[应用相关] Stm32F407ZGT6 串口通迅 usart2(转载)
 楼主| 八层楼 发表于 2018-12-14 10:30 | 显示全部楼层 |阅读模式
正点原子的开发板,一定要注意跳线帽
串口2
usart2.h
//STM32F407 zgt6 串口2
#ifndef __USART2_H
#define __USART2_H
#include "sys.h"
#define USART2_MAX_RECV_LEN 200
#define USART2_MAX_SEND_LEN 200
extern u8 USART2_RX_buf[USART2_MAX_RECV_LEN];
extern u8 USART2_TX_buf[USART2_MAX_SEND_LEN];
extern u16 USART2_RX_STA;       //接收状态标记
void uart2_init(u32 bound);
#endif
usart2.c
#include "usart2.h"
u16 USART2_RX_STA=0;//接收状态标记
/* 初始化串口过程
1.串口时钟使能
2.设置引脚复用
3.GPIO端口初始化
4.串口参数初始化
5.初始化NVIC并且开启中断2
6.使能串口
//初始化IO 串口2
//bound:波特率
   //GPIO端口设置
USART_InitTypeDef USART_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA,ENABLE); //使能GPIOA时钟
RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2,ENABLE);//使能USART2时钟
//串口1对应引脚复用映射
GPIO_PinAFConfig(GPIOA,GPIO_PinSource2,GPIO_AF_USART2); //GPIOA2复用为USART2
GPIO_PinAFConfig(GPIOA,GPIO_PinSource3,GPIO_AF_USART2); //GPIOA3复用为USART2
//USART2端口配置
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2 | GPIO_Pin_3; //GPIOA2与GPIOA3
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;//复用功能
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //速度50MHz
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //推挽复用输出
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; //上拉
GPIO_Init(GPIOA,&GPIO_InitStructure); //初始化PA2,PA3
   //USART2 初始化设置
USART_InitStructure.USART_BaudRate = bound;//波特率设置
USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长为8位数据格式
USART_InitStructure.USART_StopBits = USART_StopBits_1;//一个停止位
USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验位
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件数据流控制
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //收发模式
USART_Init(USART2, &USART_InitStructure); //初始化串口2
NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;//串口2中断通道
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3;//抢占优先级3 数值越小优先级越高
NVIC_InitStructure.NVIC_IRQChannelSubPriority =3; //子优先级3,响应优先级
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道使能
NVIC_Init(&NVIC_InitStructure); //根据指定的参数初始化VIC寄存器、
USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);//开启接收中断
USART_Cmd(USART2, ENABLE);  //使能串口2
void USART2_IRQHandler(void)
u8 Res;
if(USART_GetITStatus(USART2, USART_IT_RXNE) != RESET)  //接收中断(接收到的数据必须是0x0d 0x0a结尾)
Res =USART_ReceiveData(USART2);//(USART2->DR); //读取接收到的数据
USART_SendData(USART2,Res);//将收到的发回去了
main.c
#include "sys.h"
#include "delay.h"
//#include "usart1.h"
#include "usart2.h"
#include "led.h"
int main(void)
u8 t=0,len=0;
u16 times=0;
char str[]={'u','1','w','a','i','t','\r','\n'};
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
delay_init(168);//168 MHz
LED_Init();
LED1=0;//位带操作点灯 sys.h
uart2_init(115200);
while(1)
if (USART2_RX_STA&0x8000)//接收完成
len=USART2_RX_STA&0x3fff;//长度不能超255,因为len是u8
for(t=0;t<len;t++)
USART2->DR=USART2_RX_buf[t];
while((USART2->SR & 0x40)==0);//等待发送结束
USART2_RX_STA=0;
else
times++;
if(times %500==0)//5sec
for(t=0;t<sizeof(str);t++)
USART2->DR=str[t];
LED1=!LED1;
delay_ms(10);
以上必须在模板工程的配置情况下才能运行,本人验证以上代码ok
