- * [url=home.php?mod=space&uid=288409]@file[/url] main.c
- * [url=home.php?mod=space&uid=895143]@version[/url] V1.00
- * $Revision: 1 $
- * $Date: 14/10/01 10:35a $
- * [url=home.php?mod=space&uid=247401]@brief[/url] NUC029 Series PWM Generator and Capture Timer Driver Sample Code
- * @note
- * Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
- #include <stdio.h>
- #include "NUC029xAN.h"
- /* Macro, type and constant definitions */
- #define PLLCON_SETTING CLK_PLLCON_50MHz_HXT
- #define PLL_CLOCK 50000000
- * @brief PWMA IRQ Handler
- * @param None
- * [url=home.php?mod=space&uid=266161]@return[/url] None
- * [url=home.php?mod=space&uid=1543424]@Details[/url] ISR to handle PWMA interrupt event
- void PWMA_IRQHandler(void)
- /*In this sample code, user will not use PWMA channel 0~3 PIIR interrupt and CAPIF capture interrupt.
- Defined following code as 0 for reducing interrupt execution time and code size. */
- #if 0
- uint32_t u32PwmIntFlag, u32CapIntFlag0, u32CapIntFlag1;
- /* Handle PWMA Capture function */
- u32CapIntFlag0 = PWMA->CCR0;
- u32CapIntFlag1 = PWMA->CCR2;
- if(u32CapIntFlag0 & PWM_CCR0_CAPIF0_Msk)
- PWMA->CCR0 &= (PWM_CCR_MASK | PWM_CCR0_CAPIF0_Msk);
- else if(u32CapIntFlag0 & PWM_CCR0_CAPIF1_Msk)
- PWMA->CCR0 &= (PWM_CCR_MASK | PWM_CCR0_CAPIF1_Msk);
- else if(u32CapIntFlag1 & PWM_CCR2_CAPIF2_Msk)
- PWMA->CCR2 &= (PWM_CCR_MASK | PWM_CCR2_CAPIF2_Msk);
- else if(u32CapIntFlag1 & PWM_CCR2_CAPIF3_Msk)
- PWMA->CCR2 &= (PWM_CCR_MASK | PWM_CCR2_CAPIF3_Msk);
- /* Handle PWMA Timer function */
- u32PwmIntFlag = PWMA->PIIR;
- if(u32PwmIntFlag & PWM_PIIR_PWMIF0_Msk)
- PWMA->PIIR = PWM_PIIR_PWMIF0_Msk;
- else if(u32PwmIntFlag & PWM_PIIR_PWMIF1_Msk)
- PWMA->PIIR = PWM_PIIR_PWMIF1_Msk;
- else if(u32PwmIntFlag & PWM_PIIR_PWMIF2_Msk)
- PWMA->PIIR = PWM_PIIR_PWMIF2_Msk;
- else if(u32PwmIntFlag & PWM_PIIR_PWMIF3_Msk)
- PWMA->PIIR = PWM_PIIR_PWMIF3_Msk;
- #endif
- * @brief PWMB IRQ Handler
- * @param None
- * @return None
- * @details ISR to handle PWMB interrupt event
- void PWMB_IRQHandler(void)
- // uint32_t u32PwmIntFlag;
- uint32_t u32CapIntFlag1;
- /* Handle PWMB Capture function */
- u32CapIntFlag1 = PWMB->CCR2;
- /* PWMB channel 2 Capture interrupt */
- if(u32CapIntFlag1 & PWM_CCR2_CAPIF2_Msk)
- PWMB->CCR2 &= (PWM_CCR_MASK | PWM_CCR2_CAPIF2_Msk);
- /* Capture function to calculate the input waveform information */
- /* u32Count[4] : Keep the internal counter value when input signal rising / falling */
- /* happens */
- /* time A B C D */
- /* ___ ___ ___ ___ ___ ___ ___ ___ */
- /* ____| |_| |_| |_| |_| |_| |_| |_| |_____ */
- /* index 0 1 2 3 */
- /* The capture internal counter down count from 0x10000, and reload to 0x10000 after */
- /* input signal falling happens (Time B/C/D) */
- void CalPeriodTime(PWM_T *PWM, uint32_t u32Ch)
- uint16_t u32Count[4];
- uint32_t u32i;
- uint16_t u16RisingTime, u16FallingTime, u16HighPeroid, u16LowPeroid, u16TotalPeroid;
- /* Clear Capture Falling Indicator (Time A) */
- PWM_ClearCaptureIntFlag(PWM, u32Ch, PWM_CAPTURE_INT_FALLING_LATCH);
- /* Wait for Capture Falling Indicator */
- while(PWM_GetCaptureIntFlag(PWM, u32Ch) < 2);
- /* Clear Capture Falling Indicator (Time B)*/
- u32i = 0;
- while(u32i < 4)
- /* Clear Capture Falling and Rising Indicator */
- PWM_ClearCaptureIntFlag(PWM, u32Ch, PWM_CAPTURE_INT_FALLING_LATCH | PWM_CAPTURE_INT_RISING_LATCH);
- /* Get Capture Falling Latch Counter Data */
- u32Count[u32i++] = PWM_GET_CAPTURE_FALLING_DATA(PWM, u32Ch);
- /* Wait for Capture Rising Indicator */
- /* Clear Capture Rising Indicator */
- PWM_ClearCaptureIntFlag(PWM, u32Ch, PWM_CAPTURE_INT_RISING_LATCH);
- /* Get Capture Rising Latch Counter Data */
- u32Count[u32i++] = PWM_GET_CAPTURE_RISING_DATA(PWM, u32Ch);
- u16RisingTime = u32Count[1];
- u16FallingTime = u32Count[0];
- u16HighPeroid = u32Count[1] - u32Count[2];
- u16LowPeroid = 0x10000 - u32Count[1];
- u16TotalPeroid = 0x10000 - u32Count[2];
- printf("\nPWM generate: \nHigh Period=7199 ~ 7201, Low Period=16799 ~ 16801, Total Period=23999 ~ 24001\n");
- printf("\nCapture Result: Rising Time = %d, Falling Time = %d \nHigh Period = %d, Low Period = %d, Total Period = %d.\n\n",
- u16RisingTime, u16FallingTime, u16HighPeroid, u16LowPeroid, u16TotalPeroid);
- if((u16HighPeroid < 7199) || (u16HighPeroid > 7201) || (u16LowPeroid < 16799) || (u16LowPeroid > 16801) || (u16TotalPeroid < 23999) || (u16TotalPeroid > 24001))
- printf("Capture Test Fail!!\n");
- else
- printf("Capture Test Pass!!\n");
- void SYS_Init(void)
- /* Init System Clock */
- /* Enable Internal RC clock */
- CLK->PWRCON |= CLK_PWRCON_OSC22M_EN_Msk;
- /* Waiting for IRC22M clock ready */
- while(!(CLK->CLKSTATUS & CLK_CLKSTATUS_OSC22M_STB_Msk));
- /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
- CLK->CLKSEL0 &= ~CLK_CLKSEL0_HCLK_S_Msk;
- CLK->CLKSEL0 |= CLK_CLKSEL0_HCLK_S_HIRC;
- CLK->CLKDIV &= ~CLK_CLKDIV_HCLK_N_Msk;
- /* Set PLL to power down mode and PLL_STB bit in CLKSTATUS register will be cleared by hardware.*/
- CLK->PLLCON |= CLK_PLLCON_PD_Msk;
- /* Enable external 12MHz XTAL, internal 22.1184MHz */
- CLK->PWRCON |= CLK_PWRCON_XTL12M_EN_Msk | CLK_PWRCON_OSC22M_EN_Msk;
- /* Enable PLL and Set PLL frequency */
- CLK->PLLCON = PLLCON_SETTING;
- /* Waiting for clock ready */
- while(!(CLK->CLKSTATUS & (CLK_CLKSTATUS_PLL_STB_Msk | CLK_CLKSTATUS_XTL12M_STB_Msk | CLK_CLKSTATUS_OSC22M_STB_Msk)));
- /* Switch HCLK clock source to PLL, STCLK to HCLK/2 */
- CLK->CLKSEL0 = CLK_CLKSEL0_STCLK_S_HCLK_DIV2 | CLK_CLKSEL0_HCLK_S_PLL;
- /* Enable IP clock */
- CLK->APBCLK = CLK_APBCLK_UART0_EN_Msk | CLK_APBCLK_PWM45_EN_Msk | CLK_APBCLK_PWM67_EN_Msk;
- /* IP clock source */
- CLK->CLKSEL1 = CLK_CLKSEL1_UART_S_PLL;
- CLK->CLKSEL2 = CLK_CLKSEL2_PWM45_S_HXT | CLK_CLKSEL2_PWM67_S_HXT;
- /* Reset PWMB channel0~channel3 */
- SYS->IPRSTC2 = SYS_IPRSTC2_PWM47_RST_Msk;
- SYS->IPRSTC2 = 0;
- /* Update System Core Clock */
- /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
- //SystemCoreClockUpdate();
- PllClock = PLL_CLOCK; // PLL
- SystemCoreClock = PLL_CLOCK / 1; // HCLK
- CyclesPerUs = PLL_CLOCK / 1000000; // For SYS_SysTickDelay()
- /* Init I/O Multi-function */
- /* Set P3 multi-function pins for UART0 RXD and TXD */
- SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
- SYS->P3_MFP |= (SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0);
- /* Set P2 multi-function pins for PWMB Channel0~3 */
- SYS->P2_MFP &= ~(SYS_MFP_P25_Msk | SYS_MFP_P26_Msk);
- SYS->P2_MFP |= (SYS_MFP_P25_PWM5 | SYS_MFP_P26_PWM6);
- void UART0_Init(void)
- /* Init UART */
- UART0->BAUD = UART_BAUD_MODE2 | UART_BAUD_MODE2_DIVIDER(PLL_CLOCK, 115200);
- UART0->LCR = UART_WORD_LEN_8 | UART_PARITY_NONE | UART_STOP_BIT_1;
- /* Main Function */
- int32_t main(void)
- /* Unlock protected registers */
- SYS_UnlockReg();
- /* Init System, IP clock and multi-function I/O */
- SYS_Init();
- /* Lock protected registers */
- SYS_LockReg();
- /* Init UART0 for printf */
- UART0_Init();
- printf("+------------------------------------------------------------------------+\n");
- printf("| PWM Driver Sample Code |\n");
- printf("| |\n");
- printf(" This sample code will use PWMB channel 2 to capture\n the signal from PWMB channel 1.\n");
- printf(" I/O configuration:\n");
- printf(" PWM5(P2.5 PWMB channel 1) <--> PWM6(P2.6 PWMB channel 2)\n\n");
- printf("Use PWMB Channel 2(P2.6) to capture the PWMB Channel 1(P2.5) Waveform\n");
- while(1)
- printf("Press any key to start PWM Capture Test\n");
- getchar();
- /* Set the PWMB Channel 1 as PWM output function. */
- /* Assume PWM output frequency is 250Hz and duty ratio is 30%, user can calculate PWM settings by follows.
- duty ratio = (CMR+1)/(CNR+1)
- cycle time = CNR+1
- High level = CMR+1
- PWM clock source frequency = __HXT = 12000000
- (CNR+1) = PWM clock source frequency/prescaler/clock source divider/PWM output frequency
- = 12000000/2/1/250 = 24000
- (Note: CNR is 16 bits, so if calculated value is larger than 65536, user should increase prescale value.)
- CNR = 23999
- duty ratio = 30% ==> (CMR+1)/(CNR+1) = 30%
- CMR = 7199
- Prescale value is 1 : prescaler= 2
- Clock divider is PWM_CSR_DIV1 : clock divider =1
- /* set PWMB channel 1 output configuration */
- PWM_ConfigOutputChannel(PWMB, PWM_CH1, 250, 30);
- /* Enable PWM Output path for PWMB channel 1 */
- PWM_EnableOutput(PWMB, 0x2);
- /* Enable Timer for PWMB channel 1 */
- PWM_Start(PWMB, 0x2);
- /* Set the PWMB channel 2 for capture function */
- /* If input minimum frequency is 250Hz, user can calculate capture settings by follows.
- Capture clock source frequency = __HXT = 12000000 in the sample code.
- (CNR+1) = Capture clock source frequency/prescaler/clock source divider/minimum input frequency
- CNR = 0xFFFF
- (Note: In capture mode, user should set CNR to 0xFFFF to increase capture frequency range.)
- /* set PWMB channel 2 capture configuration */
- PWM_ConfigCaptureChannel(PWMB, PWM_CH2, 166, 0);
- /* Enable capture falling edge interrupt for PWMB channel 2 */
- PWM_EnableCaptureInt(PWMB, PWM_CH2, PWM_CAPTURE_INT_FALLING_LATCH);
- /* Enable PWMB NVIC interrupt */
- NVIC_EnableIRQ((IRQn_Type)(PWMB_IRQn));
- /* Enable Timer for PWMB channel 2 */
- PWM_Start(PWMB, 0x4);
- /* Enable Capture Function for PWMB channel 2 */
- PWM_EnableCapture(PWMB, 0x4);
- /* Wait until PWMB channel 2 Timer start to count */
- while(PWMB->PDR2 == 0);
- /* Capture the Input Waveform Data */
- CalPeriodTime(PWMB, PWM_CH2);
- /* Stop PWMB channel 1 (Recommended procedure method 1) */
- /* Set PWM Timer loaded value(CNR) as 0. When PWM internal counter(PDR) reaches to 0, disable PWM Timer */
- /* Set PWMB channel 1 loaded value as 0 */
- PWM_Stop(PWMB, 0x2);
- /* Wait until PWMB channel 1 Timer Stop */
- while(PWMB->PDR1 != 0);
- /* Disable Timer for PWMB channel 1 */
- PWM_ForceStop(PWMB, 0x2);
- /* Disable PWM Output path for PWMB channel 1 */
- PWM_DisableOutput(PWMB, 0x2);
- /* Stop PWMB channel 2 (Recommended procedure method 1) */
- /* Disable PWMB NVIC */
- NVIC_DisableIRQ((IRQn_Type)(PWMB_IRQn));
- /* Set loaded value as 0 for PWMB channel 2 */
- PWM_Stop(PWMB, 0x4);
- /* Wait until PWMB channel 2 current counter reach to 0 */
- while(PWMB->PDR2 != 0);
- /* Disable Timer for PWMB channel 2 */
- PWM_ForceStop(PWMB, 0x4);
- /* Disable Capture Function and Capture Input path for PWMB channel 2*/
- PWM_DisableCapture(PWMB, 0x4);
- /* Clear Capture Interrupt flag for PWMB channel 2*/
- PWM_ClearCaptureIntFlag(PWMB, PWM_CH2, PWM_CAPTURE_INT_FALLING_LATCH);
