_root const APP_INTVECT_ELEM __vector_table[] @ ".intvec" = {
{ .Ptr = (void *)__sfe( "CSTACK" )}, /* 0, SP start value. */
__iar_program_start, /* 1, PC start value. */
App_NMI_ISR, /* 2, NMI. */
App_Fault_ISR, /* 3, Hard Fault. */
App_MemFault_ISR, /* 4, Memory Management. */
App_BusFault_ISR, /* 5, Bus Fault. */
App_UsageFault_ISR, /* 6, Usage Fault. */
App_Spurious_ISR, /* 7, Reserved. */
App_Spurious_ISR, /* 8, Reserved. */
App_Spurious_ISR, /* 9, Reserved. */
App_Spurious_ISR, /* 10, Reserved. */
App_Spurious_ISR, /* 11, SVCall. */
App_Spurious_ISR, /* 12, Debug Monitor. */
App_Spurious_ISR, /* 13, Reserved. */
OS_CPU_PendSVHandler, /* 14, PendSV Handler. */
OS_CPU_SysTickHandler, /* 15, uC/OS-II Tick ISR Handler. */
向量表是这样写的吗..
能不能给我工程研究一下.
