[STM32F1] 驱动HT1621,液晶屏显示抖动
 楼主| 175192387 发表于 2018-12-5 16:48 | 显示全部楼层 |阅读模式
void lcd_init(void)        //初始化
        HT1621_CS_0;        //CS = 0;
        write_mode(COM);                //命令模式
        write_command(0x01);        //Enable System
        write_command(0x03);        //Enable Bias
        write_command(0x04);        //Disable Timer
        write_command(0x05);        //Disable WDT
        write_command(0x08);        //Tone OFF
        write_command(0x18);        //on-chip RC震荡
        write_command(0x29);        //1/4Duty 1/3Bias
        write_command(0x80);        //Disable IRQ
        write_command(0x40);        //Tone Frequency 4kHZ 声音频率
        write_command(0xE3);        //Normal Mode
         /*write_command(BIAS);
  write_command(RC256);  //使用内部振荡器
  write_command(SYSDIS);
  write_command(WDTDIS);
  write_command(SYSEN);
  write_command(LCDON); */
        HT1621_CS_1;        //CS = 1;
void lcd_show(void)
         uchar i;
         uchar sets[3];
         for(i=0;i<15;i++)
                 show_buf[i]=0;//0xff;
         lcd_show_data(show_buf);
显示闪动非常厉害
734774645 发表于 2018-12-5 22:15 | 显示全部楼层
  1. unsigned char Lcdram[32]=
  2.     {
  3.                 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  4.                 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  5.                 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  6.                 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
  7.     };
  8. const unsigned char Wendu[] = //温度0-9
  9.     {
  10.     0X5F, 0X50, 0X3D, 0X79, 0X72, 0X6B, 0X6F, 0X51, 0X7F, 0X7B
  11.     };
  12. ///////////////////////////////////////////////////驱动函数
  13. /*
  14. *    LCD 模式写入
  15. *    入口:MODE :COM(命令模式) DAT(数据模式)
  16. *    出口:void
  17. */
  18. void write_mode(unsigned char MODE)    //写入模式,数据or命令
  19. {
  20.     GPIO_ResetBits(GPIOB, HT1621_WR);                                //    RW = 0;
  21.     delay_us(10);
  22.     GPIO_SetBits(GPIOB, HT1621_DATA);                                    //    DA = 1;
  23.     GPIO_SetBits(GPIOB, HT1621_WR);                                    //    RW = 1;
  24.     delay_us(10);
  25.     GPIO_ResetBits(GPIOB, HT1621_WR);                                //    RW = 0;
  26.     delay_us(10);
  27.     GPIO_ResetBits(GPIOB, HT1621_DATA);                                //    DA = 0;
  28.     GPIO_SetBits(GPIOB, HT1621_WR);                                    //    RW = 1;
  29.     delay_us(10);
  30.     GPIO_ResetBits(GPIOB, HT1621_WR);                                //    RW = 0;
  31.     delay_us(10);
  32.     if (0 == MODE)
  33.     {
  34.         GPIO_ResetBits(GPIOB, HT1621_DATA);                            //    DA = 0;
  35.     }
  36.     else
  37.     {
  38.         GPIO_SetBits(GPIOB, HT1621_DATA);                                //    DA = 1;
  39.     }
  40.     delay_us(10);
  41.     GPIO_SetBits(GPIOB, HT1621_WR);                                    //    RW = 1;
  42.     delay_us(10);
  43. }
  44. /*
  45. *    LCD 命令写入函数
  46. *    入口:cbyte ,控制命令字
  47. *    出口:void
  48. */
  49. void write_command(unsigned char Cbyte)
  50. {
  51.     unsigned char i = 0;
  52.     for (i = 0; i < 8; i++)
  53.     {
  54.         GPIO_ResetBits(GPIOB, HT1621_WR);
  55.         if ((Cbyte >> (7 - i)) & 0x01)
  56.         {
  57.             GPIO_SetBits(GPIOB, HT1621_DATA);
  58.         }
  59.         else
  60.         {
  61.             GPIO_ResetBits(GPIOB, HT1621_DATA);
  62.         }
  63.         delay_us(10);
  64.         GPIO_SetBits(GPIOB, HT1621_WR);
  65.         delay_us(10);
  66.     }
  67.     GPIO_ResetBits(GPIOB, HT1621_WR);
  68.     delay_us(10);
  69.     GPIO_ResetBits(GPIOB, HT1621_DATA);
  70.     GPIO_SetBits(GPIOB, HT1621_WR);
  71.     delay_us(10);
  72. }
  73. /*
  74. *    LCD 地址写入函数
  75. *    入口:cbyte,地址
  76. *    出口:void
  77. */
  78. void write_address(unsigned char Abyte)
  79. {
  80.     unsigned char i = 0;
  81.     Abyte = Abyte << 2;
  82.     for (i = 0; i < 6; i++)
  83.     {
  84.         GPIO_ResetBits(GPIOB, HT1621_WR);
  85.         //delay_us(10);
  86.         if ((Abyte >> (7 - i)) & 0x01)
  87.         {
  88.             GPIO_SetBits(GPIOB, HT1621_DATA);
  89.         }
  90.         else
  91.         {
  92.             GPIO_ResetBits(GPIOB, HT1621_DATA);
  93.         }
  94.         delay_us(10);
  95.         GPIO_SetBits(GPIOB, HT1621_WR);
  96.         delay_us(10);
  97.     }
  98.
  99. }
  100. /*
  101. *    LCD 数据写入函数
  102. *    入口:Dbyte,数据
  103. *    出口:void
  104. */
  105. void write_data_8bit(unsigned char Dbyte)
  106. {
  107.     int i = 0;
  108.     for (i = 0; i < 8; i++)
  109.     {
  110.         GPIO_ResetBits(GPIOB, HT1621_WR);
  111.         delay_us(10);
  112.         if ((Dbyte >> (7 - i)) & 0x01)
  113.         {
  114.             GPIO_SetBits(GPIOB, HT1621_DATA);
  115.         }
  116.         else
  117.         {
  118.             GPIO_ResetBits(GPIOB, HT1621_DATA);
  119.         }
  120.         delay_us(10);
  121.         GPIO_SetBits(GPIOB, HT1621_WR);
  122.         delay_us(10);
  123.     }
  124. }
  125. void write_data_4bit(unsigned char Dbyte)
  126. {
  127.     int i = 0;
  128.     for (i = 0; i < 4; i++)
  129.     {
  130.         GPIO_ResetBits(GPIOB, HT1621_WR);
  131.         //delay_us(10);
  132.         if ((Dbyte >> (3 - i)) & 0x01)
  133.         {
  134.             GPIO_SetBits(GPIOB, HT1621_DATA);
  135.         }
  136.         else
  137.         {
  138.             GPIO_ResetBits(GPIOB, HT1621_DATA);
  139.         }
  140.         delay_us(10);
  141.         GPIO_SetBits(GPIOB, HT1621_WR);
  142.         delay_us(10);
  143.     }
  144. }
  145. //1621初始化
  146. void ht1621_init(void)
  147. {
  148.         GPIO_InitTypeDef GPIO_InitStructure;// declare the structure
  149.         GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable, ENABLE);
  150.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB, ENABLE);
  151.         memset(&GPIO_InitStructure, 0, sizeof(GPIO_InitTypeDef));
  152.         GPIO_InitStructure.GPIO_Pin =  HT1621_WR | HT1621_DATA ;//| HT1621_IRQ
  153.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  154.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  155.         GPIO_Init(GPIOB, &GPIO_InitStructure);
  156.         memset(&GPIO_InitStructure, 0, sizeof(GPIO_InitTypeDef));
  157.         GPIO_InitStructure.GPIO_Pin = HT1621_CS ;//| HT1621_IRQ
  158.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  159.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  160.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  161. }
  162. /*
  163. *    LCD 初始化,对lcd自身做初始化设置
  164. *    入口:void
  165. *    出口:void
  166. */
  167. void lcd_init(void)
  168. {
  169.     //////////////////////////////////////////////////////
  170.     GPIO_SetBits(GPIOA, HT1621_CS);
  171.     GPIO_SetBits(GPIOB, HT1621_WR);
  172.     GPIO_SetBits(GPIOB, HT1621_DATA);
  173.     for (ii=0;ii<10000;ii++)
  174.     {for(j=10;j>0;j--);}
  175.     //////////////////////////////////////////////////////
  176.     GPIO_ResetBits(GPIOA, HT1621_CS);        //CS = 0;
  177.     //delay_us(10);
  178.     for (ii=0;ii<10000;ii++)
  179.     {for(j=10;j>0;j--);}
  180.     write_mode(COMMAND);    //命令模式
  181.     write_command(0x01);    //Enable System
  182.     write_command(0x03);    //Enable Bias
  183.     write_command(0x04);    //Disable Timer
  184.     write_command(0x05);    //Disable WDT
  185.     write_command(0x08);    //Tone OFF
  186.     write_command(0x18);    //on-chip RC震荡
  187.     write_command(0x29);    //1/4Duty 1/3Bias
  188.     write_command(0x80);    //Disable IRQ
  189.     write_command(0x40);    //Tone Frequency 4kHZ
  190.     write_command(0xE3);    //Normal Mode
  191.     GPIO_SetBits(GPIOA, HT1621_CS);  //CS = 1;
  192. }
  193. /*
  194. *    LCD 清屏函数
  195. *    入口:void
  196. *    出口:void
  197. */
  198. void lcd_clr(void)
  199. {
  200.     write_addr_dat_n(0x0, 0x00, 32);//15
  201. }
  202. //用于温度区域写数据
  203. void write_addr_dat_n_wendu(unsigned char _addr, unsigned char _dat, unsigned char n)
  204. {
  205.
  206.     unsigned char i = 0;
  207.     unsigned char _dat_temp1,_dat_temp2;
  208.
  209.     //WriteLcdram(_addr, _dat);
  210.
  211.
  212.     GPIO_ResetBits(GPIOA, HT1621_CS);                                // CS = 0;
  213.     write_mode(DAT);
  214.
  215.     if(Lcdram[_addr]==0x00)
  216.     {
  217.         WriteLcdram(_addr, _dat);
  218.     }
  219.         if((_addr%2)==0)
  220.         {
  221.             _dat_temp1=Lcdram[_addr];
  222.             _dat_temp2=(_dat_temp1&0x08)|_dat;
  223.
  224.             write_address(_addr);
  225.             for (i = 0; i < n; i++)
  226.         {
  227.             write_data_4bit(_dat_temp2);
  228.         }
  229.         GPIO_SetBits(GPIOA, HT1621_CS);                                    //CS = 1;
  230.
  231.         }
  232.         else if((_addr%2)!=0)
  233.         {
  234.             write_address(_addr);
  235.             for (i = 0; i < n; i++)
  236.         {
  237.             write_data_4bit(_dat);
  238.         }
  239.         GPIO_SetBits(GPIOA, HT1621_CS);
  240.         }
  241.
  242.         WriteLcdram(_addr, _dat_temp2);
  243. }
  244. //用于湿度区域写数据
  245. void write_addr_dat_n_shidu(unsigned char _addr, unsigned char _dat, unsigned char n)
  246. {
  247.
  248.     unsigned char i = 0;
  249.     unsigned char _dat_temp1,_dat_temp2;
  250.
  251.     //WriteLcdram(_addr, _dat);
  252.
  253.
  254.     GPIO_ResetBits(GPIOA, HT1621_CS);                                // CS = 0;
  255.     write_mode(DAT);
  256.
  257.     if(Lcdram[_addr]==0x00)
  258.     {
  259.         WriteLcdram(_addr, _dat);
  260.     }
  261.         if((_addr%2)==0)
  262.         {
  263.             _dat_temp1=Lcdram[_addr];
  264.             _dat_temp2=(_dat_temp1&0x01)|_dat;
  265.
  266.             write_address(_addr);
  267.             for (i = 0; i < n; i++)
  268.         {
  269.             write_data_4bit(_dat_temp2);
  270.         }
  271.         GPIO_SetBits(GPIOA, HT1621_CS);                                    //CS = 1;
  272.
  273.         }
  274.         else if((_addr%2)!=0)
  275.         {
  276.             write_address(_addr);
  277.             for (i = 0; i < n; i++)
  278.         {
  279.             write_data_4bit(_dat);
  280.         }
  281.         GPIO_SetBits(GPIOA, HT1621_CS);
  282.         }
  283.
  284.         WriteLcdram(_addr, _dat_temp2);
  285. }
  286. //用于底部数字写数据
  287. void write_addr_dat_n_others(unsigned char _addr, unsigned char _dat, unsigned char n)
  288. {
  289.
  290.     unsigned char i = 0;
  291.     unsigned char _dat_temp1,_dat_temp2;
  292.     GPIO_ResetBits(GPIOA, HT1621_CS);                                // CS = 0;
  293.     write_mode(DAT);
  294.
  295.     if(Lcdram[_addr]==0x00)
  296.     {
  297.         WriteLcdram(_addr, _dat);
  298.
  299.     }
  300.         if((_addr%2)==0)
  301.         {
  302.             _dat_temp1=Lcdram[_addr];
  303.             _dat_temp2=(_dat_temp1&0x01)|_dat;
  304.
  305.             write_address(_addr);
  306.             for (i = 0; i < n; i++)
  307.         {
  308.             write_data_4bit(_dat_temp2);
  309.         }
  310.         GPIO_SetBits(GPIOA, HT1621_CS);                                    //CS = 1;
  311.
  312.         }
  313.         else if((_addr%2)!=0)
  314.         {
  315.             write_address(_addr);
  316.             for (i = 0; i < n; i++)
  317.         {
  318.             write_data_4bit(_dat);
  319.         }
  320.         GPIO_SetBits(GPIOA, HT1621_CS);
  321.         }
  322.
  323.         //WriteLcdram(_addr, _dat);
  324.         WriteLcdram(_addr, _dat_temp2);
  325. }
  326. //用于字符写数据
  327. void write_addr_dat_n_char(unsigned char _addr, unsigned char _dat, unsigned char state)
  328. {
  329.
  330.     unsigned char i = 0;
  331.     unsigned char _dat_temp1,_dat_temp2;
  332.
  333.         GPIO_ResetBits(GPIOA, HT1621_CS);                                // CS = 0;
  334.          write_mode(DAT);
  335.
  336.                 _dat_temp1=Lcdram[_addr];
  337.             if(state==1)
  338.             {
  339.
  340.                 _dat_temp2=(_dat_temp1|_dat);
  341.             }
  342.             else if(state==0)
  343.             {
  344.                 _dat_temp2=(_dat_temp1&(~_dat));
  345.             }
  346.                  write_address(_addr);
  347.
  348.                 for (i = 0; i < 1; i++)
  349.             {
  350.                 write_data_4bit(_dat_temp2);
  351.             }
  352.             GPIO_SetBits(GPIOA, HT1621_CS);                                    //CS = 1;
  353.             WriteLcdram(_addr, _dat_temp2);
  354.
  355.
  356.
  357.
  358. }
  359. //显示温度
  360. //入口:pos,显示位置,地址0、2、4分别为从右到左的三个数字
  361. //            num:要显示的一位数
  362. void Display_Wendu_1(unsigned char add, unsigned char num )
  363. {
  364.     unsigned char n,i,j;
  365.     n=getChr_Wendu(num);
  366.     i=(n&0xF0)>>4;
  367.     j=n&0x0F;
  368.     write_addr_dat_n_wendu(add,i,1);
  369.     write_addr_dat_n_wendu(add+1,j,1);
  370.
  371. }
  372. //温度数据转换,lcd.c内部使用
  373. unsigned char getChr_Wendu(unsigned char c)
  374. {
  375.      unsigned char i;
  376.         for ( i = 0; i < 10; ++i)
  377.         {
  378.             if (c == i)
  379.             {
  380.                 return Wendu[i];
  381.             }
  382.         }
  383.     }
  384. //更新lcdram数组
  385. void WriteLcdram(unsigned char add, unsigned char data)
  386. {
  387.
  388.     Lcdram[add]=data;
  389.
  390. }
磨砂 发表于 2018-12-7 13:54 | 显示全部楼层
是不是刷新频率太高了
晓伍 发表于 2018-12-7 13:59 | 显示全部楼层
抖动的有规律吗
天灵灵地灵灵 发表于 2018-12-8 21:01 | 显示全部楼层
是闪烁啊还是抖啊,两个概念
如果是看着闪烁,那是你频率太低。
wanduzi 发表于 2018-12-9 16:46 | 显示全部楼层
我还以为是1602液晶模块呢。
