[应用相关] 求一个定时器B的pwm例程
 楼主| Listate 发表于 2018-10-24 20:27 | 显示全部楼层 |阅读模式
#include "msp430x54x.h"
void main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  P1DIR |= 0x01;                            // Set P1.0 to output direction
  TBCTL = TBSSEL_1 + MC_2 + TBCLR + TBIE;   // ACLK, contmode, clear TBR,
                                            // enable interrupt
  __bis_SR_register(LPM3_bits + GIE);       // Enter LPM3, enable interrupts
  __no_operation();                         // For debugger
// Timer_B7 Interrupt Vector (TBIV) handler
#pragma vector=TIMERB1_VECTOR
__interrupt void TIMERB1_ISR(void)
  /* Any access, read or write, of the TBIV register automatically resets the
  highest "pending" interrupt flag. */
  switch( __even_in_range(TBIV,14) )
    case  0: break;                          // No interrupt
    case  2: break;                          // CCR1 not used
    case  4: break;                          // CCR2 not used
    case  6: break;                          // CCR3 not used
    case  8: break;                          // CCR4 not used
    case 10: break;                          // CCR5 not used
    case 12: break;                          // CCR6 not used
    case 14: P1OUT ^= 0x01;                  // overflow
            break;
    default: break;
Mozarts 发表于 2018-10-24 20:30 | 显示全部楼层
void main( void )
   // Stop watchdog timer to prevent time out reset
   FLL_CTL0 |= XCAP14PF;                   // 匹配14pf电容
   __delay_cycles(20000);                    //延时20ms,等待晶振起振稳定
   do
     IFG1 &= ~OFIFG;
     for(unsigned int i=5000;i>0;i--);
   while(IFG1&OFIFG);
   TACTL |= TASSEL_1 + MC_1 + TACLR;
   TACCR0 = 32767;                            //T=1s
   TACCTL1 |= OUTMOD_7;
   TACCR1 = 19661;                           //占空比60%
   P1DIR |= 0x04;
   P1SEL |= 0x04;
   while(1);
_gege 发表于 2018-10-24 20:31 | 显示全部楼层
void main()
    ClkInit();
    TAPwmInit('A',1,'P','P');   //将定时器TA初始化成为PWM发生器
                  //时钟源=ACLK ; 无分频;  通道1和通道2均设为高电平模式。
    TAPwmSetPeriod(500);        //通道1/2的PWM方波周期均设为500个时钟周期
    TAPwmSetDuty(1,200);        //1通道 有效200个时钟周期
    TAPwmSetPermill(2,200);     //2通道 20.0%
    LPM0;
Edisons 发表于 2018-10-24 20:33 | 显示全部楼层
5529舵机的PWM信号控制的程序吗?
laozhongyi 发表于 2018-10-24 20:34 | 显示全部楼层
设定一个变量来选择初始占空比,然后通过Timer_B定时1s,每隔一秒
wanglaojii 发表于 2018-10-24 20:37 | 显示全部楼层
TB可以输出6路完整的PWM波形。
zhouhuanの 发表于 2018-10-24 20:38 | 显示全部楼层
void main(void)
   P1DIR |= 0x0C; // P1.2 and P1.3 output
   P1SEL |= 0x0C; // P1.2 and P1.3 TA1/2 options
   Init_TIMER_B();
   TACTL = TASSEL_2 + TACLR; // SMCLK, up mode
   CCR0 = 512-1; // PWM Period
   CCTL1 = OUTMOD_7 ; // CCR1 reset/set
   CCTL2 = OUTMOD_7 ; //CCR2 reset/set
   if(v==5)
     CCR1 = 128; // CCR1 PWM duty cycle
     CCR2 = 384; // CCR2 PWM duty cycle
   else if (v==12)
     CCR1 = 384; // CCR1 PWM duty cycle
     CCR2 = 128; // CCR2 PWM duty cycle
   else
   TACTL |= MC_1;      // Start Timer_A in up mode
   TBCTL |= MC_1;      // Start Timer_B in up mode
   _EINT();         //开全局中断
   _BIS_SR(LPM0_bits); // Enter LPM0
void  Init_TIMER_B()
    TBCTL |= TBSSEL0 +TBCLR; //ACLK
    TBCCTL0 = CCIE;
    TBCCR0 =32768;  //定时1s
handleMessage 发表于 2018-10-24 20:40 | 显示全部楼层
定时器是单片机常用的其本设备,用来产生精确计时或是其他功能
bbapple 发表于 2018-10-24 20:41 | 显示全部楼层
详细参考示例工程和main.c。
Rospiers 发表于 2018-10-27 23:02 | 显示全部楼层
TB可以输出6路完整的PWM波形
stm32jy 发表于 2018-10-27 23:50 | 显示全部楼层
6路PWM很强啊,我输出一路的
也可以玩下PWM捕获
获取上下沿的持续时间
Rollo 发表于 2018-10-28 15:06 | 显示全部楼层
6路PWM相互之间能同时输出吗
paotangsan 发表于 2018-11-6 14:47 | 显示全部楼层
涨知识了 谢啦
