M23芯片,I2C_ReadMultiBytesOneReg函数修改,看不懂源码。。。
如果我想在函数中增加一些发送的数据,或修改停止或启动位,不知如何修改,请大侠指点。
- uint32_t I2C_ReadMultiBytesOneReg(I2C_T *i2c, uint8_t u8SlaveAddr, uint8_t u8DataAddr, uint8_t au8Rdata[], uint32_t u32rLen)
- uint8_t u8Xfering = 1u, u8Err = 0u, u8Ctrl = 0u;
- uint32_t u32rxLen = 0u;
- I2C_START(i2c); /* Send START */
- while(u8Xfering && (u8Err == 0u))
- I2C_WAIT_READY(i2c) {}
- switch(I2C_GET_STATUS(i2c))
- case 0x08u:
- I2C_SET_DATA(i2c, (uint8_t)(u8SlaveAddr << 1u | 0x00u)); /* Write SLA+W to Register I2CDAT */
- u8Ctrl = I2C_CTL_SI; /* Clear SI */
- break;
- case 0x18u: /* Slave Address ACK */
- I2C_SET_DATA(i2c, u8DataAddr); /* Write Lo byte address of register */
- break;
- case 0x20u: /* Slave Address NACK */
- case 0x30u: /* Master transmit data NACK */
- u8Ctrl = I2C_CTL_STO_SI; /* Clear SI and send STOP */
- u8Err = 1u;
- break;
- case 0x28u:
- u8Ctrl = I2C_CTL_STA_SI; /* Send repeat START */
- break;
- case 0x10u:
- I2C_SET_DATA(i2c, (uint8_t)((u8SlaveAddr << 1u) | 0x01u)); /* Write SLA+R to Register I2CDAT */
- break;
- case 0x40u: /* Slave Address ACK */
- u8Ctrl = I2C_CTL_SI_AA; /* Clear SI and set ACK */
- break;
- case 0x48u: /* Slave Address NACK */
- u8Err = 1u;
- break;
- case 0x50u:
- au8Rdata[u32rxLen++] = (uint8_t) I2C_GET_DATA(i2c); /* Receive Data */
- if(u32rxLen < (u32rLen - 1u))
- else
- break;
- case 0x58u:
- u8Xfering = 0u;
- break;
- case 0x38u: /* Arbitration Lost */
- default: /* Unknow status */
- u8Err = 1u;
- break;
- I2C_SET_CONTROL_REG(i2c, u8Ctrl); /* Write controlbit to I2C_CTL register */
- return u32rxLen; /* Return bytes length that have been received */
