[demo程序] 【转载】DES加密解密算法C语言代码实现
 楼主| merry_zsp 发表于 2019-10-31 09:52 | 显示全部楼层 |阅读模式
  1. #include<stdio.h>
  2. #include<string.h>
  3. #include<stdlib.h>
  4. /*------------------------
  5.      定义枚举型全局变量
  6. ------------------------*/
  7. typedef enum
  8.   {
  9.     false = 0,
  10.     true  = 1
  11.   } bool;
  12.
  13.   // 十六轮子密钥
  14. static bool SubKey[16][48]={0};
  15.
  16. /*---------------------*/
  17. /*-------------------------------------------------------------
  18.      各种置换表
  19. -------------------------------------------------------------*/
  20. // IP置换表
  21. const char IP_Table[64]={
  22. 58,50,42,34,26,18,10, 2,60,52,44,36,28,20,12, 4,
  23. 62,54,46,38,30,22,14, 6,64,56,48,40,32,24,16, 8,
  24. 57,49,41,33,25,17, 9, 1,59,51,43,35,27,19,11, 3,
  25. 61,53,45,37,29,21,13, 5,63,55,47,39,31,23,15, 7
  26. };
  27. // IP-1置换表
  28. const char IPR_Table[64]={
  29. 40, 8,48,16,56,24,64,32,39, 7,47,15,55,23,63,31,
  30. 38, 6,46,14,54,22,62,30,37, 5,45,13,53,21,61,29,
  31. 36, 4,44,12,52,20,60,28,35, 3,43,11,51,19,59,27,
  32. 34, 2,42,10,50,18,58,26,33, 1,41, 9,49,17,57,25
  33. };
  34. // E扩展表
  35. static char E_Table[48]={
  36. 32, 1, 2, 3, 4, 5, 4, 5, 6, 7, 8, 9,
  37.   8, 9,10,11,12,13,12,13,14,15,16,17,
  38.     16,17,18,19,20,21,20,21,22,23,24,25,
  39.     24,25,26,27,28,29,28,29,30,31,32, 1
  40. };
  41. // PC1置换表
  42. static char PC1_Table[56]={
  43. 57,49,41,33,25,17, 9, 1,58,50,42,34,26,18,
  44. 10, 2,59,51,43,35,27,19,11, 3,60,52,44,36,
  45. 63,55,47,39,31,23,15, 7,62,54,46,38,30,22,
  46. 14, 6,61,53,45,37,29,21,13, 5,28,20,12, 4
  47. };
  48. // pc2表
  49. static char PC2_Table[48]={
  50. 14,17,11,24, 1, 5, 3,28,15, 6,21,10,
  51. 23,19,12, 4,26, 8,16, 7,27,20,13, 2,
  52. 41,52,31,37,47,55,30,40,51,34,33,48,
  53. 44,49,39,56,34,53,46,42,50,36,29,32
  54. };
  55. //  移位表
  56. static char Move_Table[16]={
  57.   1, 1, 2, 2, 2, 2, 2, 2, 1, 2, 2, 2, 2, 2, 2, 1
  58. };
  59. // S盒
  60. static char S_Box[8][4][16]={
  61. //S1
  62. 14, 4,13, 1, 2,15,11, 8, 3,10, 6,12, 5, 9, 0, 7,
  63.   0,15, 7, 4,14, 2,13, 1,10, 6,12,11, 9, 5, 3, 8,
  64.   4, 1,14, 8,13, 6, 2,11,15,12, 9, 7, 3,10, 5, 0,
  65. 15,12, 8, 2, 4, 9, 1, 7, 5,11, 3,14,10, 0, 6,13,
  66. //S2
  67. 15, 1, 8,14, 6,11, 3, 4, 9, 7, 2,13,12, 0, 5,10,
  68.   3,13, 4, 7,15, 2, 8,14,12, 0, 1,10, 6, 9,11, 5,
  69.   0,14, 7,11,10, 4,13, 1, 5, 8,12, 6, 9, 3, 2,15,
  70. 13, 8,10, 1, 3,15, 4, 2,11, 6, 7,12, 0, 5,14, 9,
  71. //S3
  72. 10, 0, 9,14, 6, 3,15, 5, 1,13,12, 7,11, 4, 2, 8,
  73. 13, 7, 0, 9, 3, 4, 6,10, 2, 8, 5,14,12,11,15, 1,
  74. 13, 6, 4, 9, 8,15, 3, 0,11, 1, 2,12, 5,10,14, 7,
  75.   1,10,13, 0, 6, 9, 8, 7, 4,15,14, 3,11, 5, 2,12,
  76. //S4
  77.   7,13,14, 3, 0, 6, 9,10, 1, 2, 8, 5,11,12, 4,15,
  78. 13, 8,11, 5, 6,15, 0, 3, 4, 7, 2,12, 1,10,14, 9,
  79. 10, 6, 9, 0,12,11, 7,13,15, 1, 3,14, 5, 2, 8, 4,
  80.   3,15, 0, 6,10, 1,13, 8, 9, 4, 5,11,12, 7, 2,14,
  81. //S5
  82.   2,12, 4, 1, 7,10,11, 6, 8, 5, 3,15,13, 0,14, 9,
  83. 14,11, 2,12, 4, 7,13, 1, 5, 0,15,10, 3, 9, 8, 6,
  84.   4, 2, 1,11,10,13, 7, 8,15, 9,12, 5, 6, 3, 0,14,
  85. 11, 8,12, 7, 1,14, 2,13, 6,15, 0, 9,10, 4, 5, 3,
  86. //S6
  87. 12, 1,10,15, 9, 2, 6, 8, 0,13, 3, 4,14, 7, 5,11,
  88. 10,15, 4, 2, 7,12, 0, 5, 6, 1,13,14, 0,11, 3, 8,
  89.   9,14,15, 5, 2, 8,12, 3, 7, 0, 4,10, 1,13,11, 6,
  90.      4, 3, 2,12, 9, 5,15,10,11,14, 1, 7, 6, 0, 8,13,
  91. //S7
  92.   4,11, 2,14,15, 0, 8,13, 3,12, 9, 7, 5,10, 6, 1,
  93. 13, 0,11, 7, 4, 0, 1,10,14, 3, 5,12, 2,15, 8, 6,
  94.   1, 4,11,13,12, 3, 7,14,10,15, 6, 8, 0, 5, 9, 2,
  95.   6,11,13, 8, 1, 4,10, 7, 9, 5, 0,15,14, 2, 3,12,
  96. //S8
  97. 13, 2, 8, 4, 6,15,11, 1,10, 9, 3,14, 5, 0,12, 7,
  98.   1,15,13, 8,10, 3, 7, 4,12, 5, 6,11, 0,14, 9, 2,
  99.   7,11, 4, 1, 9,12,14, 2, 0, 6,10,13,15, 3, 5, 8,
  100.   2, 1,14, 7, 4,10, 8,13,15,12, 9, 0, 3, 5, 6,11
  101. };
  102. //P置换表
  103. static char P_Table[32]={
  104. 16, 7,20,21,29,12,28,17, 1,15,23,26, 5,18,31,10,
  105.   2, 8,24,14,32,27, 3, 9,19,13,30, 6,22,11, 4,25
  106. };
  107. /*-------------------------------------------------------------------*/
  108. /*-----------------------------自定义函数-----------------------------*/
  109. void SetKey(char My_key[8]); //生成16轮的子密钥;
  110. void ByteToBit(bool * Data_out,char * Data_in,int Num); //字节转换成位;
  111. void Change_bit(bool * Data_out,int Num);//二进制的位置进行转换;
  112. void BitToByte(char My_message[8],bool * Message_in,int Num); //位转换成字节;
  113. void TableReplace(bool *Data_out,bool *Data_in,const char *Table,int Num);  //各种表的置换算法;
  114. void Bitcopy(bool * Data_out,bool * Data_in,int Num);  //二进制数组的拷贝
  115. void Loop_bit(bool * Data_out,int movstep,int len);  //左移位;
  116. void Run_Des(char My_message[8],char HexMssage[16]);//des的轮加密算法
  117. void Xor(bool * Message_out, bool * Message_in,int Num); //执行异或
  118. void S_change(bool * Data_out, bool * Data_in);  // S盒变换;
  119. void HexToBit(bool * Data_out,char * Data_in,int Num); // 十六进制转二进制
  120. void BitToHex(char * Data_out,bool * Data_in,int Num); //二进制转换成十六进制;
  121. void Run_desDes(char My_message[8],char HexMessage[16]);// DES轮解密算法;
  122. /*--------------------------*/
  123. /*--------------------------主函数----------------------------------*/
  124. int main()
  125. {
  126. int i=0,j;
  127. char My_key[8]={0};  //记录加密密钥;
  128. char You_key[8]={0}; //解密密钥
  129. char My_message[8]={0}; //明文
  130. char Message_hex[16]={0};//16进制的密文
  131. printf("请输入你要加密的内容(8 Byte):\n");
  132. gets(My_message);
  133. printf("请输入你的加密密钥:\n");
  134. gets(My_key);
  135. i=strlen(My_key);
  136. while(i!=8)
  137. {
  138.   printf("请输入加密密钥(8 Byte)\n");
  139.   gets(My_key);
  140.   i=0;
  141.   i=strlen(My_key);
  142. }
  143. SetKey(My_key);  //生成16轮的加密子密钥;
  144. Run_Des(My_message,Message_hex); //des的轮加密过程
  145. printf("经过加密的密文为:\n");
  146. for(i=0;i<16;i++)
  147. {
  148.   printf("%c ",Message_hex[i]);
  149. }
  150. printf("\n");
  151. printf("请输入你的解密密钥(8 Byte):\n");
  152. gets(You_key);
  153. i=strlen(You_key);
  154. while(i!=8)
  155. {
  156.   printf("请输入解密密钥(8 Byte)\n");
  157.   gets(You_key);
  158.   i=0;
  159.   i=strlen(You_key);
  160. }
  161. SetKey(You_key);  //生成16轮的解密子密钥;
  162. Run_desDes(My_message,Message_hex);//解密;
  163. printf("解密结果为:\n");
  164. for(i=0;i<8;i++)
  165. {
  166.   printf("%c ",My_message[i]);
  167. }
  168. printf("\n");
  169. return 0;
  170. }
  171. /*--------------------具体函数定义----------------------*/
  172. void Bitcopy(bool * Data_out, bool * Data_in,int Num) //二进制数组拷贝
  173. {
  174. int i=0;
  175. for(i=0;i<Num;i++)
  176. {
  177.   Data_out[i]=Data_in[i];
  178. }
  179. }
  180. void Change_bit(bool * Data_out,int Num) //二进制的位置进行转换;
  181. {
  182. int i,j;
  183. static bool Temp[8]={0};
  184. for(i=0;i<Num/8;i++)
  185. {
  186.   Bitcopy(Temp,Data_out,Num/8);
  187.   for(j=0;j<Num/8;j++)
  188.   {
  189.    Data_out[j]=Temp[Num/8-1-j];
  190.   }
  191.   Data_out+=Num/8;
  192. }
  193. }
  194. void ByteToBit( bool * Data_out,char * Data_in,int Num) //字节转位
  195. {
  196. int i,j;
  197. for(i=0;i<Num;i++)
  198. {
  199.   Data_out[i]=(Data_in[i/8]>>(i%8))&0x01;
  200. }
  201. //Change_bit(Data_out,Num);
  202. }
  203. void BitToHex(char * Data_out, bool * Data_in,int Num) //二进制转十六进制
  204. {
  205. int i;
  206. for(i=0;i<Num/4;i++)
  207. {
  208.   Data_out[i]=0;
  209. }
  210. for(i=0;i<Num/4;i++)
  211. {
  212.   Data_out[i]=Data_in[4*i]+Data_in[4*i+1]*2+Data_in[4*i+2]*4+Data_in[4*i+3]*8;
  213.   if(Data_out[i]%16>9)
  214.   {
  215.    Data_out[i]=Data_out[i]%16+'7';
  216.   }
  217.   else
  218.   Data_out[i]=Data_out[i]%16+'0';
  219. }
  220. }
  221. void HexToBit(bool * Data_out,char * Data_in,int Num) //十六进制转二进制
  222. {
  223. int i;
  224. for(i=0;i<Num;i++)
  225. {
  226.   if(Data_in[i/4]<='9')
  227.   {
  228.    Data_out[i]=((Data_in[i/4]-'0')>>(i%4))&0x01;
  229.   }
  230.   else
  231.   {
  232.    Data_out[i]=((Data_in[i/4]-'7')>>(i%4))&0x01;
  233.   }
  234. }
  235. }
  236. void BitToByte(char My_message[8],bool * Message_in,int Num) //位转换成字节
  237. {
  238. int i=0;
  239. for(i=0;i<(Num/8);i++)
  240. {
  241.   My_message[i]=0;
  242. }
  243. for(i=0;i<Num;i++)
  244. {
  245.   My_message[i/8]|=Message_in[i]<<(i%8);
  246. }
  247. }
  248. void TableReplace( bool *Data_out, bool * Data_in,const char *Table ,int Num) // 置换算法
  249. {
  250. int i=0;
  251. static bool Temp[256]={0};
  252. for(i=0;i<Num;i++)
  253. {
  254.   Temp[i]=Data_in[Table[i]-1];
  255. }
  256. Bitcopy(Data_out,Temp,Num);
  257. }
  258. void Loop_bit(bool * Data_out,int movstep,int len)
  259. {
  260. static bool Temp[256]={0};
  261. Bitcopy(Temp,Data_out,movstep);
  262. Bitcopy(Data_out,Data_out+movstep,len-movstep);
  263. Bitcopy(Data_out+len-movstep,Temp,movstep);
  264. /*Temp=Data_out;
  265. Temp[movstep]='\0';
  266. Data_out=Data_out+movstep;
  267. Data_out+(len-movstep)=Temp;*/
  268. }
  269. void Xor(bool * Message_out,bool * Message_in,int Num)//执行异或
  270. {
  271. int i;
  272. for(i=0;i<Num;i++)
  273. {
  274.   Message_out[i]=Message_out[i]^Message_in[i];
  275. }
  276. }
  277. void SetKey(char My_key[8])
  278. {
  279. int i,j;
  280. static bool Key_bit[64]={0}; //Key的二进制缓存;
  281. static bool *Key_bit_L,*Key_bit_R;
  282. Key_bit_L=&Key_bit[0]; //key的左边28位;
  283. Key_bit_R=&Key_bit[28]; //key的右边28位;
  284. ByteToBit(Key_bit,My_key,64);
  285. /* Change_bit(Key_bit,64) ;//二进制的位置进行转换;
  286. for(i=0;i<64;i++)
  287. {
  288.   printf("%d ",Key_bit[i]);
  289. }
  290. printf("\n");
  291. printf("\n");*/
  292. TableReplace(Key_bit,Key_bit,PC1_Table,56);//pc-1 置换
  293. for(i=0;i<16;i++)
  294. {
  295.   Loop_bit(Key_bit_L,Move_Table[i],28);
  296.   Loop_bit(Key_bit_R,Move_Table[i],28);
  297.   TableReplace(SubKey[i],Key_bit,PC2_Table,48);//pc-2置换
  298. }
  299. }
  300. void S_change(bool * Data_out, bool * Data_in) //S盒变换
  301. {
  302. int i;
  303. int r=0,c=0;//S盒的行和列;
  304. for(i=0;i<8;i++,Data_in=Data_in+6,Data_out=Data_out+4)
  305. {
  306.   r=Data_in[0]*2+Data_in[5]*1;
  307.   c=Data_in[1]*8+Data_in[2]*4+Data_in[3]*2+Data_in[4]*1;
  308.   ByteToBit(Data_out,&S_Box[i][r][c],4);
  309. }
  310. }
  311. void F_change(bool Data_out[32],bool Data_in[48])   // f函数;
  312. {
  313. int i;
  314. static bool Message_E[48]={0};  //存放E置换的结果;
  315. TableReplace(Message_E,Data_out,E_Table,48);//E表置换
  316. Xor(Message_E,Data_in,48);
  317. S_change(Data_out,Message_E);                 // S盒变换
  318. TableReplace(Data_out,Data_out,P_Table,32);  //P置换
  319. }
  320. void Run_Des(char My_message[8],char HexMssage[16])//des轮加密算法;
  321. {
  322. int i;
  323. static bool Message_bit[64]={0};
  324. static bool *Message_bit_L=&Message_bit[0],*Message_bit_R=&Message_bit[32];
  325. static bool Temp[32]={0};
  326. ByteToBit(Message_bit,My_message,64);
  327. /*Change_bit(Message_bit,64) ;//二进制的位置进行转换;
  328. for(i=0;i<64;i++)
  329. {
  330.   printf("%d ",Message_bit[i]);
  331. }
  332. printf("\n");
  333. printf("\n");*/
  334. TableReplace(Message_bit,Message_bit,IP_Table,64);
  335. for(i=0;i<16;i++)
  336. {
  337.   Bitcopy(Temp,Message_bit_R,32);
  338.   F_change(Message_bit_R,SubKey[i]);
  339.   Xor(Message_bit_R,Message_bit_L,32);
  340.   Bitcopy(Message_bit_L,Temp,32);
  341. }
  342. TableReplace(Message_bit,Message_bit,IPR_Table,64);
  343. BitToHex(HexMssage,Message_bit,64);//二进制转换成十六进制;
  344. }
  345. void Run_desDes(char My_message[8],char HexMessage[16])// DES轮解密算法;
  346. {
  347. int i=0;
  348. static bool Message_bit[64]={0};
  349. static bool * Message_bit_L=&Message_bit[0], * Message_bit_R=&Message_bit[32];
  350. static bool Temp[32]={0};
  351. HexToBit(Message_bit,HexMessage,64);
  352. TableReplace(Message_bit,Message_bit,IP_Table,64);
  353. for(i=15;i>=0;i--)
  354. {
  355.   Bitcopy(Temp,Message_bit_L,32);
  356.   F_change(Message_bit_L,SubKey[i]);
  357.   Xor(Message_bit_L,Message_bit_R,32);
  358.   Bitcopy(Message_bit_R,Temp,32);
  359. }
  360. TableReplace(Message_bit,Message_bit,IPR_Table,64);
  361. BitToByte(My_message,Message_bit,64);
  362. }
aoyi 发表于 2019-11-13 10:04 | 显示全部楼层
非常感谢分享
drer 发表于 2019-11-13 10:26 | 显示全部楼层
非常感谢分享
gwsan 发表于 2019-11-13 10:52 | 显示全部楼层
非常不错的资料
kxsi 发表于 2019-11-13 11:29 | 显示全部楼层
非常不错的资料
nawu 发表于 2019-11-13 11:41 | 显示全部楼层
非常不错的资料
