送数据寄存器空中断(TXE)
// l发送完成中断(TC)
USART_Cmd(USART2, ENABLE); //启动USART
 楼主| Diyer2015 发表于 2018-9-25 12:23 | 显示全部楼层
int fputc(int ch,FILE *f)
if(ch=='\n')
USART_SendData(USART2,'\r');
USART_SendData(USART2,ch);
return ch;
void delay_nms(u16 time)//延时子程序
{ u16 i=0;
while(time--)
{ i=12000; //自己定义
while(i--) ;
void USART2_IRQHandler(void) //串口1 中断服务程序
unsigned int i=0;
if (USART_GetITStatus(USART2, USART_IT_RXNE) != RESET) //判断接收寄存器是否非空
{//如果接收寄存器非空,说明检测到中断读入
RxBuffer[RxCounter++]=USART_ReceiveData(USART2); // Read one byte from the receive data register
if (RxBuffer[RxCounter-1]=='\n') //如果检测到换行,则设置接收标志为1.
// \n:换行,光标到下行行首;
// \r:回车,光标到本行行首
Rx_Flag=1;
for (i=0;i<RxCounter;i++)//把接收到的数据缓存到CmdBuffer中
CmdBuffer[i]=RxBuffer[i];
CmdBuffer[RxCounter]=0; //发送缓冲区结束符
RxCounter=0;
if(RxCounter == RxBufferSize) //如果接收缓冲区满了。
Rx_Flag=1;
CmdBuffer[RxCounter]=0; //接收命令缓冲区结束符
RxCounter=0;
labasi 发表于 2018-10-12 12:43 | 显示全部楼层
是否还需要录入啊
 楼主| Diyer2015 发表于 2018-10-12 12:52 | 显示全部楼层
是否还需要录入啊
按道理应该需要录入!
xiaoqizi 发表于 2018-10-12 13:49 | 显示全部楼层
识别率高不高
MMMMMyyy 发表于 2021-3-19 10:01 | 显示全部楼层
请问有这个项目的YS-LDV7的程序吗?
