发送和接受到的数据经常错位或卡顿 导致不稳定
STM32F103VE SPI 速度 9M
EPM240T100C5N 时钟 50M
应该时 CPLD SPI 接口程序问题 各位大哥帮忙看看
****************** name:SPI_Slaver_Driver **************
********** author:made by zzuxzt **********
****************** time:2014.4.29 **********************
//use SPI 3 mode,CHOL = 1,CHAL = 1
module spi( input clk,
input rst_n,
input CS_N,
input SCK,
input MOSI,
output reg MISO,
input [7:0] txd_data,
output reg [7:0] rxd_data,
output rxd_flag); /*recieve done,please transmit data*/
//-------------------------capture the sck-----------------------------
reg sck_r0,sck_r1;
wire sck_n,sck_p;
always@(posedge clk or negedge rst_n)
begin
if(!rst_n)
begin
sck_r0 <= 1'b1; //sck of the idle state is high
sck_r1 <= 1'b1;
end
else
begin
sck_r0 <= SCK;
sck_r1 <= sck_r0;
end
end
assign sck_n = (~sck_r0 & sck_r1)? 1'b1:1'b0; //capture the sck negedge
assign sck_p = (~sck_r1 & sck_r0)? 1'b1:1'b0; //capture the sck posedge
//-----------------------spi_slaver read data-------------------------------
reg rxd_flag_r;
reg [2:0] rxd_state;
begin
if(!rst_n)
begin
rxd_data <= 1'b0;
rxd_flag_r <= 1'b0;
rxd_state <= 1'b0;
end
else if(sck_p && !CS_N)
begin
case(rxd_state)
3'd0:begin
rxd_data[7] <= MOSI;
rxd_flag_r <= 1'b0; //reset rxd_flag
rxd_state <= 3'd1;
end
3'd1:begin
rxd_data[6] <= MOSI;
rxd_state <= 3'd2;
end
3'd2:begin
rxd_data[5] <= MOSI;
rxd_state <= 3'd3;
end
3'd3:begin
rxd_data[4] <= MOSI;
rxd_state <= 3'd4;
end
3'd4:begin
rxd_data[3] <= MOSI;
rxd_state <= 3'd5;
end
3'd5:begin
rxd_data[2] <= MOSI;
rxd_state <= 3'd6;
end
3'd6:begin
rxd_data[1] <= MOSI;
rxd_state <= 3'd7;
end
3'd7:begin
rxd_data[0] <= MOSI;
rxd_flag_r <= 1'b1; //set rxd_flag
rxd_state <= 3'd0;
end
default: ;
endcase
end
end
//--------------------capture spi_flag posedge--------------------------------
reg rxd_flag_r0,rxd_flag_r1;
begin
if(!rst_n)
begin
rxd_flag_r0 <= 1'b0;
rxd_flag_r1 <= 1'b0;
end
else
begin
rxd_flag_r0 <= rxd_flag_r;
rxd_flag_r1 <= rxd_flag_r0;
end
end
assign rxd_flag = (~rxd_flag_r1 & rxd_flag_r0)? 1'b1:1'b0;
//---------------------spi_slaver send data---------------------------
reg [2:0] txd_state;
begin
if(!rst_n)
begin
txd_state <= 1'b0;
end
else if(sck_n && !CS_N)
begin
case(txd_state)
3'd0:begin
MISO <= txd_data[7];
txd_state <= 3'd1;
end
3'd1:begin
MISO <= txd_data[6];
txd_state <= 3'd2;
end
3'd2:begin
MISO <= txd_data[5];
txd_state <= 3'd3;
end
3'd3:begin
MISO <= txd_data[4];
txd_state <= 3'd4;
end
3'd4:begin
MISO <= txd_data[3];
txd_state <= 3'd5;
end
3'd5:begin
MISO <= txd_data[2];
txd_state <= 3'd6;
end
3'd6:begin
MISO <= txd_data[1];
txd_state <= 3'd7;
end
3'd7:begin
MISO <= txd_data[0];
txd_state <= 3'd0;
end
default: ;
endcase
end
end
endmodule |
