Commit MessageRavi Shankar JonnalagaddaAug. 8, 2017, 11:12 a.m.
Binding explaining devicetree usage for using Root DMA capability of ZynqMPSoCSigned-off-by: Ravi Shankar Jonnalagadda <vjonnal@xilinx.com>--- .../devicetree/bindings/dma/xilinx/ps-pcie-dma.txt | 67 ++++++++++++++++++++++ 1 file changed, 67 insertions(+) create mode 100644 Documentation/devicetree/bindings/dma/xilinx/ps-pcie-dma.txt
Patchdiff mbox
diff --git a/Documentation/devicetree/bindings/dma/xilinx/ps-pcie-dma.txt b/Documentation/devicetree/bindings/dma/xilinx/ps-pcie-dma.txtnew file mode 100644index 0000000..acdcc44--- /dev/null+++ b/Documentation/devicetree/bindings/dma/xilinx/ps-pcie-dma.txt@@ -0,0 +1,67 @@ +* Xilinx PS PCIe Root DMA++Required properties:+- compatible: Should be "xlnx,ps_pcie_dma-1.00.a"+- reg: Register offset for Root DMA channels+- reg-names: Name for the register. Should be "ps_pcie_regbase"+- interrupts: Interrupt pin for Root DMA+- interrupt-names: Name for the interrupt. Should be "ps_pcie_rootdma_intr"+- interrupt-parent: Should be gic in case of zynqmp+- rootdma: Indicates this platform device is root dma.+ This is required as the same platform driver will be invoked by pcie end points too+- dma_vendorid: 16 bit PCIe device vendor id.+ This can be later used by dma client for matching while using dma_request_channel+- dma_deviceid: 16 bit PCIe device id+ This can be later used by dma client for matching while using dma_request_channel+- numchannels: Indicates number of channels to be enabled for the device.+ Valid values are from 1 to 4 for zynqmp+- ps_pcie_channel : One for each channel to be enabled.+ This array contains channel specific properties.+ Index 0: Direction of channel+ Direction of channel can be either PCIe Memory to AXI memory i.e., Host to Card or+ AXI Memory to PCIe memory i.e., Card to Host+ PCIe to AXI Channel Direction is represented as 0x1+ AXI to PCIe Channel Direction is represented as 0x0+ Index 1: Number of Buffer Descriptors+ This number describes number of buffer descriptors to be allocated for a channel+ Index 2: Number of Queues+ Each Channel has four DMA Buffer Descriptor Queues.+ By default All four Queues will be managed by Root DMA driver.+ User may choose to have only two queues either Source and it's Status Queue or+ Destination and it's Status Queue to be handled by Driver.+ The other two queues need to be handled by user logic which will not be part of this driver.+ All Queues on Host is represented by 0x4+ Two Queues on Host is represented by 0x2+ Index 3: Coalesce Count+ This number indicates the number of transfers after which interrupt needs to+ be raised for the particular channel. The allowed range is from 0 to 255+ Index 4: Coalesce Count Timer frequency+ This property is used to control the frequency of poll timer. Poll timer is+ created for a channel whenever coalesce count value (>= 1) is programmed for the particular+ channel. This timer is helpful in draining out completed transactions even though interrupt is+ not generated.++Client Usage:+ DMA clients can request for these channels using dma_request_channel API+++Xilinx PS PCIe Root DMA node Example+++++++++++++++++++++++++++++++++++++++ pci_rootdma: rootdma@fd0f0000 {+ compatible = "xlnx,ps_pcie_dma-1.00.a";+ reg = <0x0 0xfd0f0000 0x0 0x1000>;+ reg-names = "ps_pcie_regbase";+ interrupts = <0 117 4>;+ interrupt-names = "ps_pcie_rootdma_intr";+ interrupt-parent = <&gic>;+ rootdma;+ dma_vendorid = /bits/ 16 <0x10EE>;+ dma_deviceid = /bits/ 16 <0xD021>;+ numchannels = <0x4>;+ #size-cells = <0x5>;+ ps_pcie_channel0 = <0x1 0x7CF 0x4 0x0 0x3E8>;+ ps_pcie_channel1 = <0x0 0x7CF 0x4 0x0 0x3E8>;+ ps_pcie_channel2 = <0x1 0x7CF 0x4 0x0 0x3E8>;+ ps_pcie_channel3 = <0x0 0x7CF 0x4 0x0 0x3E8>;+ };
