1. 下载 boost 代码,解压
2. 在当前目录下执行:
- D:\tools\boost_1_69_0>bootstrap.bat mingw
然后当前目录会有文件生成:
- Building Boost.Build engine
- Bootstrapping is done. To build, run:
- .\b2
- To adjust configuration, edit 'project-config.jam'.
- Further information:
- - Command line help:
- .\b2 --help
- - Getting started guide:
- http://boost.org/more/getting_started/windows.html
- - Boost.Build documentation:
- http://www.boost.org/build/doc/html/index.html
让后用生成的 b2.exe:
- D:\tools\boost_1_69_0>b2.exe --prefix=d:\tools\boost_1_69_0 --build-type=complet
- e toolset=gcc threading=multi
