Systick实验中,Systick用来定时。来看看程序中什么地方出现过Systick相关的语句。 main.c: - /* SysTick end of count event each 1ms with input clock equal to 9MHz (HCLK/8, default) */
- SysTick_SetReload(9000);
- /* Enable SysTick interrupt */
- SysTick_ITConfig(ENABLE);
- * Function Name : Delay
- * Description : Inserts a delay time.
- * Input : nTime: specifies the delay time length, in milliseconds.
- * Output : None
- * Return : None
- void Delay(u32 nTime)
- /* Enable the SysTick Counter */
- SysTick_CounterCmd(SysTick_Counter_Enable);
- TimingDelay = nTime;
- while(TimingDelay != 0);
- /* Disable SysTick Counter */
- SysTick_CounterCmd(SysTick_Counter_Disable);
- /* Clear SysTick Counter */
- SysTick_CounterCmd(SysTick_Counter_Clear);
- * Function Name : TimingDelay_Decrement
- * Description : Decrements the TimingDelay variable.
- * Input : None
- * Output : TimingDelay
- * Return : None
- void TimingDelay_Decrement(void)
- if (TimingDelay != 0x00)
- TimingDelay--;
- stm32f10x_it.c:
- void SysTickHandler(void)
- TimingDelay_Decrement();
